Canon Support for imageCLASS MF247dw | Canon U.S.A., Inc.
imageCLASS MF247dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Printer Specifications
Printer Type | Monochrome Laser |
Print Speed | Up to 16ppm (2-sided plain paper letter) / 28ppm (1-sided plain paper letter)1 |
First Print Time | 6 seconds or less (letter)2 |
Printer Language | UFR II LT (Host-based), PCL (5e, 6) |
Print Resolution | Up to 600 x 600 dpi |
Maximum Print Size | Up to Legal (8.5 x 14 inches) |
Duplex Print | Yes |
Print Modes | Watermark, Page Composer, Toner Saver |
Print Memory | 512 MB (Shared) |
Copier Specifications
Copy Speed | Up to 28ppm (letter, 1-sided), Up to 16ppm (letter, 2-sided) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo, Text, Photo |
Halftones | 256 Levels |
Warm-up Time | 14 seconds or less from power on |
First Copy Time | Approximately 9 seconds3 |
Recovery Time | Approximately 2 seconds |
Maximum Number of Copies | Up to 999 copies |
Reduction/Enlargement | 25-400% in 1% increments |
Copy Size | Platen: Up to 8.5 x 11, Feeder: Up to 8.5 x 14 |
Copy Features | Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Copy Memory | 512 MB (Shared) |
Fax Specifications
Modem Speed | Up to 33.6 Kbps (Super G3)4 |
Fax Resolution | Up to 200 x 400 dpi (ultra fine) |
Transmission Time | Approx. 3 seconds per page |
Memory Capacity | Up to 256 pages5 |
Speed Dials | Up to 4 one-touch speed dials, up to 100 coded dials |
Group Dialing | 103 destinations |
Sequential Broadcasting | 114 destinations |
Duplex Fax | No |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | Fax forwarding, Dual Access, Remote Reception, PC Fax (sending only), Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Fax Activity / Result Reports, Fax Activity Management Reports |
Memory Backup | Yes |
pC Fax | Sending only |
Fax Forwarding | SMB, E-mail |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical) |
Scan Size | Platen: Up to Letter, Feeder: Up to Legal |
Duplex Scan | No |
Compatibility | TWAIN, WIA, ICA |
Output File Formats | TIFF, JPEG, PDF, Compact PDF, Searchable PDF |
Scan Features | Push Scan, Pull Scan: USB and Network |
Send Specifications
Scan to Email | Yes - TIFF, JPEG, PDF, Compact PDF, Searchable PDF |
Scan to SMB | Yes - TIFF, JPEG, PDF, Compact PDF, Searchable PDF |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet cassette plus 1-sheet multipurpose tray, 16-43 lb. (bond, plain paper)6 |
Document Feeder | 35-sheet Auto Document Feeder6 |
Paper Output | 100 sheets (face down) |
Media Sizes | Letter, Legal, Executive, Statement |
Media Types | Plain, Color, Recycled, Heavy, Bond, Label, Envelope |
Envelope Capacity | 1 (Multipurpose Tray) |
Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet (Network), 802.11 b/g/n Wireless7, Wi-Fi Direct Connection8 |
WiFi Access Mode | Infrastructure Mode, WPS Easy Set Up |
WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
Mobile Functions | Canon PRINT Business9, Apple® AirPrint®10, Mopria™ Print Service11, Google Cloud Print™12 |
Network Functions | Print, PC Fax, Scan, Send |
Web Browser Support for Remote UI | IE 7.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6), IPP, IPPS |
TCP/IP Set of Application Services | Bonjour(mDNS),DHCP, BOOTP, RARP, Auto IP (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1/SNMPv3 (IPv4,IPv6), HTTP/HTTPS, SNTP |
OS Compatibility | Windows® 10, 8.1, 8, 7, Windows Vista®,Windows Server® 2012, 2012 R2, 2008, 2008 R2, 2003, 2003 R2, Mac OS 10.6.8 or later |
Cable Included | Power Cord, Phone Cable (USB not included) |
Bundled Software | Printer driver, Fax driver, Scanner driver, MF Scan Utility, Address Book Tool |
Environmental Specifications
Power Consumption | Approx: Operation: 480 W, Standby: 5.6 W, Energy Saver: 1.2 W (USB), 1.3 W (wired), 2 W (wireless) |
Typical Energy Consumption | 0.9kWh |
General Specifications
Dimensions | 15.4"(W) x 14.7"(D) x 14.2"(H) |
Unit Weight (without/with cartridge) | 26.9 lbs. w/o cartridge, 28.3 lbs. w/ cartridge |
Package Weight | 37.5 lbs |
Cartridge Type | Cartridge 137 (Yields approximately 2,400 pages), Single Cartridge System *Yields based on ISO/IEC Standard |
LCD Display | Tiltable, Touch LCD |
Duty Cycle | Up to 15,000 pages per month, RMPV (Recommended Monthly Print Volume): 750 - 3,000 pages |
Security | IP/MAC address filtering, IEEE802.1x, SNMPv3, HTTPS/IPPS |
Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Simplified Chinese, Traditional Chinese, Korean |
Warranty | 1 year limited exchange/carry-in warranty13 (Extended warranty available) |
PRODUCT LIMITED WARRANTY
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
