Canon Support for imageCLASS MF426dw | Canon U.S.A., Inc.
imageCLASS MF426dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
| Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 | Golden Gate 27 |
imageCLASS MF426dw / MF424dw Spec Sheet
imageCLASS MF426dw / MF424dw | |
| MAIN UNIT | |
| TYPE | Black and White Laser Multifunctional |
| CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Fax |
| PROCESSOR | Canon Custom Processor |
| CONTROL PANEL | 5" Color Touch-panel |
| MEMORY | 1GB |
| STANDARD INTERFACE CONNECTION | USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection |
| PAPER CAPACITY (LTR, 20LB BOND) | Standard: 350 Sheets Maximum: 900 Sheets |
| PAPER SOURCES (LTR, 20LB BOND) | Standard: 250-sheet Paper Cassette, 100-sheet Optional: 550-sheet Paper Cassettes (Cassette Unit-AH1) |
| PAPER OUTPUT CAPACITY (LTR, 20LB BOND) | Standard: 65 Sheets |
| SUPPORTED MEDIA TYPES | Cassettes: Thin, Plain, Recycled, Thick, Bond Stack Bypass: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes) |
| SUPPORTED MEDIA SIZES | Cassettes: Letter, Legal, Statement, Executive Stack Bypass: Letter, Legal, Statement, Executive |
| SUPPORTED MEDIA WEIGHTS | Cassettes: 14.0 lb. Bond to 32.0 lb. Bond (52 to 120 g/m2) Stack Bypass: 14.0 lb. Bond to 43.0 lb. Bond (52 to 163 g/m2) |
| WARM-UP TIME | From Power On: 14 Seconds or less From Sleep Mode: 4 Seconds or less |
| DIMENSIONS (W x D x H) | Standard (Desktop): 17.9" x 18.3" x 15.5" (453 mm x 464 mm x 392 mm) |
| INSTALLATION SPACE (W x D x H) | Standard (Desktop): 19.5" x 35.7" x 28.6" (453 mm x 883 mm x 664 mm) Fully Configured: 19.5" x 35.7" x 43.9" (453 mm x 883 mm x 795 mm) |
| WEIGHT | Machine Only: Approx. 35.8 lb. (16.2 kg) Boxed Weight: Approx. 45.9 lb. (20.8 kg) |
| PRINT SPECIFICATIONS | |
| PRINTING METHOD | Laser Beam Printing |
| PRINT SPEED2 | Up to 40 ppm (Letter); Up to 32 ppm (Legal) |
| FIRST PRINT-OUT-TIME | Approximately 6 seconds |
| RECOMMENDED MONTHLY PAGE VOLUME | 500 - 4,000 Pages |
| PRINT RESOLUTION (dpi) | 600 x 600 |
| STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, PCL®5, Adobe PostScript 3® (MF426dw only) |
| DOUBLE SIDED PRINTING | Automatic (Standard) |
| DIRECT PRINT | Available from USB memory (JPEG, TIFF, PDF) |
| PRINTING FROM MOBILE AND CLOUD-BASED SERVICES5 | Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service, Google Cloud Print,™4 |
| FONTS | PCL fonts: 45 Fonts PS fonts: 136 Fonts (MF426dw only) |
| OPERATING SYSTEM | UFR II/PCL/PS: Windows®7 / Windows 8.1 / Windows 10 / Windows Server2008 / Windows Server2008 R2 / Windows Server2012 / Windows Server2012 R2 / Windows Server2016 Mac OS X v10.8.5 (or later) |
| COPY SPECIFICATIONS | |
| COPY SPEED | Up to 40 ppm (Letter); Up to 32 ppm (Legal) |
| FIRST-COPY-OUT-TIME (LETTER) | As fast as 6.0 seconds |
| COPY RESOLUTION (dpi) | 600 x 600 |
| COPY SIZE | Platen: Up to Letter ADF: Up to Legal |
| MULTIPLE COPIES | Up to 999 Copies |
| MAGNIFICATION | 25% - 400% (1% Increments) |
| PRESET REDUCTIONS | 25%, 50%, 64%, 78% |
| PRESET ENLARGEMENTS | 129%, 200%, 400% |
| COPY FEATURES | Paper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card |
| SCAN SPECIFICATIONS | |
| TYPE | Single-Pass Duplexing Automatic Document Feeder |
| DOCUMENT FEEDER PAPER CAPACITY | 50 Sheets (20 lb. Bond) |
| DOCUMENT FEEDER SUPPORTED MEDIA SIZES | Legal, Letter, Statement |
| DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Single and Double-sided scanning: 13-28 lb. Bond (50-105 g/m2) |
| PLATEN ACCEPTABLE ORIGINALS | Sheet, Book |
| PULL SCAN | ScanGear MF for TWAIN, WIA, and ICA |
| SUPPORTED OS | Windows 7 / Windows 8.1 / Windows 10 / Windows Server2008 / Windows Server2008 R2 / Windows Server2012 / Windows Server2012 R2 / Windows Server2016 / Mac OS X v10.8.5 (or later) |
| SCAN RESOLUTION (dpi) | 300 x 600, 600 x 600 |
| SCAN TO MOBILE DEVICES | Canon PRINT Business |
| SCAN SPEED (LETTER) | Single-sided: 13/38 ipm (300 x 600 dpi) (Color/BW) Double-sided: 26/70 ipm (300 dpi) (Color/BW) |
| MEMORY MEDIA | Standard USB Memory (JPEG, TIFF, PDF) |
| SEND SPECIFICATIONS | |
| DESTINATION | Email/Internet FAX (SMTP), SMB, FTP, Super G3 FAX |
| ADDRESS BOOK | LDAP (50)/Local (300)/Speed dial (281) |
| SEND RESOLUTION (dpi) | 600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other) |
| COMMUNICATION PROTOCOL | File: FTP, SMB E-mail/I-Fax: SMTP, POP3, iFax (Simple) |
| FILE FORMAT | Standard: TIFF, JPEG, PDF (Compact, Searchable) |
| FAX SPECIFICATIONS | |
| MODEM SPEED | Super G3: 33.6 kbps G3: 14.4 kbps |
| COMPRESSION METHOD | MH, MR, MMR, JBIG |
| RESOLUTION (dpi) | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
| SENDING / RECORDING SIZE | Statement to Legal |
| FAX MEMORY | Up to 512 Pages |
| SPEED DIALS | Max. 281 |
| GROUP DIALS / DESTINATIONS | Max. 299 dials |
| SEQUENTIAL BROADCAST | Max. 310 Addresses |
| MEMORY BACKUP | Yes |
| FAX FEATURES | RX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax |
| SECURITY SPECIFICATIONS | |
| AUTHENTICATION | Standard: Department ID Authentication |
| NETWORK | Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
| DOCUMENT | Standard: Secure Print |
| WI-FI AUTHENTICATION METHODS | Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) Wi-Fi Access Point: WPA2-PSK (AES) |
| ENVIRONMENTAL SPECIFICATIONS | |
| OPERATING ENVIRONMENT | Temperature: 50 to 86º F Humidity: 20 to 80% RH (no condensation) |
| POWER REQUIREMENTS | AC 120-127 V:6.5 A, 60 Hz |
| POWER CONSUMPTION | Maximum: Approx. 1320 W Standby: Approx. 10 W Sleep Mode: Approx. 0.9 W Typical Electricity Consumption (TEC) Rating: 1.3 kWh |
| STANDARDS | ENERGY STAR® Qualified, Rated EPEAT Silver |
| FOOTNOTES | |
| 1 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net. 2 Print speed is based on internal testing. Print speed may vary depending on the number of copies selected as well as the settings for size, type, and orientation of paper. 3 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information. 4 Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions. 5 Warranty program is subject to certain conditions and restrictions. See warranty card for details. | |
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
next to your download
