Canon Support for imageCLASS MF449dw | Canon U.S.A., Inc.
imageCLASS MF449dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.16.24
File Size 1.32 MB
Date 04.26.23
File Size 460.45 KB
Date 01.30.23
File Size 2.16 MB
Date 01.30.23
File Size 2.92 MB
Date 12.23.20
File Size 819.56 KB
Date 07.19.23
File Size 405.58 KB
Date 07.19.23
File Size 154.27 KB
Date 12.19.23
File Size 1.85 MB
Date 01.30.23
File Size 2.26 MB
Date 10.03.19
File Size 958.35 KB
Date 01.30.23
File Size 144.76 KB
Date 09.16.24
File Size 1.85 MB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 07.19.23
File Size 146.85 KB
Date 09.03.19
File Size 408.66 KB
Date 12.01.20
File Size 961.90 KB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 12.19.23
File Size 476.17 KB
Date 10.03.19
File Size 2.92 MB
Date 09.11.25
File Size 2.27 MB
Date 09.11.25
File Size 1.32 MB
Date 03.02.26
File Size 1.85 MB
Date 09.16.26
File Size 2.27 MB
Date 10.07.26
File Size 1.32 MB
Date 10.07.26
File Size 1.85 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF449dw
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS MF449dw
Products ChromeOS
imageCLASS MF449dw
imageCLASS MF449dw Brochure
imageCLASS MF449dw
MAIN UNIT
CORE FUNCTIONSStandard: Print, Copy, Scan, Send, Fax
PROCESSORCanon Custom Processor
CONTROL PANEL5" Color Touch Panel
MEMORY1 GB
STANDARD INTERFACE CONNECTIONUSB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 350 Sheets
Maximum: 900 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)Standard: 250-sheet Paper Cassette, 100-sheet Multipurpose Tray
Optional: 550-sheet Paper Cassettes (Cassette Unit-AH1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)Standard: 65 Sheets
SUPPORTED MEDIA TYPESCassettes: Thin, Plain, Recycled, Thick, Bond
Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTSCassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
WARM-UP TIMEFrom Power On: 14 Seconds or Less
From Sleep Mode: 4 Seconds or Less
DIMENSIONS (W x D x H)Standard (Desktop): 17.9" x 18.3" x 15.5" (453 mm x 464 mm x 392 mm)
INSTALLATION SPACE (W x D x H)Standard (Desktop): 17.9" x 34.8" x 26.2" (553 mm x 983 mm x 664 mm)
Fully Configured: 17.9" x 34.8" x 31.3" (453 mm x 883 mm x 795 mm)
WEIGHT4Unit: Approx. 35.8 lb. (16.2 kg)
Boxed Weight: Approx. 45.9 lb. (20.8 kg)
OPERATING SYSTEMSUFR II/PCL/PS: Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/ Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X v10.8.5 (or later)
PRINT SPECIFICATIONS
PRINTING METHODLaser Beam Printing
PRINT SPEED5 Up to 40 ppm (Letter); Up to 32 ppm (Legal)
FIRST PRINT OUT TIMEApprox. 5.3 Seconds
RECOMMENDED MONTHLY PAGE VOLUME750 - 4,000 Pages
PRINT RESOLUTION (dpi)600 x 600
STANDARD PAGE DESCRIPTION LANGUAGESUFR II, PCL®6, PCL®5, Adobe PostScript 3®
DOUBLE-SIDED PRINTINGAutomatic (Standard)
DIRECT PRINTAvailable from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service, uniFLOW Secure Mobile Printing
FONTSPCL: 93 Fonts PS: 136 Fonts
PRINT FEATURESSecure Print, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations
COPY SPECIFICATIONS
COPY SPEEDUp to 40 ppm (Letter); Up to 32 ppm (Legal)
FIRST-COPY-OUT-TIME (LETTER)Approx. 6.2 Seconds
COPY RESOLUTION600 x 600
COPY SIZEPlaten: Up to Letter
ADF: Up to Legal
MULTIPLE COPIESUp to 999 Copies
MAGNIFICATION25% - 400% (1% Increments)
PRESET REDUCTIONS25%, 50%, 64%, 78%
PRESET ENLARGEMENTS129%, 200%, 400%
COPY FEATURESPaper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
SCAN SPECIFICATIONS
TYPESingle-Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY50 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZESLegal, Letter, Statement
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTSSingle and Double-sided scanning: 13-28 lb. Bond (50-105 g/m2)
PLATEN ACCEPTABLE ORIGINALSSheet, Book
PULL SCANScanGear MF for TWAIN, WIA, and ICA
SCAN RESOLUTION300 x 600, 600 x 600
SCAN TO MOBILE DEVICES Canon PRINT Business
SCAN SPEED (LETTER)Single-sided: 13/38 ipm (300 x 300 dpi) (Color/BW)
Double-sided: 26/70 ipm (300 x 300 dpi) (Color/BW)
MEMORY MEDIAStandard USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATIONEmail/Internet FAX (SMTP), SMB, FTP, Super G3 FAX
ADDRESS BOOKLDAP (50)/Local (300)/Speed Dial (281)
SEND RESOLUTION600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other)
COMMUICATION PROTOCOLFile: FTP, SMB
Email/iFax: SMTP, POP3, iFax (Simple)
FILE FORMATStandard: TIFF, JPEG, PDF (Compact, Searchable)
Optional: PDF (Encrypted, Digital Signature)
FAX SPECIFICATIONS
MODEM SPEEDSuper G3: 33.6 kbps
G3: 14.4 kbps
COMPRESSION METHODMH, MR, MMR, JBIG
RESOLUTION400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZEStatement to Legal
FAX MEMORYUp to 512 Pages
SPEED DIALSMax. 281 Dials
GROUP DIALS / DESTINATIONSMax. 299 Dials
SEQUENTIAL BROADCASTMax. 310 Addresses
MEMORY BACKUPYes
FAX FEATURESRX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax
SECURITY SPECIFICATIONS
AUTHENTICATIONStandard: Embedded Universal Login Manager, Department ID Authentication
Optional: uniFLOW, uniFLOW Online
DATAStandard: Verify System at Startup
NETWORKStandard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENTStandard: Secure Print, High Compression PDF, Searchable PDF
Optional: Encrypted PDF, User and Device Signatures
WI-FI AUTHENTICATION METHODSWi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENTTemperature: 50 to 86º F
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTSAC 120-127 V:6.5 A, 60 Hz
POWER CONSUMPTIONMaximum: Approx. 1330 W
Standby: Approx. 10 W
Sleep Mode: Approx. 0.9 W
Typical Electricity Consumption (TEC) Rating: 0.34 kWh
STANDARDSENERGY STAR® Qualified, Rated EPEAT Silver3
CONSUMABLES
TONERCartridge 057 Black, Standard - Yields up to 3,100 Pages
Cartridge 057 Black, High Capacity - Yields up to 10,000 Pages
FOOTNOTES
  1. Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
  2. Please reference user manuals for details on settings available to export.
  3. For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
  4. Includes consumables.
  5. Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
  6. Warranty program is subject to certain conditions and restrictions. See warranty card for details.
NOTE: Check for availability and details for uniFLOW solutions.
PRODUCT LIMITED WARRANTY
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Advisory Type Service Notice
Date 04.19.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
