Canon Support for imageCLASS MF453dw | Canon U.S.A., Inc.
imageCLASS MF453dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 01.30.23
File Size 381.60 KB
Date 07.19.23
File Size 405.58 KB
Date 07.19.23
File Size 154.27 KB
Date 12.19.23
File Size 1.85 MB
Date 01.30.23
File Size 2.26 MB
Date 01.30.23
File Size 144.76 KB
Date 09.16.24
File Size 1.85 MB
Date 04.26.23
File Size 2.27 MB
Date 09.16.24
File Size 2.27 MB
Date 09.24.23
File Size 2.27 MB
Date 07.19.23
File Size 146.85 KB
Date 09.11.25
File Size 2.27 MB
Date 03.02.26
File Size 1.85 MB
Date 09.16.26
File Size 2.27 MB
Date 10.07.26
File Size 1.85 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF453dw
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS MF453dw
Products ChromeOS
imageCLASS MF453dw
imageCLASS MF453dw
MAIN UNIT
CORE FUNCTIONS
Print/Scan/Copy
ITEM CODE
5161C011
PROCESSOR
Canon Custom Processor
CONTROL PANEL
5" Color Touch Panel
MEMORY
1 GB
STANDARD INTERFACE CONNECTION
USB 2.0 High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 350 Sheets
Maximum: 900 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 250-sheet Paper Cassette, 100-sheet Multipurpose Tray
Optional: 550-sheet Paper Cassette(Cassette Unit-AH1)
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Thick, Bond
Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond,Label, Envelope (10 Envelopes)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, ExecutiveCustom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Multipurpose Tray: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DLCustom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
WARM-UP TIME
From Power On: 14 Seconds or Less
From SleepMode: 4 Seconds or Less
DIMENSIONS (W x D x H)
Standard (Desktop):17.8" x 18.3" x 15.4"(453 mm x 464 mm x 392 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 17.9" x 34.8" x 26.2" (453 mm x 883 mm x 664 mm)
Fully Configured: 17.9" x 34.8" x 31.3" (453 mm x 883 mm x 795 mm)
WEIGHT 4
Unit:Approx. 35.7 lb. (16.2 kg)
Boxed Weight:Approx. 46 lb. (20.8 kg)
OPERATING SYSTEM
UFR II/PCL/PS: Windows® 8.1/10, Windows Server 2012 R2/2016/2019, Mac OS X v10.11 (or later)
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED5
Up to 40 ppm (Letter); Up to 32.4 ppm (Legal)
FIRST PRINT OUT TIME
Approx. 5.4 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
750 - 4,000 Pages
PRINT RESOLUTION (dpi)
600 x 600 dpi
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II, PCL®6, PCL®5, Adobe PostScript 3®
DOUBLE-SIDED PRINTING
Automatic (Standard)
DIRECT PRINT
Available from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES3
Apple® AirPrint®, Canon PRINT Business, Mopria™Print Service
FONTS
PCL: 45 Fonts
PS: 136 Fonts
PRINT FEATURES
Secured Watermark, Header/Footer, Page Layout,Two-sided Printing, Mixed Paper Sizes, Orientations,Toner Reduction, Poster Printing, Print Date, Collating, Grouping, Page Border,6 Booklet Printing6
COPY SPECIFICATIONS
COPY SPEED
40 ppm (Letter)
FIRST-COPY-OUT-TIME (LETTER)
Approximately 6.2 Seconds
COPY RESOLUTION
600 x 600 dpi
COPY SIZE
Platen: Up to Letter
ADF: Up to Legal
MULTIPLE COPIES
Up to 999 Copies
MAGNIFICATION
25% - 400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
COPY FEATURES
Preset R/E Ratios by Area, Two-Sided, Density Adjustment, Original Type Selection, Two-sided Original, Sort, N on 1, Different Size Originals, Sharpness, Erase Frame, Copy ID Card, Copy Passport, Paper Settings, Favorite Settings, Cancel, Collate
SCAN SPECIFICATIONS
TYPE
Single-Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY
50 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter, Statement
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
Single and Double-sided scanning: 13-28 lb.Bond (50-105 g/m2)
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book
PULL SCAN
ScanGear MF for TWAIN, WIA, and ICA
SCAN RESOLUTION
Up to 600 x 600
SCAN TO MOBILE DEVICES
SCAN SPEED (LETTER)
Single-sided: 13/38 ipm (300 x 300 dpi) (Color/BW)
Double-sided: 26/70 ipm (300 x 300 dpi) (Color/BW)
MEMORY MEDIA
Standard USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATION
Email/Internet FAX (SMTP), SMB, FTP, Super G3 FAX
ADDRESS BOOK
LDAP (50)/Local (300)/Speed Dial (281)
SEND RESOLUTION (DPI)
300 x 300
COMMUNICATION PROTOCOL
File:FTP, SMBEmail/iFax:SMTP, POP3, iFax (Simple)
FILE FORMAT
Standard:TIFF, JPEG, PDF (Compact, Searchable)
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard:Department ID Authentication
DATA
Standard:Verify System at Startup
NETWORK
Standard:IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.11b/g/n, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENT
Standard:Secure Print, Searchable PDF
WI-FI AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS
AC 120-127 V:5.9 A, 60 Hz
POWER CONSUMPTION
Maximum:Approx. 1330 W
Standby: Approx. 10 W
Sleep Mode: Approx. 0.9 W
Typical ElectricityConsumption (TEC) Rating: 0.34 kWh
STANDARDS
ENERGY STAR® Qualified, Currently Rated EPEAT Silver2
CONSUMABLES
TONER
Cartridge 057 - Yields up to 3,100 Pages (In-box toner)
Cartridge 057 H - Yields up to 10,000 Pages
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Advisory Type
Date 03.29.15
Title Service Notice: Toner Cartridge Auto Replenishment Service (ARS) will be down for planned server maintenance
Advisory Type Service Notice
Date 03.03.23
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Date 04.19.23
Title Service Notice: Regarding Vulnerability Measure Against Buffer Overflow for Laser Printers and Small Office Multifunctional Printers
Date 02.05.24
Date 06.20.25
Title Service Notice: Regarding Remediation Measure Against Potential Buffer Overflow Vulnerability in Laser Printers and Small Office Multifunctional Printers
Date 02.23.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
