Canon Support for imageCLASS MF455dw | Canon U.S.A., Inc.
imageCLASS MF455dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.07.26
File Size 1.32 MB
Date 10.07.26
File Size 1.85 MB
Date 09.16.24
File Size 1.32 MB
Date 04.26.23
File Size 460.45 KB
Date 01.30.23
File Size 2.16 MB
Date 01.30.23
File Size 381.60 KB
Date 01.30.23
File Size 2.92 MB
Date 07.19.23
File Size 405.58 KB
Date 07.19.23
File Size 154.27 KB
Date 12.19.23
File Size 1.85 MB
Date 01.30.23
File Size 2.26 MB
Date 01.30.23
File Size 144.76 KB
Date 09.16.24
File Size 1.85 MB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 07.19.23
File Size 146.85 KB
Date 01.30.23
File Size 1.63 MB
Date 12.19.23
File Size 476.17 KB
Date 09.11.25
File Size 2.27 MB
Date 09.11.25
File Size 1.32 MB
Date 03.02.26
File Size 1.85 MB
Date 09.16.26
File Size 2.27 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF455dw
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS MF455dw
Products ChromeOS
imageCLASS MF455dw
Printer Specifications
Printer Type Black and White Laser
Print Speed Up to 40 ppm (Letter); Up to 32 ppm (Legal) Footnote3
First Print Time Approx. 5.3 Seconds
Printer Language UFR II, PCL®6, PCL®5, Adobe PostScript 3®
Print Resolution 600 x 600 (dpi)
Duplex Print Automatic (Standard)
Print Memory 1GB
Direct Print from USB Available from USB memory (JPEG, TIFF, PDF)
Copier Specifications
Copy Speed Up to 40 ppm (Letter); Up to 32 ppm (Legal)
Copy Resolution 600 x 600 (dpi)
First Copy Time Approx. 6.2 seconds
Maximum Number of Copies Up to 999 Copies
Reduction/Enlargement Preset Reductions: 25%, 50%, 64%, 78%
Preset Enlargements: 129%, 200%, 400%
Copy Size Platen: Up to Letter
ADF: Up to Legal
Copy Features Paper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
Fax Specifications
Modem Speed Super G3: 33.6 kbps
G3: 14.4 kbps
Fax Resolution 400 x 400, 200 x 400, 200 x 200, 200 x 100
Memory Capacity Up to 512 Pages
Speed Dials Max. 281
Group Dialing Max. 299 dials
Sequential Broadcasting Max. 310 Addresses
Fax Features RX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax
Memory Backup Yes
Scanner Specifications
Scan Type Single-Pass Duplexing Automatic Document Feeder
Scan Resolution 300 x 600, 600 x 600
Scan Size Legal, Letter, Statement
Duplex Scan Yes
Output File Formats Standard: TIFF, JPEG, PDF (Compact, Searchable) Optional: PDF (Encrypted, Digital Signature)
Pull Scan ScanGear MF for TWAIN, WIA, and ICA
Paper Handling Specifications
Standard Paper Source(s) 250-sheet Paper Cassette, 100-sheet Multipurpose Tray
Optional Paper Source(s) 550-sheet Paper Cassette (Cassette Unit-AH1)
Paper Output Standard: 65 Sheets
Paper Weight Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
Media Sizes Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14")
Media Types Cassettes: Thin, Plain, Recycled, Thick, Bond
Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes)
Connectivity and Software Specifications
Standard Interface(s) USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
WiFi Authentication Methods WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Mobile Functions Apple® AirPrint,® Mopria® Print Service, Canon PRINT Business
Network Management Protocols IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
OS Compatibility UFR II/PCL/PS: Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/ Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X v10.8.5 (or later)
Environmental Specifications
Power Consumption Maximum: Approx. 1330 W
Standby: Approx. 10 W
Sleep Mode: Approx. 0.9 W
Typical Energy Consumption 0.34 kWh
General Specifications
Dimensions Standard (Desktop): 17.9" x 18.3" x 15.5" (453 mm x 464 mm x 392 mm)
Unit Weight (without/with cartridge) Approx. 35.8 lb. (16.2 kg) Footnote2
Package Weight Approx. 45.9 lb. (20.8 kg) Footnote2
LCD Display 5" Color Touch-panel
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Advisory Type
Date 03.29.15
Title Service Notice: Toner Cartridge Auto Replenishment Service (ARS) will be down for planned server maintenance
Advisory Type Service Notice
Date 03.03.23
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Date 04.19.23
Title Service Notice: Regarding Vulnerability Measure Against Buffer Overflow for Laser Printers and Small Office Multifunctional Printers
Date 02.05.24
Date 06.20.25
Title Service Notice: Regarding Remediation Measure Against Potential Buffer Overflow Vulnerability in Laser Printers and Small Office Multifunctional Printers
Date 02.23.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
