Canon Support for imageCLASS MF4570dw | Canon U.S.A., Inc.
imageCLASS MF4570dw
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
Initial Setup
Setting up additional computers
Finding your Network Key/Password
Re-establishing Printer Connection After A Network Change?
Need additional information or assistance?
SELECT ERROR CODE
WINDOWS
macOS X
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Printer
Printing Method | Monochrome Laser |
Print Speed (up to) | Default Print Mode: 2-sided Black: Up to 16 ppm (2-sided, plain paper letter)10 Black: Up to 26 ppm (1-sided, plain paper letter)10 First Print Time: 6 seconds or less |
Print Resolution (Up to) | Black:Up to 600 x 600 dpi 1200 x 600 dpi quality |
Toner Compatibility (for Laser MFP) | Cartridge 128 (Yield: 2,100*) *Yield based on ISO/IEC Standard |
Paper Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
Automatic Sheet Feeder | 35-sheet5 |
Paper Weights | 16 to 43 lb. bond (cassette) 16 to 43 lb. bond (multipurpose tray) |
Output Tray Capacity | Approx. 100 sheets (face-down) |
Copier
Copy Resolution (up to) | Up to 600 x 600 dpi |
Copy Speed (up to) | Up to 26 cpm (letter) |
Zoom | 25-400% in 1% increments |
Halftones | 256 levels |
First Copy Time | Approx. 9 seconds1 Warmup Time: Approx. 13.5 seconds |
Reduction / Enlargement | 25%, 50%, 64%, 78% , 129%, 200%, 400% |
Copy Size | Platen: Up to Letter ADF: Up to Legal |
Copy Features | ID Card Copy, 2 on 1, 4 on 1, Collate, Memory Sort, Auto Background Control |
Scanner
Scanner Type | Color Contact Image Sensor (CIS) |
Max. Resolutions | Optical:Up to 600 x 600 dpi Interpolated:9600 x 9600 dpi |
Scanner Features | Rotate, Push Scan (Scan to PC), Pull Scan |
Color Depth | 24-bit |
File Format | Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP, PNG4 |
Fax
Modem Speed | Up to 33.6 Kbps (Super G3)2 |
Fax Resolution | Up to 203 x 391 dpi (super fine) |
Memory Capacity | Up to 256 pages3 |
Speed Dialing | 4 one-touch speed dials 100 coded dials |
Fax Features | Distinctive Ring Pattern Detection, Remote RX, Dual Access Fax, Auto Redial, Auto Fax Reduction |
Other Features | Memory Backup PC Fax (sending only) |
General
Other Features | USB Device 2.0 Hi-Speed6, 10/100 Base-T Ethernet (Network), IEEE802.11b/g/n (wireless)9 WiFi Access Infrastructure Mode WiFi Authentication Method Open System, Shared Key, WPA-PSK, WPA2-PSK WiFi Encryption Mode WEP (64/128 bit), TKIP, AES WPS Easy Setup Support Methods Push-button mode, PIN code mode |
OS Compatibility | Windows® 8, Windows 7, Windows Server® 2008, Windows Vista®, Windows Server 20038, Windows XP/2000, Mac® OS X 10.4.9 & up |
Software Included | Canon Drivers, Document Management & OCR Software Drivers available for download from www.usa.canon.com |
Power Consumption (approx.) | 1090W (Max) 3.5W (wired), 4W (wireless) (Energy Saver Mode) |
Dimension (W x D x H) | 15.4" (W) x 16.6" (D) x 14.6" (H) |
Weight | 25.8 lbs. (w/o cartridge) 27.4 lbs. (w/cartridge) |
Warranty | 1 year limited exchange/trade-in warranty9 (Extended warranty available) |
Canon imageCLASS MF3010/MF4570dw LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
Click Here to download the imageCLASS MF3010/MF4570dw Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
