Canon Support for imageCLASS MF4890dw | Canon U.S.A., Inc.
imageCLASS MF4890dw
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
Initial Setup
Setting up additional computers
Finding your Network Key/Password
Re-establishing Printer Connection After A Network Change?
Need additional information or assistance?
SELECT ERROR CODE
WINDOWS
macOS X
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Printer Specifications
Printer Type | Monochrome Laser |
Print Speed | Up to 16ppm (2-sided plain paper letter)1 Up to 26ppm (1-sided plain paper letter)1 |
First Print Time | 5.8 seconds or less (letter)2 |
Printer Language | UFR II LT (Host-based) |
Print Resolution | Up to 600 x 600 dpi (1200 x 600 dpi quality) |
Maximum Print Size | Up to Legal |
Duplex Print | Yes |
Print Modes | Watermark, Toner Saver, Page Composer |
Print Memory | 128 MB (Shared) |
Copier Specifications
Copy Type | Monochrome Laser |
Copy Speed | Up to 26cpm (letter) |
Duplex Copy Speed | Up to 16cpm (letter) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text, Text/Photo, Text/Photo+, Photo |
Halftones | 256 Levels |
Warm-up Time | Approximately 13.5 seconds |
First Copy Time | Approximately 8.7 seconds3 |
Recovery Time | Approximately 2 seconds |
Maximum Number of Copies | 99 copies |
Duplex Copy/Bind Time | Yes / Book, Calendar |
Reduction/Enlargement | 25%, 50%, 64%, 78%129%, 200%, 400% |
Zoom | 25 - 400% in 1% increments |
Copy Size | Platen: Up to Letter ADF: 5.5" x 5" to Legal |
Copy Features | Collate 2 on 1 4 on 1 ID Card Copy |
Copy Memory | 128 MB (Shared) |
Fax Specifications
Modem Speed | Up to 33.6 Kbps (Super G3)4 |
Fax Resolution | Up to 200 x 400 dpi (super fine) |
Transmission Time | JBIG (approx. 3 seconds) |
Memory Capacity | Up to 256 sheets5 |
Speed Dials | 4 one-touch speed dials 100 coded dials |
Group Dialing | 103 destinations |
Sequential Broadcasting | 114 destinations |
Duplex Fax | Yes |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial |
Activity Reports | Activity Result & Activity Management |
pC Fax | Sending only |
Fax Forwarding | (FAX -> FAX) |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical) 9600 x 9600 (interpolated) |
Scan Size | Platen: Up to Letter ADF: 5.5" x 5" to Legal |
Duplex Scan | Yes |
Compatibility | TWAIN, WIA |
Output File Formats | Hi-Compression PDF (Windows only), Searchable PDF (Windows only), PDF, JPEG, TIFF, BMP, PNG6 |
Scan Features | Rotate Image |
Pull Scan | USB and Network |
Push Scan (Scan to pC) | USB and Network |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet cassette plus 1-sheet multipurpose tray7 |
Document Feeder | 50-sheet duplex7 |
Paper Output | 100 sheets (face down) |
Paper Weight | 16-43 lb. bond (cassette) 16-43 lb. bond (multipurpose tray) |
Media Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
Media Types | Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope |
Envelope Capacity | 20 envelopes |
Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 Hi-Speed8, 10/100 Base-T Ethernet, 802.11 b/g/n Wireless9 |
WiFi Access Mode | Infrastructure Mode |
WiFi Authentication Methods | Open System, Shared Key, WPA-PSK, WPA2-PSK |
WiFi Encryption Modes | WEP (64/128 bit), TKIP, AES |
WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
Mobile Functions | |
Network Functions | Print, PC Fax and Scan |
Embedded Web Server (Remote UI) | Yes |
Web Browser Support for Remote UI | Microsoft Internet Explore 6.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
TCP/IP Set of Application Services | DHCP, BOOTP, RARP, Auto IP (IPv4), Bonjour( mDNS), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1 (IPv4,IPv6) |
MIB | RFC1213 (MIB-II), RFC1514 (Host Resources MIB), RFC1759 (Printer MIB), Canon MIB |
OS Compatibility | Windows® 8, Windows 7, Windows Server® 2008 R2, Windows Server® 2008, Windows Vista®, Windows Server 2003, Windows XP, Mac OS X 10.5.8 and up |
Cable Included | Power Cord (USB not included) |
Bundled Software | Printer driver, Fax driver, Scanner driver, MF Toolbox, AddressBook Tool, Presto! PageManager, SSID Tool |
Environmental Specifications
Power Consumption | Max: Approx. 1,110W During Operation: Approx. 520W Standby: Approx. 5W Energy Saver: Approx. 2.1W |
Typical Energy Consumption | 0.8kWh |
General Specifications
Dimensions | 15.4" (W) x 14.5" (D) x 14.2" (H) |
Unit Weight (without/with cartridge) | 28.2 lbs. (w/o cartridge) 29.5 lbs. (w/cartridge) |
Package Weight | Approx. 38.8 lbs. |
Cartridge Type | Cartridge 128 (Yields approximately 2,100 pages) Single Cartridge System *Yields based on ISO/IEC Standard |
LCD Display | 5-row backlit LCD |
Duty Cycle | Up to 10,000 pages per month |
Security | IP Filtering, MAC Address Filtering |
Languages | English, French, Spanish, Portuguese |
Warranty | 1 year limited exchange/carry-in warranty10 (Extended warranty available) |
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to the Canon imageCLASS Series product and accessories packaged with this limited warranty (collectively, the 'Product') when purchased and used in the United States.
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD 'AS IS' AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
Click Here to download the Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
