Canon Support for imageCLASS MF6160dw | Canon U.S.A., Inc.
imageCLASS MF6160dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.11.25
File Size 1.20 MB
Date 09.16.24
File Size 1.32 MB
Date 02.03.20
File Size 652.13 KB
Date 01.30.23
File Size 2.92 MB
Date 12.23.20
File Size 819.56 KB
Date 04.19.22
File Size 1.50 MB
Date 12.21.17
File Size 809.44 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 04.23.19
File Size 2.92 MB
Date 04.23.19
File Size 647.96 KB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 03.23.23
File Size 1.60 MB
Date 08.27.13
File Size 7.05 MB
Date 12.21.17
File Size 647.92 KB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 10.03.19
File Size 2.92 MB
Date 04.23.19
File Size 815.66 KB
Date 09.21.17
File Size 2.92 MB
Date 09.24.23
File Size 1.20 MB
Date 09.11.25
File Size 2.27 MB
Date 09.11.25
File Size 1.32 MB
Date 09.16.26
File Size 2.27 MB
Date 09.16.26
File Size 1.20 MB
Date 10.07.26
File Size 1.32 MB
Date 08.27.13
File Size 28.25 MB
Date 08.27.13
File Size 25.93 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Initial Setup
Setting up additional computers
Finding your Network Key/Password
Re-establishing Printer Connection After A Network Change?
Need additional information or assistance?
imageCLASS MF6160dw
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS MF6160dw
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 17ppm (2-sided plain paper letter)2
Up to 35ppm (1-sided plain paper letter)2
First Print Time 6 seconds or less (letter)7
Printer Language UFR II LT (Host-based), PCL6(5e,XL)
Print Resolution Up to 600 x 600 dpi
(1200 x 600 dpi quality)
Maximum Print Size Up to Legal
Duplex Print Yes
Print Modes Watermark, Toner Saver, Page Composer, Poster
Print Memory 256 MB (Shared)
Direct Print from USB JPEG, TIFF
Copier Specifications
Copy Type Monochrome Laser
Copy Speed Up to 35cpm (letter)
Duplex Copy Speed Up to 17cpm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo, Text/Photo(Quality), Photo, Text
Halftones 256 Levels
Warm-up Time Approximately 11 seconds
First Copy Time Approximately 8 seconds8
Recovery Time Approximately 5 seconds
Maximum Number of Copies 99 copies
Reduction/Enlargement 25%, 50%, 64% 78%129%, 200%, 400%
Zoom 25 - 400% in 1% increments
Copy Size Platen: Up to Letter
ADF: 5.5" x 5" to Legal
Copy Features Collate
2 on 1
4 on 1
ID Card Copy
Frame Erase
Copy Memory 256 MB (Shared)
Fax Specifications
Modem Speed Up to 33.6 Kbps (Super G3)9
Fax Resolution Up to 400 x 400 dpi (ultra fine)
Transmission Time JBIG (approx. 3 seconds)
Memory Capacity Up to 512 sheets10
Speed Dials 19 one-touch speed dials
181 coded dials
Group Dialing 199 destinations
Sequential Broadcasting 210 destinations
Duplex Fax Yes
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial
Activity Reports Activity Result & Activity Management
pC Fax Sending only
Fax Forwarding (FAX -> FAX, Email, SMB)
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical)
9600 x 9600 (interpolated)
Scan Size Platen: Up to Letter
Duplex Scan Yes
Compatibility TWAIN, WIA
Output File Formats PDF(Compact), PDF, JPEG, TIFF
Scan Features Push Scan, Pull Scan, Scan to USB
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Send Specifications
Scan to Email Scan to Email (JPEG, TIFF, PDF, Compact PDF)
Scan to SMB Scan to SMB (JPEG, TIFF, PDF, Compact PDF)
Paper Handling Specifications
Standard Paper Source(s) 250-sheet cassette plus 50 sheet multipurpose tray3
Optional Paper Source(s) 500-sheet cassette3
Document Feeder 50-sheet duplex3
Paper Output 150 sheets (face down)
Paper Weight 16-34 lb. bond (cassette)
16-43 lb. bond (multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Executive
Media Types Plain Paper, Heavy Paper, Recycled, Color, Transparency, Label, Envelope
Envelope Capacity 5 envelopes
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet, 802.11 b/g/n Wireless1
WiFi Access Mode Infrastructure Mode
WiFi Authentication Methods WPA-PSK, WPA2-PSK
WiFi Encryption Modes WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Google Cloud Print&trade;6, Apple AirPrint&trade;5
Network Functions Print, PC Fax and Scan
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI Microsoft Internet Explore 8.0 or higher, Safari 5.0.6 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services DHCP, BOOTP, RARP, Auto IP, Bonjour(mDNS), DHCPv6 (IPv6), HTTP, HTTPS, POP before SMTP (IPv4, IPv6), ARP+PING, WINS (IPv4)
Network Management Protocols SNMPv1 (IPv4,IPv6), SNMPv3 (IPv4, IPv6)
OS Compatibility Windows® 8, Windows Server® 2012, Windows 7, Windows Server 2008 R2, Windows Server 2008, Windows Vista®, Windows Server 2003, Windows® XP, Mac® OS X 10.5.8 & up
Cable Included Power Cord (USB not included)
Bundled Software Printer driver, Fax driver, Scanner driver, MF Toolbox, Presto! PageManager
Environmental Specifications
Power Consumption Max: Approx. 1,110W
During Operation: Approx. 550W
Standby: Approx. 9W
Energy Saver: Approx. 2.6W
Typical Energy Consumption 1.4kWh
General Specifications
Dimensions 15.4" (W) x 18.6" (D) x 17" (H)
Unit Weight (without/with cartridge) 40.3 lbs. (w/o cartridge)
42.1 lbs. (w/cartridge)
Package Weight Approx. 50.7 lbs.
Cartridge Type Cartridge 119 (Yields approximately 2,100 pages)
Cartridge 119II (Yields approximately 6,400 pages)
Single Cartridge System
*Yields based on ISO/IEC Standard
LCD Display 5-row backlit LCD
Duty Cycle Up to 50,000 pages per month
Department ID Management Yes, up to 300 ID's
Security IP Filtering, MAC Address Filtering,IEEE802.1x, SNMPv3, HTTPS, Secure Print, Department ID Management
Languages English, French, Spanish, Portuguese
Warranty 1 year limited exchange/carry-in warranty11 (Extended warranty available)
Canon imageCLASS MF6160dw/MF6180dw LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
Click Here to download the imageCLASS MF6160dw/MF6180dw Warranty Card.
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
