Canon Support for imagePRESS 1110+ | Canon U.S.A., Inc.
imagePRESS 1110+
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
| Model Name | imagePRESS 1110+ |
| Imaging System | Laser Electrostatic Transfer System |
| Printing Resolution | Up to 1200 x 1200 dpi |
| Halftone | 256-Level Grayscale |
| Letter | Simplex: 110 Duplex/Perfect: 55 |
| Ledger | Simplex: 68 Duplex/Perfect: 34 |
| Maximum Original Size | 13" x 19.2" |
| Standard Paper Capacity | 2,000 Sheets (20 lb. Bond) |
Acceptable Paper Weights
| Cassette | Uncoated: 14 lb. Bond to 110 lb. Bond Cover Coated: 24 lb. Bond to 90 lb. Cover |
| Duplexing | Automatic Duplex/Perfect Any Supported Stock |
| Power Requirements | 208V/30A+208V/15A |
| Dimension | (H x W x D): 54.12" x 54.62" x 31.87" |
| Weight | 1,103 lb. |
| Estimated Toner Yield | 69,000 impressions at 6% coverage (LTR pgs) |
Feeders
| Description | Color Image Reader-L1 (Opt.) (Includes DADF (Duplex Automatic Document Feeder) |
| Acceptable Originals | Statement to 11" x 17" Resolution: Up to 600 x 600 dpi, 256 Gradations |
| Scanning Speed | B/W: Up to 200 ipm (300 dpi) Up to 120 ipm (600 dpi) Color: Up to 80 ipm (300 dpi) Up to 40 ipm (600 dpi)* |
| Capacity | 300 sheets (20 lb. Bond) |
| Paper Weights | 14 lb. Bond to 120 lb. Index |
| Power Source | From Main Unit |
| Dimensions | (H x W x D): 7.12" x 23.25" x 25" |
| Weight | 81.6 lb. |
Paper Supply Options
| Description | POD Deck-C1 (Std.) |
| Paper Capacity | 4,000 Sheets (1,000 x 2 + 2,000) (20 lb. Bond) |
| Paper Sizes | 13" x 19.2" |
| Paper Weights | Uncoated: 14 lb. Bond to 110 lb. Bond Cover (All Trays) Coated: 24 lb. Bond to 90 lb. Cover (All Trays) |
| Power Source | 120-127VAC, 60Hz, 15A |
| Dimensions | 43.12" x 29.37" x 31.25" |
| Weight | 499 lb. |
| Description | POD Deck-C1 and Secondary POD Deck-C1 (Opt.)*** |
| Power Source | 120-127VAC, 60Hz, 15A x (2) |
| Dimensions | 43.12" x 61.5" x 31.25" |
| Weight | 997 lb. |
| Description | POD Deck-C1 & Sec. POD Deck-C1 (2) (Opt) *** |
| Dimensions | 43.12" x 93.62" x 31.25" |
| Weight | 1,495 lb.⟩ |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
