Canon Support for imagePRESS 1125+ | Canon U.S.A., Inc.
imagePRESS 1125+
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Main Unit Specs
Model Name imagePRESS 1125+
Imaging System Laser Electrostatic Transfer System
Printing Resolution Up to 1200 x 1200 dpi
Halftone 256-Level Grayscale
Letter Simplex: 125
Duplex/Perfect: 62
Ledger Simplex: 74
Duplex/Perfect: 37
Maximum Original Size 13 x 19.2
Standard Paper Capacity 2,000 Sheets (20 lb. Bond)
Acceptable Paper Weights
Cassette Uncoated: 14 lb. Bond to 110 lb. Bond Cover
Coated: 24 lb. Bond to 90 lb. Cover
Duplexing Automatic Duplex/Perfect
Any Supported Stock
Power Requirements 208V/30A+208V/15A
Dimension (H x W x D): 54.12 x 54.62 x 31.87
Weight 1,103 lb.
Supplies
Estimated Toner Yield 69,000 impressions at 6% coverage (LTR pgs)
Accessories
Feeders
Description Color Image Reader-L1 (Opt.) (Includes DADF (Duplex Automatic Document Feeder)
Acceptable Originals Statement to 11 x 17
Resolution: Up to 600 x 600 dpi, 256 Gradations
Scanning Speed B/W: Up to 200 ipm (300 dpi)
Up to 120 ipm (600 dpi)
Color: Up to 80 ipm (300 dpi)
Up to 40 ipm (600 dpi)*
Capacity 300 sheets (20 lb. Bond)
Paper Weights 14 lb. Bond to 120 lb. Index
Power Source From Main Unit
Dimensions (H x W x D): 7.12 x 23.25 x 25
Weight 81.6 lb.
Paper Supply Options
Description POD Deck-C1 (Std.)
Paper Capacity 4,000 Sheets (1,000 x 2 + 2,000) (20 lb. Bond)
Paper Sizes 13 x 19.2
Paper Weights Uncoated: 14 lb. Bond to 110 lb. Bond Cover (All Trays)
Coated: 24 lb. Bond to 90 lb. Cover (All Trays)
Power Source 120-127VAC, 60Hz, 15A
Dimensions 43.12 x 29.37 x 31.25
Weight 499 lb.
Description POD Deck-C1 and Secondary POD Deck-C1 (Opt.)***
Power Source 120-127VAC, 60Hz, 15A x (2)
Dimensions 43.12 x 61.5 x 31.25
Weight 997 lb.
Description POD Deck-C1 & Sec. POD Deck-C1 (2) (Opt) ***
Dimensions 43.12 x 93.62 x 31.25
Weight 1,495 lb.
Output Options
Finishers Output Trays
Description Finisher-AF1/Saddle Finisher-AF2 (Opt.)
Paper Weights Finisher: 14 lb. Bond to 110 lb. Cover
Saddle Finisher: 14 lb. Bond to 110 lb. Cover
Paper Size Stapling: Executive, Letter-R, Letter, Legal, 11 x 17
Sheet Stacking: Up to 13 x 19.2
Saddle Finisher: Letter-R, Legal, 11 x 17, 12 x 18, 13 x 19
Number Of Trays 2/3
Top Tray Up to 3,000 Sheets (20 lb. Bond)
Lower Tray 2,000 (20 lb. Bond)
Saddle Stitch Tray 30 Booklets or Limitless
Staple Positions Corner-Stapling, Double-Stapling
Stapling Capacity Up to 100 Sheets (LTR)
Max. Booklet Stapling Capacity: Up to 25 Sheets Saddle-Stitched (20 lb. only)
Power Source 120V/15A
Dimensions 46.5 x 31.25 x 35.37
Weight Finisher: 287 lb.
Saddle Finisher: 396 lb. Puncher Unit-BB1 (Option for Finisher-AF1/Saddle Finisher-AF2)
Acceptable Paper Weight: 14 lb. Bond to 73 lb. Cover
Paper Sizes
2-Hole: Legal, Letter-R
3-Hole: 11 x 17, Letter, EXE
Punch Speed: Up to 135 ppm (Depends on Speed of Marking Engine)
Weight: 6.7 lb.
Power Source: From Finisher High-Capacity Stacker-E1 (Opt.)
Offset Stack Capacity: 10,000 Sheets (Letter) (20 lb. Bond)
Top Tray Capacity: 1,000 Sheets (20 lb. Bond)
Maximum Paper Size: 13 x 19.2
Acceptable Paper Weight: 14 lb. Bond to 110 lb. Cover
Number of Units Connected at Once: Up to 2
Dimensions (H x W x D): 53.62 x 39.25 x 31.25
Weight: 463 lb.
Power Source: 120V/15ATwo-Knife Trimmer-A1 (Opt.)
Margin Trimming: Top and Bottom Trim
Trim Amount: 0.08 to 0.59
Trim Thickness: 100 Sheets
Waste Tray Capacity: 750 Sheets (Two-Sided Trimmed)
Output Tray Capacity: 30 Booklets
Dimensions (H x W x D): 21.12 x 30.37 x 41
Weight: 319 lb.
Booklet Trimmers
Description Booklet Trimmer-D1 (Opt.)
Sheet Capacity Waste Tray Capacity: 1,500 Sheets (With 0.78 Trim, 20 lb. Bond)
Margin Trimming: Fore-Edge Trim
Trim Amount: 0.08 to 0.78
Dimensions (H x W x D): 41 x 62 x 30.37
Weight: 335 lb.
Power Source: From Saddle Finisher Perfect Binder-C1 (Opt.)
Cutting Method: Stack Rotation 3-Direction or 1-Direction Cut
Finished Book Size
Width: 8 to 11.62
Length: 5.37 to 8.5
Body Paper Weight: 14 lb. Bond to 90 lb. Index
Cover Weight: 24 lb. Bond to 110 lb. Cover
Book Thickness: 10 to 200 Sheets
Glue Warm-Up Time: 440 Seconds
Trim Range: Adjustable in .0197 (0.5mm) Increments
Side: 0.26 to 1.94
Top and Bottom: 0.52 to 3.11
Dimensions (H x W x D): 51.25 x 36.97 x 31.12
Weight: 674.6 lb.
Power Source: 208V/15A
Document Inserters
Description Multi-Drawer Document Insertion Unit-A1 (Opt.)
Paper Weight 14 lb. Bond to 110 lb. Cover
Feeder Capacity 4,000 Sheets (1,000 x 2 + 2,000) (20 lb. Bond)
Dimensions (H x W x D): 43.12 x 42.5 x 31.25
Weight: 554 lb.
Power Source: 120V/15AProfessional Puncher and Integration Unit-B1 (Opt.)
Paper Size: Letter, Tab
Supported Media Weights: 20 lb. Bond to 80 lb. Cover
Productivity: Up to 135 ppm (Depends on Speed of Marking Engine)
Chip Tray Capacity: 25,000 Sheets
Punch Patterns: 3H, 5H, Velo Bind 11H, Plastic Comb, 19H, Twin Loop 21H/32H, ProClick 32H, Color Coil 44H
Dimensions (H x W x D): 41 x 22.5 x 31.25
Weight: 258.5 lb.
Paper Folding
Description Paper Folding Unit-F1 (Opt.)
Fold Type Z-fold: 11 x 17, Legal, Letter-R
C/V/Accordian Fold: Letter-R
Double Parallel Fold: Letter-R, Legal
Supported Media Weights: 14 lb. Bond to 28 lb. Bond
Dimensions (H x W x D): 46.87 x 13.25 x 31.25
Weight: 157 lb.* System Upgrade RAM-B1 required for 600 dpi color scanning
** Combined weight of the POD Deck-C1 and Secondary POD Deck-C1
*** Requires either the imagePRESS 1135+ or the imagePRESS 1125+ to connect three (3) POD Decks. Combined weight of the POD Deck-C1 and Secondary POD.
Deck-C1 (2)
890mm when the extension tray is pulled out for Saddle Finisher-AF1. 1060mm when the extension tray is pulled out for Saddle Finisher-AF2.
Only one additional High Capacity Stacker-E1 attaches to the imagePRESS 1110P.
Requires either the Finisher-AF1 or the Saddle Finisher-AF2.
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
