Canon Support for imagePROGRAF GP-200 | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 04.09.25
File Size 8.12 MB
Date 09.27.21
File Size 3.42 MB
Date 12.10.24
File Size 4.43 MB
Date 09.27.21
File Size 13.40 MB
Date 04.09.25
File Size 7.93 MB
Date 08.28.24
File Size 1.04 MB
Date 08.28.24
File Size 1.96 MB
Date 05.12.25
File Size 1.97 MB
Date 05.12.25
File Size 1.67 MB
Date 08.28.24
File Size 2.58 MB
Date 08.28.24
File Size 760.69 KB
Date 08.28.24
File Size 771.01 KB
Date 08.28.24
File Size 1.36 MB
Date 05.25.25
File Size 5.20 MB
Date 12.08.25
File Size 6.10 MB
Date 04.13.26
File Size 1.73 MB
Date 09.15.26
File Size 926.53 KB
Date 09.15.26
File Size 2.15 MB
Date 09.15.26
File Size 2.31 MB
Date 09.15.26
File Size 60.53 KB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Printer Type 5-Color plus Fluorescent Pink Ink 24-inch Printer
Number of Nozzles Total: 15,360
C, M, Y, BK, MBK, FP: 2,560 nozzles each
Nozzle Pitch 1200 dpi
Non-firing nozzle detection and compensation
Print Resolution (Up to) 2400×1200dpi (Max)
OS Compatibility Windows® 7, 8.1, 10 (32/64bit)
Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit), 2019
Macintosh OS X v10.10.5-v10.12x or later
Standard Interfaces USB 2.0 High-Speed
10/100/1000 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
Ink Droplet Size 5 picoliter
Ink Capacity 130 ml or 300 ml per color
Ink Types Pigment Ink Plus Fluorescent Pink Ink
Color Set Pigment: Matte Black, Black, Cyan, Magenta, Yellow and Fluorescent Pink Ink
Buffer Ram 2 GB (Physical)
Media Width Cut Sheet - 8”- 24”
Roll Feed - 8” - 24”
Media Thickness 0.07-0.8mm
Maximum Roll Print Length Roll Feed - 59' (18 meters)
Maximum Media Roll Diameter 5.9”
Borderless Printing Width 8, 10", 12, 14", 16 17", 20, 24”
B4 (10.12"/257 mm), A3 (11.69"/297 mm), A3+ (12.95"/329 mm), A2 (16.54"/420 mm), B2 (20.28"/515 mm), A1 (23.39"/594 mm)
Paper Feed Method Roll Feed: One Roll, Top-loading, Front Output
Cut Sheet: Top Loading, Front Output
Languages SGRaster, HPGL/2, HP-RTL, JPEG
Noise Level Approx Operation: 49 dB (A)
Standby: 35 dB (A) or less
Acoustic Power: 6.7 Bels
Physical Dimensions 42” (H) x 39” (W) x 35” (D) (Basket Open)
Weight approx. 110 lbs (roll holder included, no inks, no print heads)
Power Source AC100-240V (50-60Hz)
Power Consumption Maximum: 71 W or less
Standby 2.0 W or less
Power Off: 0.3 W or less (Compliant with Executive Order)
Operating Environment Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
User-replaceable items
  • Print Head (PF-07)
  • Maintenance Cartridge (MC-31)
  • Ink Tanks (PFI-120/PFI-320)
  • Cutter Blade (CT-08)
Software Included Quick Utility Toolbox, Accounting Manager, Device Management Console, Media Configuration Tool, PosterArtist Lite (PC only), PosterArtist (Available for purchase, PC only), Printer Driver Extra Kit (Free Layout and Advanced Preview), Direct Print Plus (PC only), Free Layout Plus (PC only)
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon") with respect to the Canon imagePROGRAF GP-200 and Canon imagePROGRAF GP-300 Large Format Printers packaged with this limited warranty and Canon branded accessories and options designed for use with these same Canon imagePROGRAF Large Format Printers (collectively, the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of two (2) years after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer.  During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty shall not extend to the Canon Printhead for the Product, for which a separate warranty is given. Nor shall this warranty cover other consumable parts or consumables, such as paper and ink cartridges, as to which there shall be no warranty or replacement.
Call: 1-800-423-2366 Monday through Friday from 8:00 a.m. to 8:00 p.m. ET
You must cooperate with Canon in remotely diagnosing the Products malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, Canon shall schedule an on-site service call by an independent authorized Canon Service Provider (the "Service Provider") or Canon will send you a replacement part for any defective user replaceable item. You will be charged at the then-current service call rates of Canon or the Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES OR CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE PRODUCT.  NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON) WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON.  THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON.  PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CONDITIONS OF WARRANTY
THIS WARRANTY APPLIES TO PRODUCTS SOLD AND USED IN THE U.S.A. AND CANADA ONLY.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
