Canon Support for imagePROGRAF TM-200 MFP L24ei | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 06.14.20
File Size 925.69 KB
Date 06.24.19
File Size 14.70 MB
Date 01.14.20
File Size 2.28 MB
Date 09.03.19
File Size 3.43 MB
Date 09.18.18
File Size 4.21 MB
Date 09.18.18
File Size 3.32 MB
Date 10.02.22
File Size 18.95 MB
Date 09.18.18
File Size 4.31 MB
Date 09.03.19
File Size 3.53 MB
Date 09.03.19
File Size 2.46 MB
Date 08.28.24
File Size 1.04 MB
Date 08.28.24
File Size 1.96 MB
Date 05.12.25
File Size 1.97 MB
Date 05.12.25
File Size 1.67 MB
Date 08.28.24
File Size 2.58 MB
Date 08.28.24
File Size 760.69 KB
Date 08.28.24
File Size 771.01 KB
Date 08.28.24
File Size 1.36 MB
Date 05.25.25
File Size 5.20 MB
Date 12.08.25
File Size 6.10 MB
Date 04.13.26
File Size 1.73 MB
Date 09.15.26
File Size 926.53 KB
Date 09.15.26
File Size 2.15 MB
Date 09.15.26
File Size 2.31 MB
Date 09.15.26
File Size 60.53 KB
Date
File Size 1.06 MB
Date 10.04.18
File Size 3.80 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Printer Type 5-Color 24-inch Printer
Number of Nozzles Total: 15,360
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
Nozzle Pitch 1,200 dpi
Non-firing nozzle detection and compensation
OS Compatibility Windows® 7, 8.1, 10 (32/64bit)
Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit)
Macintosh OS X v10.10.5-v10.12x
Standard Interfaces USB 2.0 High-Speed
10/100/1000 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
Ink Droplet Size 5 picoliter
Ink Capacity 130 ml or 300ml per color
Ink Droplet Size Pigment Ink
Color Set Pigment: Matte Black, Black, Cyan, Magenta, Yellow
Buffer Ram 2 GB (Physical)
Media Width Cut Sheet - 8"- 24"
Roll Feed - 8" - 24"
Media Thickness 0.07-0.8mm
Maximum Roll Print Length Roll Feed - 59' (18 meters)
Maximum Media Roll Diameter 5.9" (150mm)
Borderless Printing Width 8", 10", 12", 14", 16" 17", 20", 24" B4 (10.12"/257 mm), A3 (11.69"/297 mm), A3+ (12.95"/329 mm), A2 (16.54"/420 mm), B2 (20.28"/515 mm), A1 (23.39"/594 mm)
Paper Feed Method Roll Feed: One Roll, Top-loading, Front Output
Cut Sheet: Top Loading, Front Output
Languages SGRaster, HPGL/2, HP-RTL, JPEG
Noise Level Approx Operation: 44 dB (A)
Standby: 35 dB (A) or less
Acoustic Power: 6.0 Bels
Physical Dimensions 42.0" x 38" x 34"
Weight approx.112 lbs (roll holder included, no inks, no print heads)
Power Source AC-100-240V (50-60Hz)
Power Consumption Maximum: 69W or less
Standby 3.6W or less
Power Off: 0.3W or less (Compliant with Executive Order)
Operating Environment Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
User-replaceable items Print Head (PF-06)Maintenance Cartridge (MC-31)Ink Tanks (PFI-120/PFI-320)Cutter Blade (CT-08)
Software Included TM Unified Printer Driver, Accounting Manager, Apple AirPrint, Canon Print Service, Device Management Console, Direct Print & Share, Free Layout Tool, Free Layout Plus, imagePROGRAF Printer Driver for Windows®/Mac®, Media Configuration Tool, PosterArtist Lite for Windows, Optimized Driver for AutoCAD, Canon PRINT Inkjet Selphy, Easy Photo Print Editor &dagger;Scanner Type:Contact Image Sensor (CIS) technology
Scan Accuracy: +/- 0.20%
Speed:3 ips monochrome, 1 ips color (Copy, Standard Mode)
Optical Resolutions:600 dpi
Max Resolutions:600 dpi
Max. Document SizeWidth: 26 inch document width (24 inch image width)
Length:109 inch
Thickness:0.5mm
Standard Interface: (Scan to USB)USB 2.0 / (Scan to Network)Gigabit ethernet
CANON imagePROGRAF LARGE FORMAT PRINTER LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon") with respect to the Canon imagePROGRAF Large Format Printer packaged with this limited warranty and Canon branded accessories and options designed for use with the imagePROGRAF Large Format Printer (collectively, the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one (1) year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty shall not extend to the Canon Printhead for the Product, for which a separate warranty is given. Nor shall this warranty cover other consumable parts or consumables, such as paper and ink cartridges, as to which there shall be no warranty or replacement.
 Your local Service Provider; or call
 1-800-423-2366, Monday through Friday from 8:00 a.m. to 8:00 p.m. ET
You must cooperate with Canon in remotely diagnosing the Products malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, Canon shall schedule an on-site service call by an independent authorized Canon Service Provider (the "Service Provider") or Canon will send you a replacement part for any defective user replaceable item. You will be charged at the then-current service call rates of Canon or the Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON) WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATION AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CONDITIONS OF WARRANTY
Canon U.S.A., Inc. One Canon Park, Melville, NY 11747 - 3336
SUPPLIES & ACCESSORIES
