Canon Support for imagePROGRAF TM-305 MFP Z36 | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 06.14.20
File Size 925.69 KB
Date 06.24.19
File Size 14.70 MB
Date 01.14.20
File Size 2.28 MB
Date 09.03.19
File Size 3.43 MB
Date 10.02.22
File Size 21.19 MB
Date 09.18.18
File Size 4.21 MB
Date 09.18.18
File Size 3.32 MB
Date 09.18.18
File Size 4.31 MB
Date 09.03.19
File Size 3.53 MB
Date 09.03.19
File Size 2.46 MB
Date 08.28.24
File Size 1.04 MB
Date 08.28.24
File Size 1.96 MB
Date 04.15.25
File Size 60.53 KB
Date 05.12.25
File Size 1.97 MB
Date 05.12.25
File Size 1.73 MB
Date 05.12.25
File Size 1.67 MB
Date 05.12.25
File Size 2.31 MB
Date 08.28.24
File Size 2.58 MB
Date 05.12.25
File Size 2.14 MB
Date 08.28.24
File Size 760.69 KB
Date 08.28.24
File Size 771.01 KB
Date 08.28.24
File Size 1.36 MB
Date 05.25.25
File Size 5.20 MB
Date 05.12.25
File Size 922.57 KB
Date 12.08.25
File Size 6.10 MB
Date
File Size 1.06 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Printer Type 5-Color 36-inch Printer
Number of Nozzles Total: 15,360
MBK: 5,120 nozzles C, M, Y
BK: 2,560 nozzles each
Nozzle Pitch 1200 dpi
Non-firing nozzle detection and compensation
Print Resolution (Up to) 2400×1200dpi (Max)
OS Compatibility Windows® 7, 8.1, 10 (32/64bit)
Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit)
Macintosh OS X v10.10.5-v10.12x
Standard Interfaces USB 2.0 High-Speed
10/100/1000 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
Direct USB Thumb Drive Printing
Ink Droplet Size 5 picoliter
Ink Capacity 130 ml or 300ml per color
Ink Droplet Size Pigment Ink
Color Set Pigment: Matte Black, Black, Cyan, Magenta, Yellow
Buffer Ram 128 GB (2 GB Physical)
Media Width Cut Sheet - 8”- 36”
Roll Feed - 8” - 36”
Media Thickness 0.07-0.8mm
Maximum Roll Print Length Roll Feed - 59' (18 meters)
Maximum Media Roll Diameter 5.9” (150mm)
Borderless Printing Width 8, 10", 12, 14", 16 17", 20, 24", 36" B4 (10.12"/257 mm), A3 (11.69"/297 mm), A3+ (12.95"/329 mm), A2 (16.54"/420 mm), B2 (20.28"/515 mm), A1 (23.39"/594 mm), B1 (28.66"/ 728 mm), A0 (33.11"/841 mm)
Paper Feed Method Roll Feed: One Roll, Top-loading, Front Output
Cut Sheet: Top Loading, Front Output
Languages SGRaster, HPGL/2, HP-RTL, JPEG
Noise Level Approx Operation: 44 dB (A)
Standby: 35 dB (A) or less
Acoustic Power: 6.0 Bels
Physical Dimensions 42" x 51" x35"
Weight approx.134 lbs (roll holder included, no inks, no print heads)
Power Source AC100-240V (50-60Hz)
Power Consumption Maximum: 69W or less
Standby 3.6W or less
Power Off: 0.3W or less (Compliant with Executive Order)
Operating Environment Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
User-replaceable items
  • Print Head (PF-06)
  • Maintenance Cartridge (MC-31)
  • Ink Tanks (PFI-120/PFI-320)
  • Cutter Blade (CT-08)
Software Included TM Unified Printer Driver, Accounting Manager, Canon Print Service, Device Management Console, Direct Print Plus, Free Layout Tool, Free Layout Plus, imagePROGRAF Printer Driver for Windows®/Mac®, Media Configuration Tool, PosterArtist Lite for Windows, Optimized Driver for AutoCAD, Canon PRINT Inkjet Selphy, Easy Photo Print Editor
Scanner Type Contact Image Sensor (CIS) technology
Scan Accuracy +/- 0.1%
Speed 13 ips monochrome, 6 ips color
Optical Resolutions 1200dpi (Adjustable from 100 dpi to 2,400 dpi)
Max. Resolutions 9600dpi interpolated
Max. Document Size Width: 38 inch document width (36 inch image width)
Length: 315" (JPG or PDF) / 598" (TIFF)
Thickness 0.079in (1mm)
Standard Interface USB 3.0 (PC connector compatible with USB 2.0 and USB 3.0 sockets)
SUPPLIES & ACCESSORIES
