Canon Support for imagePROGRAF TX-4000 MFP T36 | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.30.17
File Size 5.69 MB
Date 01.14.20
File Size 2.28 MB
Date 10.30.17
File Size 647.86 KB
Date 09.03.19
File Size 3.43 MB
Date 07.24.19
File Size 21.24 MB
Date 10.30.17
File Size 3.43 MB
Date 02.08.22
File Size 22.36 MB
Date 09.03.19
File Size 3.53 MB
Date 09.03.19
File Size 2.46 MB
Date 08.28.24
File Size 1.04 MB
Date 08.28.24
File Size 1.96 MB
Date 04.15.25
File Size 60.53 KB
Date 05.12.25
File Size 1.97 MB
Date 05.12.25
File Size 1.67 MB
Date 05.12.25
File Size 2.31 MB
Date 08.28.24
File Size 2.58 MB
Date 05.12.25
File Size 2.14 MB
Date 08.28.24
File Size 760.69 KB
Date 08.28.24
File Size 771.01 KB
Date 08.28.24
File Size 1.36 MB
Date 05.25.25
File Size 5.20 MB
Date 05.12.25
File Size 922.57 KB
Date 04.13.26
File Size 1.73 MB
Date 07.23.19
File Size 8.90 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
SCANNER SPECIFICATIONS
SCANNER TYPEContact Image Sensor (CIS) technology
SCAN ACCURACY +/- 0.1%
SPEED 13 ips monochrome, 6 ips color
OPTICAL RESOLUTIONS
1200dpi (Adjustable from 100 dpi to 2,400 dpi)
MAX. RESOLUTIONS 9600dpi interpolated
MAX. DOCUMENT SIZE
Width: 38 inch document width (36 inch image width)
Length 315" (JPG or PDF)
598" (TIFF)
THICKNESS 0.079in (2mm)
STANDARD INTERFACE USB 3.0 (PC connector compatible with USB 2.0 and USB 3.0 sockets)
PRINTER SPECIFICATIONS
PRINTER TYPE
5-Color 44-inch Printer
NUMBER OF NOZZLES
Total: 15,360
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
NOZZLE PITCH
1200 dpi
Non-firing nozzle detection and compensation
PRINT RESOLUTION (UP TO) 2400×1200dpi (Max)
OS COMPATIABILITY
Windows® 7, 8.1, 10 (32/64bit)
Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit)
STANDARD INTERFACE
USB 2.0 High-Speed
10/100/1000 Base-T/TX
INK DROPLET SIZE 5 picoliter
INK CAPACITY 160 ml, 330ml or 700ml per color
INK TYPES Pigment Ink
COLOR SET Pigment: Matte Black, Black, Cyan, Magenta, Yellow
BUFFER / RAM 128 GB (Virtual) 2 GB (Physical)
HARD DRIVE 500 GB
MEDIA WIDTH
Cut Sheet - 8"- 44"
Roll Feed - 8" - 44"
MEDIA THICKNESS 0.07-0.8mm (2.8-31.4mil)
Roll: 0.07 - 0.8 mm (2.8 - 31.4mil)
MAX. ROLL PRINT LENGTH Roll Feed - 59' (18 meters)2
MAX. MEDIA ROLL DIAMETER 6.7" (170mm)
BORDERLESS PRINTING WIDTH (ROLL MEDIA ONLY)
8”, 10", 12”, 14", 16” 17", 20”, 24", 30”, 36", 42”, 44”
B4 (10.12"/257 mm), A3 (11.69"/297 mm), A3+ (12.95"/329 mm), A2 (16.54"/420 mm), B2 (20.28"/515 mm), A1 (23.39"/594 mm), B1 (28.66"/ 728 mm), A0 (33.11"/841 mm), B0 (40.55”/1030 mm)
PAPER-FEED METHOD
Roll Feed: One Roll, Front-loading, Front Output
Front Loading Manual Feed: One Roll, Front Output
LANGUAGES SGRaster, HPGL/2, HP-RTL, PDF, JPEG
NOISE LEVEL (APPROX.)
Operation: 51 dB (A) or less
Standby: 35 dB (A) or less
Acoustic Power: 6.9 Bels or less
PHYSICAL DIMENSIONS 46.0“ x 62.7“ x 46.8“ (Main unit and TX Stacker)
WEIGHT approx.277 lbs (roll holder included, no inks, no print heads)
POWER SOURCE AC-100-240V (50-60Hz)
POWER CONSUMPTION
Maximum: 107W or less
Standby 3.6W or less
Power Off: 0.3W or less (Compliant with Executive Order)
OPERATING ENVIRONMENT TEMPERATURE
59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
USER-REPLACEABLE ITEMS
Print Head (PF-06)
Maintenance Cartridge (MC-30)
Ink Tanks (PFI-110/PFI-310/PFI-710)
SOFTWARE INCLUDED TX Unified Printer Driver8, Accounting Manager, Canon Print Service, Device Management Console, Direct Print & Share2, Free Layout Tool, Media Configuration Tool, PosterArtist Lite for Windows, Printer Driver Extra Kit for Windows/Mac (Free Print Utility Layout, Advanced Preview), Optimized Driver for AutoCAD, Print Plug-in for Microsoft® Word/Excel/PowerPoint® for Windows, Quick Utility Toolbox
CANON imagePROGRAF TX-SERIES LARGE FORMAT PRINTER LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon") with respect to the Canon imagePROGRAF TX-3000 and TX-4000 Large Format Printers, and imagePROGRAF TX-3000 MFP T36 and TX-4000 MFP T36 devices, packaged with this limited warranty, as well as with respect to the accessories and options designed for use with such imagePROGRAF Large Format products, including the all-in-one computer and Colortrac T36 scanner integrated with the imagePROGRAF Multi-Function Printers (such printers, accessories and options are collectively referred to herein as the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of ninety (90) days after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty shall not extend to the Canon Printhead for the Product, for which a separate warranty is given. Nor shall this warranty cover other consumable parts or consumables, such as paper and ink cartridges, as to which there shall be no warranty or replacement.
  • Your local Service Provider; or call
  • 1-800-423-2366, Monday through Friday from 8:00 a.m. to 8:00 p.m. ET
You must cooperate with Canon in remotely diagnosing the Product’s malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, Canon shall schedule an on-site service call by an independent authorized Canon Service Provider (the "Service Provider") or Canon will send you a replacement part for any defective user replaceable item. You will be charged at the then-current service call rates of Canon or the Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. EXCEPT AS OTHERWISE SPECIFIED IN THIS WARRANTY, NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON) WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CONDITIONS OF WARRANTY
CANON U.S.A., INC.
One Canon Park
Melville, NY 11747
SUPPLIES & ACCESSORIES
