Canon Support for imageRUNNER ADVANCE 4525i III | Canon U.S.A., Inc.
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
image icon
Canon PRINT Business - iOS
Easily print from and scan to your iCloud accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
image icon
Canon PRINT Business - Android
Easily print from and scan to your Dropbox, Google Drive accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
imageRUNNER ADVANCE 4500 III Series Spec Sheet
MAIN UNIT
TYPE
Monochrome Laser Multifunctional
CORE FUNCTIONS
Standard: Print, Copy, Scan, Send, Store
Optional: Fax
PROCESSOR
Canon Dual Custom Processor (Shared)
CONTROL PANEL
10.1" TFT LCD WSVGA Color Touch-panel
MEMORY
3.0 GB RAM
HARD DISK DRIVE
Standard: 250 GB
Maximum: 1 TB
MIRRORING HARD DISK DRIVE
Optional (250 GB, 1 TB)
Method: Raid
INTERFACE CONNECTION
Network
Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth Low Energy
Others
Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Serial Interface, Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 1,200 Sheets
Maximum: 6,350 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: Two 550-sheet Paper Cassettes, 100-sheet Stack Bypass
Optional: Two 550-sheet Paper Cassettes (Cassette Feeding Unit-AN1), 2,450-sheet Paper Deck (High Capacity Cassette Feeding Unit-B1), 2,700-sheet Paper Deck (Paper Deck Unit-F1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Standard: 250 Sheets
Maximum: 3,350 Sheets (with External Finishers)
FINISHING CAPABILITIES
Standard: Collate, Group
With Inner Finisher: Collate, Group, Offset, Staple, Hole Punch,1 Staple-Free Staple, Staple On Demand
With External Finisher: Collate, Group, Offset, Staple, Booklet,2 Staple-Free Staple, Staple On Demand, Hole Punch3
SUPPORTED MEDIA TYPES
Paper Cassettes: Thin, Plain, Recycled, Color, Heavy, Pre-punched
Stack Bypass: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Transparency, Label, Envelope
SUPPORTED MEDIA SIZES
Paper Cassette (1): Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8")
Paper Cassette (2): 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 17")
Stack Bypass: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 17")
SUPPORTED MEDIA WEIGHTS
Paper Cassettes: 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2)
Stack Bypass: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Duplexing: 16 lb. Bond to 28 lb. Bond (60 to 105 g/m2)
WARM-UP TIME
From Power On: Approx. 24 Seconds4
From Sleep Mode: Approx. 10 Seconds5
Quick Startup Mode: Approx. 4 Seconds6
DIMENSIONS (W x D x H)
23-1/8" x 29-1/8" x 47" (587 mm x 740 mm x 1,193 mm)7
INSTALLATION SPACE (W x D x H)
Basic [With DADF (Stack Bypass and Cassette Drawers Open)]: 35" x 46-1/2" (889 mm x 1,182 mm)
Fully Configured [With ADF+Paper Deck Unit-F1+ Booklet Finisher-Y1 (Cassette Drawers Open)]: 71-3/8" x 50-3/8"
(1,811 mm x 1,280 mm)
WEIGHT
Approx. 240.3 lb. (109 kg)8
PRINT SPECIFICATIONS
PRINT SPEED
Up to 25 ppm (Letter); Up to 17 ppm (Letter-R); Up to 13 ppm (Legal); Up to 15 ppm (11" x 17")
PRINT RESOLUTION (dpi)
1200 x 1200
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT
Available from USB, Advanced Box, Remote UI, and Web Access9
SUPPORTED FILES
PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES
A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements.
FONTS
PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),10 Barcode Fonts11
PS fonts: 136 Roman
OPERATING SYSTEM 12
UFRIII: Windows Server 2008/Windows¿ 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016,
MAC OS X (10.9 or later)
PCL: Windows Server 2008/Windows 7/Server 2008 R2/Server 2012/Server 2012 R2/Windows 10/Server 2016
PS: Windows Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.9 or later)
PPD: MAC OS X (10.3.9 or later), Windows 7/Windows 8/Windows 8.1/Windows 10
PRINT FEATURES
Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Front/Back Covers, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
COPY SPEED
FIRST-COPY-OUT-TIME
As fast as 5.2 seconds
COPY RESOLUTION
Reading: 600 x 600
Printing: 2400 x 600
MULTIPLE COPIES
Up to 9,999 Copies
COPY EXPOSURE
Automatic or Manual (9 Levels)
MAGNIFICATION
25%-400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS
121%, 129%, 200%, 400%
BASIC COPY FEATURES
Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES
Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different-size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original
SCAN SPECIFICATIONS
TYPE
Standard Single Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY
Single Pass DADF-A1: 150 Sheets (20 lb. Bond)
DADF-AV1: 100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
Single Pass DADF-A1 BW Original: 13 lb. Bond to 58 lb. Cover (50 to 157 g/m2)
CL Original: 17 lb. Bond to 58 lb. Cover (64 to 157 g/m2)
DADF-AV1 BW Original: 13 lb. Bond to 34 lb. Bond (50 to 128 g/m2)
CL Original: 17 lb. Bond to 34 lb. Bond (64 to 128 g/m2)
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book, 3-Dimensional Objects [Height: Up to 2" (50mm); Up to 4.4 lb. (2 kg)]
PULL SCAN
Color Network ScanGear2 for both Twain and WIA
Supported OS: Windows 7/8.1/10 Windows Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION
600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES
A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER)
Single Pass DADF-A1 Single-sided Scanning BW: 80 ipm (300 dpi)/80 ipm (600 dpi) Color: 80 ipm (300 dpi)
Double-sided Scanning BW: 160 ipm (300 dpi)/150 ipm (600 dpi) Color: 160 ipm (300 dpi)
DADF-AV1 Single-sided Scanning BW: 70 ipm (300 dpi)/51 ipm (600 dpi) Color: 70 ipm (300 dpi)
Double-sided Scanning BW: 35 ipm (300 dpi)/25.5 ipm (600 dpi) Color: 35 ipm (300 dpi)
SEND SPECIFICATIONS
DESTINATION
Email/Internet Fax (SMTP), SMB v3.0, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional)
COLOR MODE
Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White
ADDRESS BOOK
LDAP (2,000)/Local (1,600)/Speed dial (200)
SEND RESOLUTION
COMMUICATION PROTOCOL
File: FTP (TCP/IP), SMB v3.0, WebDAV
Email: SMTP, POP3
FILE FORMAT
Standard: TIFF, JPEG, PDF Device Signature (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b, Device Signature), XPS (Device Signature, Compact, Searchable), Office Open XML (PowerPoint¿, Word)
Optional: PDF (User Signature, Trace & Smooth), XPS (User Signature)
UNIVERSAL SEND FEATURES
Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-to, Email Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES
4
MODEM SPEED
Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD
MH, MR, MMR, JBIG
RESOLUTION
400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
Statement-R to 11" x 17"
FAX MEMORY
Up to 30,000 Pages
SPEED DIALS
Max. 200
GROUP DIALS / DESTINATIONS
Max. 199 Dials
SEQUENTIAL BROADCAST
Max. 256 Addresses
MEMORY BACKUP
Yes
FAX FEATURES
Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Sender's Name (TTI), Select Line, Selecting the Telephone Line, Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED)
100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 7/8.1/10)
Concurrent Connections (Max.)
SMB:
64 WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE
Approx. 16 GB (Standard HDD)
Approx. 480 GB (1 TB HDD)
ADVANCED BOX FEATURES
Authentication for Advanced Box Log-in, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA
Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Universal Login Manager, uniFLOW Online Express,13 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in
Optional: uniFLOW
DATA
Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control 14
Optional: Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK
Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENT
Standard: Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle¿ Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signatures
Optional: User Signatures, Document Scan Lock
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86ºF
Humidity: 20 to 80% RH (Relative Humidity)
POWER REQUIREMENTS
120-127 V AC, 60 Hz, 7A
PLUG (MAIN UNIT)
NEMA 5-15P
POWER CONSUMPTION
Maximum: Approx. 1,500 W
Standby: Approx. 38 W15
Sleep Mode: Approx. 0.9 W16
Typical Electricity Consumption (TEC) Rating: 0.32 kWh*
STANDARDS
ENERGY STAR¿ Certified
Rated EPEAT¿ Gold17
CONSUMABLES
TONER
GPR-57 Toner BK
TONER YIELD (ESTIMATED @ 6% COVERAGE)
Black: 42,100 Images
FOOTNOTES
  1. Requires the optional Inner 2/3 Hole Puncher-C1.
  2. Booklet Finisher-Y1 only.
  3. Requires the optional 2/3 Hole Puncher Unit-A1.
  4. Time from device power-on, until copy ready (not print reservation).
  5. Time from exiting Sleep Mode to when printings is operational.
  6. Time from device power-on to when key orientations can be performed on the touch panel display.
  7. Includes Main Unit, Single Pass DADF-A1, and Cassette Feeding Unit-AN1.
  8. Includes Main Unit, Single Pass DADF-A1, Cassette Feeding Unit-AN1, and consumables.
  9. PDF print from Web sites is supported.
  10. Requires the optional PCL International Font Set-A1.
  11. Requires the optional Barcode Printer Kit-D1.
  12. Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  13. No charge for this solution; however activation is required.
  14. Requires Unified Firmware Platform v3.9.
  15. Reference Value (measured one unit).
  16. 0.9 W sleep mode not available in all circumstances due to certain settings.
  17. For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
* Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
