Canon Support for imageRUNNER ADVANCE 4535i | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
| Model Name | imageRUNNER ADVANCE 4535i |
| Type | Monochrome Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | 10.1" TFT LCD WSVGA Color Touch-panel |
| Imaging System | Canon Dual Custom Processor (Shared) |
| Image Server Memory | 3.0 GB RAM |
| Hard Disk Drive | Standard: 250 GB Maximum: 1 TB |
| Mirroring Hard Disk Drive | Optional (250 GB, 1 TB) Method: Raid1 |
| Network Interface Connection | Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) Optional: NFC, Bluetooth |
| Other Interface | Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
| Scanning Resolution | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi |
| Printing Resolution | 1200 dpi x 1200 dpi |
| Warm Up Time | From Power On: 24 Seconds or Less From Deep Sleep Mode: 10 Seconds or Less Quick Startup Mode: 4 Seconds4 |
| Power Requirements | 120-127 V AC, 60 Hz, 9.3A |
| Power Consumption | Maximum Approx. 1.5 kWh Standby: Approx. 38 W Sleep Mode: Approx. 0.9 W11 Typical Electricity Consumption (TEC) Rating: 1.8 kWh |
| Plug | NEMA 5-15P |
| Dimension | 23-1/8" x 29-1/8" x 47" (587 mm x 740 mm x 1,193 mm)5 |
| Installation Space | Basic [With ADF (Stack Bypass and Cassette Drawers Open)]: 35" x 46-1/2" (889 mm x 1,182 mm) Fully Configured [With ADF+Paper Deck Unit-F1+ Booklet Finisher-Y1 (Cassette Drawers Open)]: 71-3/8" x 50-3/8" (1,811 mm x 1,280 mm) |
| Weight | Approx. 240.7 lb. (109.2 kg)6 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original |
Advanced Box
| Available Disk Space | Approx. 16 GB (Standard HDD) Approx. 480 GB (1 TB HDD) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
Memory Media
| Standard | USB |
Copy/Print Speed (BW/Color)
| Letter | Up to 35 ppm |
| Letter R | Up to 32 ppm |
| Legal | Up to 25 ppm |
| Ledger | Up to 22 ppm |
Copy Specifications
| First Copy Time | (Letter): As fast as 3.8 seconds |
| Multiple Copies | Up to 999 copies |
| Copy Exposure | Automatic or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
| Standard Paper Capacity | (LTR, 20 lb. Bond): 1,180 Sheets |
| Optional | (LTR, 20 lb. Bond): Two 550-sheet Paper Cassettes (Cassette Feeding Unit-AN1), 2,450-sheet Paper Deck (High Capacity Cassette Feeding Unit-B1), 2,700-sheet Paper Deck (Paper Deck Unit-F1) |
| Manual Bypass | 80-sheet Stack Bypass |
| Maximum Paper Capacity | (LTR, 20 lb. Bond): 6,330 Sheets |
| Output Paper Capacity | (LTR, 20 lb. Bond): Standard: 250 Sheets Maximum: 3,350 Sheets (with External Finishers) |
Output Sizes
| Cassette | Paper Cassette (1): Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8") Paper Cassette (2): 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8") |
| Bypass | 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 17") |
Acceptable Paper Weights
| Cassette | 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2) |
| Bypass | 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
Duplexing
| Duplexing | 16 lb. Bond to 28 lb. Cover (60 to 105 g/m2) |
| Toner | GPR-57 Toner BK |
| Estimated Toner Yield | (Estimated @ 6% Coverage): 42,100 Copies |
next to your download
