Canon Support for imageRUNNER ADVANCE 500iF | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Model Name imageRUNNER ADVANCE 500iF
Type Color Digital Multifunction Imaging System
Functions Copy, Print (UFR II, PCL 5e/6, Adobe® PostScript® 3&trade;),Fax (Up to 2 Lines), Scan, Send, Store
Operation Panel 7" WVGA Full-Color, TFT Screen
Image Server Memory Standard: 1.5GB RAM
Maximum: 1.5GB RAM
Hard Disk Drive Standard: 80GB
Maximum: 80GB
Network Interface Connection Ethernet 10/100 Base-TX, Ethernet 1000 Base-TX
Other Interface USB 2.0 X3 (Host), USB 2.0 (Device)
Special Media Support Plain 1 [17 lb. Bond to 21 lb. Bond (64 to 80g/m2)], Plain 2 [22 lb. Bond to 24 lb. Bond (81 to 90g/m2)], Recycled [17 lb. Bond to 21 lb. Bond (64 to 80g/m2)], Color [17 lb. Bond to 24 lb. Bond (64 to 90g/m2)], Heavy 1 [25 lb. Bond to 28 lb. Bond (91 to 105g/m2)], Heavy 2 [29 lb. Bond to 34 lb. Bond (106 to 128g/m2)], Transparency [40 lb. Bond to 67 lb. Cover (151 to 181g/m2)]**, Pre-punched [20 lb. Bond to 21 lb. Bond (75 to 80g/m2)], Bond [20 lb. Bond to 24 lb. Bond (75 to 90g/m2)], Labels [40 lb. Bond to 67 lb. Cover (151 to 181g/m2)], Envelope
Warm Up Time From Power On: 34 Seconds
From Sleep Mode: 10 Seconds or Less
Quick Startup Mode: Within 7 Seconds or Less***
Power Requirements 120V AC, 60Hz
Power Consumption Maximum: 1.5 kW
Sleep Mode: 1 W
Plug 10.5A
Dimension 24-7/8" x 22-1/8" x 22-3/8" (633mm x 560mm x 567mm)
Installation Space Without Staple Finisher-R1: 34-3/4" x 40-7/8" (881mm x 1035mm)
With Staple Finisher-R1: 50-1/4" x 40-7/8" (1276mm x 1035mm)
Weight Approximately 107 lb. (48.7kg)&Delta;
Basic Copy Features Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel, Standard Keys, Reset, Job Duration Display, Reserved Copying, ID Management, Counter Check
Special Copy Features ID Card Copy, Shift, Frame Erase, Scan Image Check, Mode Memory, Recall, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date
Environmental Features ENERGY STAR® Qualified RoHS Compliant Blue Angel EPEAT® Rated WEEE Directive
Advanced Box
Advanced Box Features Store To Remote Advanced Box:&diams; Supported
Print/View from Remote Advanced Box:&diams; Supported
Memory Media
Standard USB Memory
Scan Specifications
Network TWAIN Scan Standard
Network Scan Utility Color Network ScanGear
Copy/Print Speed (BW/Color)
Letter (BW): Up to 52/52 ppm
Legal (BW): Up to 43/43 ppm
Copy Specifications
First Copy Time (Letter): 5 Seconds or Less
Multiple Copies 1 to 999
Copy Exposure Automatic or Manual (9 Levels)
Magnification 25 - 400% (1% Increments) from Platen Glass
25 - 200% (1% Increments) from Document Feeder
Preset Reductions 78%, 73%, 64%, 50%, 25%
Preset Enlargements 400%, 200%, 129%
Standard Paper Capacity (20 lb. Bond): 550-sheet Paper Cassette
100-sheet Stack Bypass
Optional (20 lb. Bond): 550-sheet Paper Cassette (Up to 3)
Maximum Paper Capacity (20 lb. Bond): 2,300 Sheets
Output Paper Capacity (20 lb. Bond): Standard: 250 Sheets
Maximum: 500 Sheets (with Staple Finisher-R1)
Output Sizes
Cassette LGL, LTR, STMT, EXEC, Custom size 5-1/2" x 8-1/4" to 8-1/2" to 14" (139.7mm x 210mm to 216mm x 355.6 mm), and Envelopes (COM10, Monarch, DL, ISO-C5)*
Bypass LGL, LTR, STMT, EXEC, Custom size [3-7/8" x 5-1/2" to 8-1/2" x 14" (99mm x 139.7mm to 216mm x 355.6mm)], and Envelopes (COM10, Monarch, DL, ISO-C5)
Other Option Envelope Feeder Attachment (COM10, Monarch, DL, ISO-C5)*
Acceptable Paper Weights
Cassette 17 lb. Bond to 28 lb. Bond (64 to 105g/m2)
Bypass 17 lb. Bond to 34 lb. Bond (64 to 128g/m2)
Duplexing
Duplexing Standard Automatic Trayless Duplexing
Paper Size Statement to Legal
Paper Weight Up to 34 lb. Bond (128g/m2)
Image Reader
Scan Resolution Up to 600 x 600 dpi
Acceptable Originals (Glass): Sheet, Book, 3-Dimensional Objects [up to 4.4 lb. (2kg)]
Maximum Original Size Legal (8-1/2" to 14")
Security Features
Standard Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), Send to Myself (only), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, IEEE 802.1x (wired/wireless), SMTP Authentication, POP Authentication before SMTP, HDD Initialize (Up to 9x) HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration
Optional HDD Encryption, Encrypted Secure Print, Encrypted PDF, Secure Watermark, IEEE 2600.1 Common Criteria Certification&diams;&diams;
Estimated Toner Yield 15,200 Copies/Bottle (Estimated @ 6% Coverage)
Feeders
Description Document Feeder
Acceptable Originals Legal, Letter, Statement
Scan Method Duplexing Automatic Document Feeder
Scanning Speed (BW/Color; Letter): Simplex: 52 ipm (600 dpi)/52 ipm (300 dpi)
Duplex: 33 ipm (600 dpi)/33 ipm (300 dpi)
Capacity (20 lb. Bond): 100 Sheets
Paper Weight One-sided scanning: 11 lb. Bond to 34 lb. Bond (42 to 128g/m2), Two-sided scanning: 13 lb. Bond to 34 lb. Bond (50 to 128g/m2)
Paper Supply Options
Description Cassette Module-AA1
Paper Capacity 550 Sheets [20 lb. Bond (80g/m2)]
Paper Size LGL, LTR, STMT, EXEC, Custom size [5-1/2" x 8-1/4" to 8-1/2" x 14" (139.7mm x 210mm to 216mm x 355.6mm)]
Paper Weight 17 lb. Bond to 28 lb. Bond (64 to 105g/m2)
Power Source From the Main Unit
Power Consumption Approximately 20W
Dimensions 4-3/4" x 21-1/4" x 19-3/4" (248mm x 565mm x 650mm)
Weight Approximately 17 lb. (7.7kg)
Description Envelope Cassette-E1
Paper Capacity 50 sheets
Paper Size COM10, Monarch, DL, ISO-C5Feeding Speed: 12 cpm
Dimensions 3-1/4" x 21-1/4" x 18-7/8" (96mm x 54 mm x 480mm)
Weight Approximately 5.5 lb. (2.5kg)
Title Canon Support | Feature Notice: 2600.1 Security Kits Update
Advisory Type
Date 03.19.15
Title Canon Support | Service Notice: NFC function with the Canon PRINT Inkjet / SELPHY App Version 2.7.0 or Later for Android Will Be Discontinued for Select Models.
Advisory Type
Date 06.03.14
SUPPLIES & ACCESSORIES
