Canon Support for imageRUNNER ADVANCE 525iFZ II | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE 715iF II Series Spec Sheet
imageRUNNER ADVANCE 525iFZ II | |
| MAIN UNIT | |
| TYPE | Monochrome Laser Multifunction |
| CORE FUNCTIONS | Print, Copy, Scan, Send, Fax |
| PROCESSOR | Canon Dual Custom Processor (Shared) |
| CONTROL PANEL | 10.1" WSVGA Color Touch-panel |
| MEMORY | 3.0 GB RAM |
| HARD DISK DRIVE | Stan250 GB |
| INTERFACE CONNECTION | Network: 1000Base-T/100Base-TX/10Base-T,Wireless LAN (IEEE 802.11 b/g/n) Optional: NFC, Bluetooth Others Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host),USB 2.0 x1 (Device) Optional: Copy Control Interface |
| PAPER CAPACITY (LTR, 20LB BOND) | Standard: 650 Sheets Maximum: 3,200 Sheets |
| PAPER SOURCES (LTR, 20LB BOND) | Standard: 550-sheet Paper Cassette, 100-sheet StackBypass Optional: 550-sheet (CASSETTE FEEDING UNIT-AR1),2,550-sheet (HIGH CAPACITY CASSETTEFEEDING UNIT-D1), 550-sheet (CASSETTEMODULE-AG1), 75-envelope (ENVELOPECASSETTE MODULE-A1) |
| PAPER OUTPUT CAPACITY (LTR, 20LB BOND) | 1,000 Sheets (Base tray 500 + Upper tray400 + Lower tray 100 Sheets) |
| FINISHING CAPABILITIES | Collate, Group, Offset, Staple |
| SUPPORTED MEDIA TYPES | Cassette (Std.): Thin, Plain, Recycled, Color, Heavy,Labels, Bond, Pre-punchedStack Bypass: Thin, Plain, Recycled, Color, Heavy,Transparency, Bond, EnvelopeCassette Feeding Unit-AR1 (Optional):Thin, Plain, Recycled, Color, Heavy, Labels,Bond, Pre-punched High Capacity Cassette Feeding Unit-D1 (Optional):Upper: Thin, Plain, Recycled, Heavy, Color, Labels,Bond, Pre-punchedLower: Thin, Plain, Recycled, Heavy, Color, Bond,Pre-punchedCassette Module-AG1 (Optional):Thin, Plain, Recycled, Heavy, Color, Labels,Bond, Pre-punched |
| SUPPORTED MEDIA SIZES | Cassette (Std.): Letter, Executive, Statement, Custom size(3-7/8" x 5-7/8" to 8-1/2" x 11-3/4") Stack Bypass: Legal, Letter, Executive, Statement,Envelope [No.10 (COM10), Monarch,DL, ISO-C5], Custom size (3" x 5" to8-1/2" x 14") Cassette Feeding Unit-AR1 (Optional):Legal, Letter, Executive, Statement,Custom size: 3-7/8" x 5-7/8" to 8-1/2" x 14" High Capacity Cassette Feeding Unit-D1 (Optional) Upper: Legal, Letter, Executive, Statement,Custom size: 3-7/8" x 5-7/8" to 8-1/2" x 14" Lower: Legal, Letter-RCassette Module-AG1 (Optional):Legal, Letter, Executive, Statement,Custom size: 3-7/8" x 5-7/8" to 8-1/2" x 14"Envelope Cassette Module-A1:No.10 (COM10), Monarch, DL, ISO-C5 |
| SUPPORTED MEDIA WEIGHTS | Cassettes: 16 lb. Bond to 36 lb. Bond (60 to 135 g/m2) Stack Bypass: 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2) Duplex: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) |
| PRINT / COPY SPEED (BW AND COLOR) | Up to 55 ppm (Letter) Up to 45 ppm (Legal) |
| WARM-UP TIME | From Power On: 30 Seconds1 From SleepMode: 10 Seconds Quick StartupMode: 4 Seconds2 |
| DIMENSIONS (W X D X H) | 20-1/4" x 23-5/8" x 32-1/8”(514 mm x 600 mm x 816 mm) |
| Dimensions (W x D x H) with Paper Feeding Unit orHigh Capacity Paper Feeding | 25-1/4" x 26-3/8" x 50”(641 mm x 670 mm x 1270 mm) |
| INSTALLATION SPACE (WXD) | 41-3/8" x 32-3/8" (1,052 mm x 823 mm) |
| WEIGHT3 | Approx. 101.4 lb. (46 kg) |
| PRINT SPECIFICATIONS | |
| PRINT RESOLUTION (dpi) | 1200 x 600 |
| STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
| DIRECT PRINT | Available from USB, Advanced Box, Remote UI,and Web Access4 |
| SUPPORTED FILE TYPES | PDF, TIFF, JPEG, EPS, XPS |
| PRINTING FROM MOBILE AND CLOUD | A range of software and MEAP-based solutions areavailable to provide printing from mobile devices orInternet-connected devices and cloud-based servicesdepending on your requirements.5 |
| FONTS | PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts,Andalé Mono WT J/K/S/T (Japanese,Korean, Simplified and Traditional Chinese),6Barcode Fonts7 PS fonts: 136 Roman |
| OPERATING SYSTEM8 | UFRII/PS: Windows® 7/8.1/10, Windows Server2008/2008 R2/2012/2012 R2/2016,MAC OS X (10.7 or later) PCL: Windows® 7/8.1/10, Windows Server2008/2008 R2/2012/2012 R2/2016 |
| PRINT FEATURES | Suspend Job Timeout, Secured Print, Encrypted SecurePrint, Watermark, Erase Frame, Header/Footer, PageLayout, Two-sided Printing, Collating, Booklet Printing,Grouping, Mixed Paper Sizes/Orientations, Offsetting,Printing on Transparencies, Toner Reduction, PosterPrinting, Job hold printing |
| COPY SPECIFICATIONS | |
| FIRST-COPY-OUT TIME (LETTER) | As fast as 5 Seconds |
| Copy Resolution (dpi) | Reading: 600 x 600 Printing: 2400 x 600 |
| MULTIPLE COPIES | Up to 999 Copies |
| COPY EXPOSURE | Automatic or Manual (9 Levels) |
| MAGNIFICATION | 25%-400% (1% Increments) |
| PRESET REDUCTIONS | 25%, 50%, 64%, 78% |
| PRESET ENLARGEMENTS | 129%, 200%, 400% |
| BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, PaperSetting, Previous Settings, Favorite Settings, Finishing, Two sided,Density Adjustment, Exposure Adjustment, OriginalType Selection, Interrupt Mode, Setting Confirmation/Cancel |
| SPECIAL COPY FEATURES | Two-sided Original, Finishing, Job Build, N on 1, Different SizeOriginals, Density Adjustment, Original Type Selection, PageNumbering, Copy Set Numbering, Sharpness, Erase Frame,Secure Watermark, Print Date, Shift, Job Done Notice, CopyID Card, Skip Blank Pages, Multi Sheet Feed Detection |
| SCAN SPECIFICATIONS | |
| TYPE | Single-pass Duplexing Automatic Document Feeder |
| DOCUMENT FEEDER PAPER CAPACITY | 100 Sheets (20 lb. Bond) |
| DOCUMENT FEEDER SUPPORTED MEDIA SIZES | Legal, Letter, Statement, and Custom size (4-1/8" x 5-7/8"to 8-1/2" x 14") |
| DOCUMENT FEEDER SUPPORTED MEDIA WEIGHT | BW Original: 42 to 128 g/m2CL Original: 64 to 128 g/m2 |
| PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Height up to 1-1/4";Weight Up to 4.4 lb. (2 kg)] |
| PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS: Windows 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016 |
| SCAN RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200,200 x 100, 150 x 150, 100 x 100 |
| SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning tomobile devices or cloud-based services depending onyour requirements.1 |
| SCAN SPEED (LETTER) | Single-sided Scanning(Color/BW):50/50 ipm (300 dpi);(Color/BW) 30 ipm/50 ipm (600 dpi) Double-sided Scanning(Color/BW): 100/100 ipm (300 dpi);(Color/BW) 50 ipm/100 ipm (600 dpi) |
| SEND SPECIFICATIONS | |
| DESTINATION | Email/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box,Super G3 Fax, IP Fax (Optional) |
| COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White |
| ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed Dial (200) |
| SEND RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200,200 x 100, 150 x 150, 100 x 100 |
| COMMUICATION PROTOCOL | File: FTP, SMB v3.0, WebDAV E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full) |
| FILE FORMAT | Standard: TIFF, JPEG, PDF (Compact, Searchable,Apply Policy, Optimize for Web, PDF A/1-b,Encrypted), XPS (Compact, Searchable),Office Open XML (PowerPoint®, Word), PDF/XPS (Digital Signature) Optional: PDF (Trace & Smooth), PDF/XPS(User Signature) |
| UNIVERSAL SEND FEATURES | Original Type Selection, Two-sided Original, Different-sizeOriginals, Density Adjustment, Sharpness, Erase Frame,Job Build, Sender's Name (TTI), Direct Send, Delayed Send,Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-To, Email Priority, TX Report, Original ContentOrientation, Skip Blank Originals, Multi Sheet Feed Detection |
| FAX SPECIFICATIONS | |
| MAXIMUM NUMBER OF CONNECTION LINES | One |
| MODEM SPEED | Super G3: 33.6 KbpsG3: 14.4 Kbps |
| COMPRESSION METHOD | MH, MR, MMR, JBIG |
| RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
| SENDING / RECORDING SIZE | Statement to Legal |
| FAX MEMORY | Up to 30,000 Pages |
| SPEED DIALS | Max. 200 |
| GROUP DIALS / DESTINATIONS | Max. 199 Dials |
| SEQUENTIAL BROADCAST | Max. 256 Addresses |
| MEMORY BACKUP | Yes |
| FAX FEATURES | Original Type Selection, Two-sided Original, Density forScanning, Sharpness, Erase Frame, Job Build, Specifyingthe Sender's Name (when sending fax), Sender's Name (TTI),Selecting the Telephone Line (when sending fax), Direct Send,Delayed Send, Preview, Job Done Notice, TX Report, MultiSheet Feed Detection |
| STORE SPECIFICATIONS | |
| MAIL BOX (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential FaxIn-boxes, 30,000 Maximum Pages Stored |
| ADVANCED BOX | Communication Protocol: SMB or WebDAV SupportedClient PC: Windows (Windows 7/8.1/10) Concurrent Connections (Max.) SMB: 64 WebDAV: 3 (Active Sessions) |
| ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB |
| ADVANCED BOX FEATURES | Disabling Advanced Box, Authentication for Advanced BoxLog-in, Sort Function, Printing a PDF File with a Password,imageWARE Secure Audit Manager Support |
| MEMORY MEDIA | Standard: USB |
| SECURITY SPECIFICATIONS | |
| AUTHENTICATION | Standard: Universal Login Manager (Deviceand Function Level Log-in), UserAuthentication, Department ID,Authentication, Access ManagementSystem, uniFLOW Online Express9 Optional: uniFLOW and uniFLOW Online |
| DATA | Standard: Trusted Platform Module (TPM), Hard DiskPassword Lock, Hard Disk Drive Erase, MailBox Password Protection, Hard Disk DriveEncryption (FIPS140-2 Validated) Optional: Data Loss Prevention (Requires uniFLOW) |
| NETWORK | Standard: IP/Mac Address Filtering, IPsec, TLSEncrypted Communication, SNMP V3.0, IEEE802.1X, IPv6, SMTP Authentication, POPAuthentication before SMTP |
| DOCUMENT | Standard: Encrypted Secure Print, Adobe LiveCycle¿Rights Management ES2.5 Integration,Encrypted PDF, Device Signature, SecureWatermark Optional User Signature |
| ENVIRONMENTAL SPECIFICATIONS | |
| OPERATING ENVIRONMENT | Temperature: 50 to 86 ºFHumidity: 20 to 80 % RH (no condensation) |
| POWER REQUIREMENTS | 120-127V AC 60 Hz, 9.7 A |
| PLUG (MAIN UNIT) | NEMA 5-15P |
| POWER CONSUMPTION | Maximum: Approx. 1.5 kWh Standby: Approx. 29.77 W Sleep Mode: Approx. 0.41 W10 Typical Electricity Consumption (TEC) Rating: 2.1 kWh |
| STANDARDS | ENERGY STAR® Certified Rated EPEAT® Gold11 |
| CONSUMABLES | |
| TONER | T03 Black (All-In-One Toner Cartridge)12 |
| TONER YIELD (ESTIMATED @ 5% COVERAGE)13 | 51,500 Images |
| FOOTNOTES | |
| 1 Time from device power-on until copy ready(not print reservation). 2 Time from device power-on to when copy icon appearson the main menu of touch-panel. 3 Includes consumables. 4 PDF print from Web sites is supported. 5 For more information, including compatibility, pleasevisit https://www.usa.canon.com/mobile-app. 6 Requires the optional PCL International Font Set-A1. 7 Requires the optional Barcode Printer Kit-D1. 8 Other operating systems and environments includingAS/400, UNIX, Linux and Citrix may be supported. Someof these solutions are chargeable. SAP Device Types areavailable via the SAP Market Place. For more information,contact your sales representative.9 No charge for this solution; however activation is required. 10 0.41 W sleep mode not available in all circumstancesdue to certain settings. 11 For current EPEAT rating (Gold/Silver/Bronze),please visit www.epeat.net. 12 Includes toner, drum, developer, and waster toner hopper. 13 Toner cartridge yield in accordance with ISO/IEC 19752. | |
next to your download
