Canon Support for imageRUNNER ADVANCE 6255 | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
imageRUNNER ADVANCE 6200 Srs Setup Guide
SELECT ERROR CODE
| Model Name | imageRUNNER ADVANCE 6255 |
| Type | Monochrome Digital Multifunction Imaging System Letter: Up to 55 ppm Legal/11" x 17": Up to 39/32 ppm |
| Functions | Standard: Copy, Print (UFR II), Scan, Send, Store Optional: Print (PCL 5e/6, Adobe® PostScript® 3 ™), Fax (Up to 4 Lines) |
| Operation Panel | Standard: 8.4" SVGA Full-Color, TFT Screen Optional: 10.4" SVGA Full-Color, TFT Upright Screen |
| Image Server Memory | Standard: 1.5GB RAM Maximum: 2GB RAM |
| Hard Disk Drive | Standard: 160GB Maximum: 1TB |
| Mirroring Hard Disk Drive | Optional (160GB, 1TB), Method: RAID1 |
| Network Interface Connection | Standard: 10Base-T/100Base-TX/1000Base-T Optional: Wireless LAN (IEEE 802.1x via third-party adapter) |
| Other Interface | Standard: USB 2.0 (Host) x2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) x2], Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes |
| Max Pages Stored | 20,000 Maximum Pages Stored |
| First Copy Time | 3.3 Seconds or Less (Letter) |
| Standard Paper Capacity | (20 lb. Bond) Standard: Dual 1,500-sheet Paper Drawers, Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass |
| Optional | 3,500-sheet Paper Deck Unit-A1 or 3,500-sheet Paper Deck Unit-D1 |
| Maximum Paper Capacity | 7,700 Sheets (w/Paper Deck Unit Option) |
| Output Paper Capacity | (20 lb. Bond) Standard: 250 Sheets (w/Copy Tray) Maximum: 4,000 Sheets (w/Staple Finisher or Booklet Finisher) |
| Warm Up Time | From Power On: 30 Seconds or Less, From Sleep Mode: 30 Seconds or Less, Quick Startup Mode: 7 Seconds* |
| Power Requirements | 120-127V AC, 60Hz, 16A |
| Power Consumption | Maximum: 1.92kW Sleep Mode: 0.9W or Less |
| Plug | NEMA 5-20P |
| Dimension | Without the Upright Control Panel: 48" x 25-3/8" x 30-3/8" (1220mm x 645mm x 770mm) With the Upright Control Panel (To the right edge of the Upright Control Panel in the right-most position): 49-1/4" x 53-3/8" x 30-3/8" (1252mm x 1481mm x 770mm) |
| Installation Space | Without the Upright Control Panel: 53-5/8" x 30-3/8" (1362mm x 770mm) With the Upright Control Panel: 74-7/8" x 30-3/8" (1901mm x 770mm) |
| Weight | Approx. 516 lb. (234kg)** |
| Basic Copy Features | First-Copy-Out Time (Letter): 3.3 Seconds or Less Multiple Copies: 1 to 9,999 Copy Exposure: Automatic or Manual (9 Levels) Magnification: 25% - 400% (1% Increments) Preset Reductions: 25%, 50%, 64%, 73%, 78% Preset Enlargements: 121%, 129%, 200%, 400% Basic Copy Features: Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying |
| Special Copy Features | Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different-size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox, Cascade Copy |
| Environmental Features | EPEAT® Registered ENERGY STAR® Qualified EU RoHS Compliant Ecomark Blue Angel WEEE Directive |
Advanced Box
| Available Disk Space | Approx. 15GB (Standard HDD) Approx. 629GB (1TB HDD) |
| Common Protocol | SMB or WebDAV |
| Supported Client PC | Windows (Windows 2000/XP/7/Windows Vista) |
| Max. Number of Concurrent Connections | SMB: 32, WebDAV: 12 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
Memory Media
| Standard | USB Memory |
| Optional | SD, SDHC, CompactFlash, Memory Stick, Microdrive |
Scan Specifications
| Network TWAIN Scan | Standard |
| Network Scan Utility | Color Network ScanGear |
Output Sizes
| Cassette | 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 19-1/4") |
| Bypass | 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4" x 5-7/8" to 11-3/4" x 19-1/4") |
Acceptable Paper Weights
| Cassette | 14 lb. Bond to 80 lb. Cover (52 to 220g/m2) |
| Bypass | 14 lb. Bond to 140 lb. Index (52 to 256g/m2) |
Duplexing
| Paper Size | Standard Automatic Trayless Duplexing (Up to 11" x 17") |
| Paper Weight | 14 lb. Bond to 80 lb. Cover (52 to 220g/m2) |
| Special Media Support | Thin [14 lb. Bond to 16 lb. Bond (52 to 63g/m2)], Plain [17 lb. Bond to 24 lb. Bond (64 to 90g/m2)], Heavy 1 [25 lb. Bond to 66lb. Cover (91 to 180g/m2)], Heavy 2 [67 lb. Cover to 80 lb. Cover (181 to 220g/m2)], Heavy 3 [82 lb. Cover to 140 lb. Index (221 to 256g/m2)], Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Letterhead, Tab |
Image Reader
| Scan Resolution | Up to 600 x 600 dpi |
| Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2kg)] |
| Maximum Original Size | Up to 11" x 17" |
Security Features
| Standard | Department ID Management, Single Sign-On H, Access Management System (Device and Function Level Log-in), Secure Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, IPsec, Adobe LiveCycle® Rights Management ES2.5 Integration |
| Optional | Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification † † |
| Estimated Toner Yield | Black: 56,000 Copies/Bottle (Estimated @ 6% Coverage) |
Feeders
| Acceptable Originals | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
| Scan Method | Single-Pass Duplexing Automatic Document Feeder |
| Scanning Speed | (BW/Color; Letter): Simplex: Up to 120/85 ipm (300 dpi)/Up to 120/51 ipm (600 dpi)*** Duplex: Up to 200/100 ipm (300 dpi)/Up to 120/51 ipm (600 dpi)*** |
| Capacity | (20 lb. Bond): 300 Sheets |
| Paper Weight | 1-sided scanning: 13 lb. Bond to 80 lb. Cover (50 to 220g/m2) 2-sided scanning (Black-and-white original): 13 lb. Bond to 80 lb. Cover (50 to 220g/m2) 2-sided scanning (Color original): 17 lb. Bond to 80 lb. Cover (64 to 220g/m2) |
Paper Supply Options
| Description | Paper Deck Unit-A1 |
| Number Of Cassettes | 1 |
| Paper Capacity | 3,500 Sheets [20 lb. Bond (80g/m2)] |
| Paper Size | Letter |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Bond, Pre-Punched |
| Power Source | From the Main Unit |
| Power Consumption | Approx. 39W |
| Dimensions | 22-1/2" x 12-3/4" x 23" (570mm x 323mm x 583mm) |
| Weight | 81.6 lb. (37kg) |
| Description | Paper Deck Unit-D1 |
| Paper Size | 11" x 17", Legal, Letter, Letter-R |
| Dimensions | 22-1/2" x 23-5/8" x 24-1/2" (570mm x 601mm x 621mm) |
| Weight | Approx. 125.7 lb. (57kg) |
next to your download
