Canon Support for imageRUNNER ADVANCE 6575i II | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE 6500i II Series Spec Sheet
imageRUNNER ADVANCE 6575i II | |
| MAIN UNIT | |
| TYPE | Monochrome Laser Multifunctional |
| CORE FUNCTIONS | Standard:Print, Copy, Scan, Send, Store Optional:Fax |
| PROCESSOR | Canon Dual Custom Processor (Shared) |
| CONTROL PANEL | Standard:10.1" TFT LCD WSVGA Color Flat- panel Optional10.4" TFT LCD SVGA Color Upright-panel |
| MEMORY | 3.0 GB RAM |
| HARD DISK DRIVE | Standard:250 GBMaximum:1 TB |
| MIRRORING HARD DISK DRIVE | Optional (250 GB, 1 TB), Method: Raid1 |
| INTERFACE CONNECTION | Network1000Base-T/100Base-TX/10Base-T,Wireless LAN (IEEE 802.11 b/g/n) OthersStandard:USB 2.0 x2 (Host), USB 3.0 x1 (Host),USB 2.0 x1 (Device) Optional:Serial Interface, Copy Control Interface |
| PAPER CAPACITY (LTR, 20LB BOND) | Standard:4,200 Sheets Maximum:7,700 Sheets |
| PAPER SOURCES (LTR, 20LB BOND) | Standard:Dual 1,500-sheet Paper Drawers, Dual 550-sheet Paper Cassettes, 100-sheetStack Bypass Optional:3,500-sheet Paper Deck(POD DECK LITE-C1 orPAPER DECK UNIT-E1) |
| PAPER OUTPUT CAPACITY (LTR, 20LB BOND) | With Copy Tray:250 Sheets With External Finishers:3,500 Sheets |
| FINISHING CAPABILITIES | With External Finishers:Collate, Group, Offset, Staple, StapleOn Demand, Staple-free Staple, Booklet, Hole Punch, Document Insertion, C and Z Folding |
| SUPPORTED MEDIA TYPES | Paper Drawers (1/2):Thin, Plain, Recycled, Color, Heavy,Pre-punched, Letterhead, Bond PaperCassettes (3/4):Thin, Plain, Recycled, Color, Heavy,Pre-punched, Letterhead, Bond, Tab. Stack Bypass:Thin, Plain, Recycled, Color, Heavy,Pre-punched, Bond, Transparency, Labels, Letterhead, Tab, Tracing1 POD DECK LITE-C1:Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond, Transparency, Labels, Tab PAPER DECK UNIT-E1:Thin, Plain, Recycled, Color, Heavy,Pre-punched, Letterhead, Bond |
| SUPPORTED MEDIA SIZES | Paper Drawers (1/2):LetterPaper Cassettes (3/4):11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 17") Stack Bypass:11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size(4" x 5-7/8" to 11-3/4" x 17"), Free Size(4" x 7-1/4" to 11-3/4" x 17") POD DECK LITE-C1:11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 17")PAPER DECK UNIT-E1:Letter |
| SUPPORTED MEDIA WEIGHTS | Paper Decks/Cassettes:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) Stack Bypass:14 lb. Bond to 140 lb. Index (52 to 256 g/m2) Duplexing:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
| WARM-UP TIME2 | From Power On:30 Seconds From Sleep Mode:30 Seconds |
| DIMENSIONS (W X D X H) | 26-3/8" x 30-5/8" x 48"(670 mm x 779 mm x 1220 mm) |
| INSTALLATION SPACE (WXD) | Basic:Stack Bypass Extended+ Cassette Drawers open + Copy Tray:60-3/8" x 53-1/4" (1533 mm x 1353 mm) Fully Configured:Booklet finisher + Paper Deck + Insertionand Folding Unit + Puncher Unit + Cassette Drawers open:94-3/4" x 53-1/4" (2407 mm x 1353 mm) |
| WEIGHT | Approx. 515.9 lb. (234 kg)3 |
| PRINT SPECIFICATIONS | |
| PRINT SPEED | Up to 75 ppm (Letter) Up to 58 ppm (Letter-R) Up to 45 ppm (Legal) Up to 37 ppm (11" x 17") |
| PRINT RESOLUTION | 1200 dpi x 1200 dpi, 600 dpi x 600 dpi |
| STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
| DIRECT PRINT | Available from USB, Advanced Box, Remote UI,and Web Access4 |
| SUPPORTED FILE TYPES | PDF, TIFF, JPEG, EPS,5 XPS |
| PRINTING FROM MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements. |
| FONTS | PCL fonts:93 Roman, 10 Bitmap fonts, 2 OCRfonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese)6 PS fonts:136 Roman |
| OPERATING SYSTEM7 | UFRII:Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later) PCL:Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016 PS:Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later) |
| PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing |
| COPY SPECIFICATIONS | |
| COPY SPEED | Up to 75 ppm (Letter) Up to 58 ppm (Letter-R) Up to 45 ppm (Legal) Up to 37 ppm (11" x 17") |
| FIRST-COPY-OUT-TIME | As fast as 3.1 seconds |
| COPY RESOLUTION | Reading:600 dpi x 600 dpi Printing:1200 dpi x 1200 dpi |
| MULTIPLE COPIES | Up to 9,999 copies |
| COPY EXPOSURE | Automatic or Manual (9 Levels) |
| MAGNIFICATION | 25%-400% (1% Increments) |
| PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
| PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
| BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| SPECIAL COPY FEATURES | Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Cascade Copy, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original |
| SCAN SPECIFICATIONS | |
| TYPE | Color Platen and Single-pass Duplexing Automatic Document Feeder |
| DOCUMENT FEEDER PAPER CAPACITY | 300 Sheets (20 lb. Bond) |
| DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
| DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | BW Original:13 lb. Bond to 80 lb. Cover(50 to 220 g/m2) CL Original:17 lb. Bond to 80 lb. Cover(64 to 220 g/m2) |
| PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
| PULL SCAN | Color Network ScanGear2 for both Twain and WIASupported OS:Windows Vista/7/8.1/10Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016 |
| SCAN RESOLUTION | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi,100 x 100dpi |
| SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning tomobile devices and cloud-based services depending onyour requirements. |
| SCAN SPEED (LETTER) | Single-sided Scanning (BW):120 ipm (300 dpi)/120 ipm (600 dpi) Single-sided Scanning (Color):120 ipm (300 dpi)/60 ipm (600 dpi) Double-sided Scanning (BW):240 ipm (300 dpi)/150 ipm (600 dpi) Double-sided Scanning (Color):220 ipm (300 dpi)/60 ipm (600 dpi) |
| SEND SPECIFICATIONS | |
| DESTINATION | E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
| COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White |
| ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
| SEND RESOLUTION | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi,100 x 100dpi |
| COMMUICATION PROTOCOL | File:FTP, SMB v3.0, WebDAVE-mail/I-Fax:SMTP, POP3, I-Fax (Simple, Full) |
| FILE FORMAT | Standard:TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable), Office Open XML (PowerPoint, Word), Digital Signature (PDF/XPS) Optional:PDF (Trace & Smooth) |
| UNIVERSAL SEND FEATURES | Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Sender's Name (TTI), Select Line, Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Multi Sheet Feed Detection |
| FAX SPECIFICATIONS | |
| MAXIMUM NUMBER OF LINES | 4 |
| MODEM SPEED | Super G3:33.6 kbps G3:14.4 kbps |
| COMPRESSION METHOD | MH, MR, MMR, JBIG |
| RESOLUTION | 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi |
| SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
| FAX MEMORY | Up to 30,000 pages |
| SPEED DIALS | Max. 200 |
| GROUP DIALS / DESTINATIONS | Max. 199 dials |
| SEQUENTIAL BROADCAST | Max. 256 addresses |
| MEMORY BACKUP | Yes |
| FAX FEATURES | Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Multi Sheet Feed Detection |
| STORE SPECIFICATIONS | |
| MAIL BOX SIMPLE(NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored |
| ADVANCED BOX | Communication Protocol: SMB or WebDAV SupportedClient PC:Windows (Windows Vista/7/8/8.1/10) Concurrent Connections (Max.): SMB:64 WebDAV:3 (Active Sessions) |
| ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) Approx. 480 GB (1 TB HDD) |
| ADVANCED BOX FEATURES | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
| MEMORY MEDIA | Standard: USB |
| SECURITY SPECIFICATIONS | |
| AUTHENTICATION | Standard:Universal Login Manager, uniFLOWOnline Express,8,9 User Authentication, Department ID Authentication, (Deviceand Function Level Log-in), AccessManagement System Optional:uniFLOW |
| DATA | Standard:Trusted Platform Module (TPM),Hard Disk Password Lock, Hard DiskDrive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated) Optional:Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW) |
| NETWORK | Standard:Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
| DOCUMENT | Standard:Secure Watermark, Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature Optional:User Signature, Document Scan Locking |
| ENVIRONMENTAL SPECIFICATIONS | |
| OPERATING ENVIRONMENT | Temperature:50 to 86 ºF Humidity:20 to 80 % RH (no condensation) |
| POWER REQUIREMENTS | 120-127 V AC, 60 Hz, 16 A |
| PLUG (MAIN UNIT) | NEMA 5-20P |
| POWER CONSUMPTION | Maximum:Approx. 2.1 KW Standby:Approx. 238 Wh Energy Saver Mode:Approx. 192 Wh Sleep mode:Approx. 0.9 W or less10 Typical Electricity Consumption (TEC) Rating: 6.3 kWh |
| STANDARDS | ENERGY STAR® Certified Rated EPEAT® Gold11 EU RoHS Compliant Ecomark Blue Angel |
| CONSUMABLES | |
| TONER | GPR-38 Black Toner |
| TONER YIELD (ESTIMATED @ 6% COVERAGE) | 56,000 Images |
| FOOTNOTES 1 Some types of tracing paper cannot be used. 2 Warm-up time shown for when "Quick Startup Settings for Main Power" is set to "OFF". For significantly faster warm-up set "Quick Startup Settings for Main Power" to "ON". 3 Including the toner bottle. 4 PDF print from Websites is supported. 5 EPS can be printed directly only from the Remote User Interface. 6 Requires the optional PCL International Font Set-A1. 7 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative. 8 No charge for this solution; however activation is required. 9 Check for availability. 10 0.9 W sleep mode not available in all circumstances due to certain settings. 11 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net. | |
next to your download
