Canon Support for imageRUNNER ADVANCE C256iF III | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
imageRUNNER ADVANCE C356iF / C256iF III Series Spec Sheet
imageRUNNER ADVANCE C256iF III | |
MAIN UNIT | |
| TYPE | Color Laser Multifunctional |
| CORE FUNCTIONS | Print, Copy, Scan, Send, Store, Fax (Line One Standard, Line Two Optional) |
| PROCESSOR | Canon Dual Custom Processor (Shared) |
| CONTROL PANEL | 10.1" TFT LCD WSVGA Color Flat-panel |
| MEMORY | 3.0 GB RAM |
| HARD DISK DRIVE | 250 GB |
| INTERFACE CONNECTION | Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard: 650 Sheets |
| PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass |
| PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Standard: 250 Sheets |
| FINISHING CAPABILITIES | Standard: Collate, Group |
| SUPPORTED MEDIA TYPES | Paper Cassette: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Envelope |
SUPPORTED MEDIA SIZES | Paper Cassette 1: Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14") |
| SUPPORTED MEDIA WEIGHTS | Cassettes: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2 ) |
| WARM-UP TIME | From Power On: 34 Seconds |
| DIMENSIONS (W x D x H) | Standard (Desktop): 20-1/8" x 25-5/8" x 25-1/8" (511 mm x 651 mm x 639 mm) |
| INSTALLATION SPACE (W x D x H) | Basic: 33-1/2" x 35-3/4" (852 mm x 908 mm) |
| WEIGHT2 | Standard (Desktop): Approx. 108 lb. (49 kg) |
PRINT SPECIFICATIONS | |
| PRINT / COPY SPEED (BW AND COLOR) | Up to 26 ppm (Letter); Up to 21 ppm (Legal) |
| PRINT RESOLUTION (dpi) | 1200 x 600 |
| STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
| DIRECT PRINT | Available from USB, Advanced Box, Remote UI, and Web Access3 |
| SUPPORTED FILES | PDF, TIFF, JPEG, EPS, XPS |
| PRINTING FROM MOBILE AND CLOUD-BASED SERVICES | A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet connected devices and cloud-based services depending on your requirements. |
| FONTS | PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),4 Barcode Fonts5 |
| OPERATING SYSTEM 6 | UFRII/PS: Windows Vista®/Server 2008/Windows® 7/ Server 2008 R2/Server 2012/Windows 8.1/ Server 2012 R2/Windows 10/Server 2016/ MAC OS X (10.6.8 or later) |
| PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Grouping, Mixed Paper Sizes/ Orientations, Offsetting, Front/Back Covers, Toner Reduction |
COPY SPECIFICATIONS | |
| FIRST-COPY-OUT-TIME | As fast as 6.9 seconds (BW)/ 9.4 seconds (Color) |
| COPY RESOLUTION | Reading: 600 x 600 |
| MULTIPLE COPIES | Up to 999 Copies |
| COPY EXPOSURE | Automatic or Manual (9 Levels) |
| MAGNIFICATION | 25%-400% (1% Increments) |
| PRESET REDUCTIONS | 25%, 50%, 64%, 78% |
| PRESET ENLARGEMENTS | 129%, 200%, 400% |
| BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| SPECIAL COPY FEATURES | Two-Sided Original, Finishing, Job Build, N on 1, Density Adjustment, Original Type Selection, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Job Done Notice, Copy ID Card, Multi Sheet Feed Detection |
SCAN SPECIFICATIONS | |
| TYPE | Single-pass Duplexing Automatic Document Feeder |
| DOCUMENT FEEDER PAPER CAPACITY | 100 Sheets (20 lb. Bond) |
| DOCUMENT FEEDER SUPPORTED MEDIA SIZES | Legal, Letter, Statement |
| DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | BW Original: 13 lb. Bond to 34 lb. Cover (50 to 128 g/m2 ) |
| PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
| PULL SCAN | Color Network ScanGear2 for both Twain and WIA |
| SCAN RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100 |
| SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements. |
| SCAN SPEED (LETTER) | Single-sided Scanning (BW and Color): 50 ipm (300 dpi )/30 ipm (600 dpi) |
SEND SPECIFICATIONS | |
| DESTINATION | E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax, IP Fax (Optional) |
| COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White |
| ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed Dial (200) |
| SEND RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100 |
| COMMUICATION PROTOCOL | File: FTP, SMB, WebDAV |
| FILE FORMAT | Standard: TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable), Office Open XML (PowerPoint®, Word, Digital Signature (PDF/XPS) |
| UNIVERSAL SEND FEATURES | Original Type Selection,Two-Sided Original, Density Adjustment, Sharpness, Erase Frame, Job Build, Direct Send, Delayed Send, Preview, Job Done Notice, File Name, Subject/ Message, Reply-To, Email Priority, TX Report, Original Content Orientation, Skip Blank Originals, Multi Sheet Feed Detection |
FAX SPECIFICATIONS | |
| MAXIMUM NUMBER OF LINES | 2 (Line One Standard, Line Two Optional) |
| MODEM SPEED | Super G3: 33.6 Kbps |
| COMPRESSION METHOD | MH, MR, MMR, JBIG |
| RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
| SENDING / RECORDING SIZE | Statement to Legal |
| FAX MEMORY | Up to 30,000 Pages |
| SPEED DIALS | Max. 200 |
| GROUP DIALS / DESTINATIONS | Max. 199 Dials |
| SEQUENTIAL BROADCAST | Max. 256 Addresses |
| MEMORY BACKUP | Yes |
| FAX FEATURES | Original Type Selection, Two-Sided Original, Density for Scanning, Sharpness, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Multi Sheet Feed Detection |
STORE SPECIFICATIONS | |
| MAIL BOX SIMPLE (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored |
| ADVANCED BOX | Communication Protocol: SMB or WebDAV |
| ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB |
| ADVANCED BOX FEATURES | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
| MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
| AUTHENTICATION | Standard: Universal Login Manager, uniFLOW Online Express,7 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in |
| DATA | Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), McAfee Embedded Control8 |
| NETWORK | Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
| DOCUMENT | Standard: Secure Watermark, Secure Print, Adobe LiveCycle¿ Rights Management ES2.5 Integration |
ENVIRONMENTAL SPECIFICATIONS | |
| OPERATING ENVIRONMENT | Temperature: 50 to 86 ºF |
| POWER REQUIREMENTS | 120-127V AC 60 Hz, 6.9 A |
| PLUG (MAIN UNIT) | NEMA 5-15P |
| POWER CONSUMPTION | Maximum: Approx. 1.5 kWh |
| STANDARDS | ENERGY STAR® Certified |
CONSUMABLES | |
| TONER | GPR-58 Toner |
| TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black: 23,000 Images |
FOOTNOTES | |
next to your download
