Canon Support for imageRUNNER ADVANCE C3325i | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
| Model Name | imageRUNNER ADVANCE C3325i |
| Type | Color Digital Multifunction Imaging System |
| Functions | Standard: Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3™), Scan, Send Optional: Fax (Up to 2 Lines) |
| Operation Panel | 7" WVGA Full-Color TFT Screen |
| Image Server Memory | Standard: 2 GB RAM Maximum: 2 GB RAM |
| Hard Disk Drive | Standard: 215 GB Maximum: 215 GB |
| Network Interface Connection | Standard: 1000Base-TX/100Base-TX/10Base-T Optional: Wireless LAN (IEEE 803.1x via third-party adapter) |
| Other Interface | Standard: USB 2.0 (Host) x 2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) x 2], Copy Control Interface |
| Scanning Resolution | Up to 600 x 600 dpi |
| First Copy Time | As fast as 5.9 Seconds (BW), 8.2 Seconds (Color) |
| Multiple Copies | 1 to 999 |
| Copy Exposure | Automatic or Manual (9 Levels) |
| Magnification | 25% - 400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Acceptable Originals | (Glass) Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)] |
| Maximum Original Size | Up to 11" x 17" |
| Standard Paper Capacity | Up to 100 Sheets (20 lb. Bond) |
| Maximum Paper Capacity | Paper Sources (20 lb. Bond) Standard: Two 550-sheet Paper Cassettes 100-sheet Stack Bypass Optional: Dual 550-sheet Paper Cassettes Maximum: 2,300 Sheets |
| Output Paper Capacity | (20 lb. Bond) Standard: 250 Sheets (Inner Tray) Maximum: 2,100 Sheets (w/Staple Finisher or Booklet Finisher) |
| Warm Up Time | From Power On: Approximately 34 Seconds From Sleep: Approximately 10 Seconds Quick Startup Mode: Within 7 Seconds* |
| Power Requirements | 120 V AC, 60 Hz, 7.5 A |
| Power Consumption | Maximum: 1.5kW Sleep Mode: 0.8 W |
| Plug | NEMA 5-15P |
| Dimension | (H x W x D) 34-5/8" x 22-1/4" x 27-5/16" (878 mm x 565 mm x 693 mm) |
| Installation Space | (W x D) 35-1/4" x 44" (894 mm x 1117 mm) (when the Multi-purpose Tray is extended.) |
| Weight | Approximately 163.4 lb. (74.1 kg)** |
| Basic Copy Features | Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying, ID Management, Counter Check |
| Special Copy Features | Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Document Scan Lock, Area Designation, ID Card Copy |
| Environmental Features | ENERGY STAR® Qualified, Rated EPEAT Gold, EU RoHS Compliant, Ecomark Blue Angel, WEEE Directive |
Advanced Box
| Advanced Box Features | Store to Remote Advanced Box: Supported Print/View from Remote Advanced Box: Supported Standard: USB Memory, Mail Box Simple |
Memory Media
| Standard | Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPV6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Format, HDD Initialize (Up to 9x ), HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration |
| Optional | Removable HDD, HDD Encryption, HDD Data Erase Scheduler, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification†† |
Scan Specifications
| Network TWAIN Scan | Standard |
| Network Scan Utility | Color Network ScanGear |
Output Sizes
| Cassette | 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
| Bypass | 14 lb. Bond to 140 lb. Index (52 to 256 g/m2) |
Duplexing
| Duplexing | Paper Size: Standard Automatic Trayless Duplexing (Executive to 12" x 18") Paper Weight: 14 lb. Bond to 80 lb. Cover (220 g/m2) |
| Paper Size | Cassette 1: Statement, Letter, Executive, Envelope (ISO-C5), Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 8-1/2") Cassette 2: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement, Executive, Custom Size (5-1/2" x 7-1/8" to 12" x 18"), Envelopes (COM10 No.10, Monarch, DL) Cassettes 3/4: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement, Executive, Custom Size (5-1/2" x 7-1/8" to 12" x 18") Bypass: 12" x 18", 12-5/8" x 17-11/16", 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size (3-7/8" x 5-1/2" to 12-5/8" x 18"), Envelopes (COM10 No.10, Monarch, DL, ISO-C5) |
| Paper Weight | Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) Bypass: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2) |
| Special Media Support | Tracing, Coated, Labels, Transparency, Pre-punched, Bond, and Envelopes Envelope Feeding Attachment Paper Capacity: Up to 50 Sheets (or 45 mm in height) Acceptable Envelope Type: COM10 No.10, Monarch, DL, ISO-C5 Feeding Speed: 10 cpm |
Image Reader
| Scan Resolution | Up to 600 x 600 dpi |
| Acceptable Originals | Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)] |
Security Features
| Standard | USB Memory, Mail Box Simple |
| Toner | (Estimated Yield @ 5% Coverage) Black: 36,000 copies/bottle Color: 19,000 copies/bottle |
Feeders
| Description | Image Reader Unit |
| Acceptable Originals | (Glass) Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)] Maximum Original Size: Up to 11" x 17" Scan Resolution: Up to 600 x 600 dpi |
| Description | Document Feeder |
| Acceptable Originals | Paper Sizes: 11" x 17", Legal, Letter, Letter-R, Statement, or Statement-R Paper Weights: 13 lb. Bond to 34 lb. Bond (50 to 128 g/m2) |
| Scan Method | Duplex Automatic Document Feeder |
| Scanning Speed | Simplex: Up to 55 ipm (300 dpi) Up to 30 ipm (600 dpi) Duplex: Up to 27.5 ipm (300 dpi) Up to 15 ipm (600 dpi) |
Paper Supply Options
| Description | Cassette Feeding Unit-AL1 |
| Paper Capacity | 550 Sheets x 2 Cassettes [20 lb. Bond (80 g/m2)] |
| Paper Size | 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, and Custom Size [5-1/2" x 7-1/8" to 12"x 18" (139.7 mm x 182 mm to 304.8 mm x 457.2 mm)] |
| Paper Weight | 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
| Power Source | From the Main Unit |
| Power Consumption | Approximately 30 W |
| Dimensions | 9-13/16" x 22-1/4" x 24-1/4" (248 mm x 565 mm x 615 mm) |
| Weight | Approximately 35.5 lb. (16.1 kg) |
next to your download
