Canon Support for imageRUNNER ADVANCE C3525i | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE C3500 Series Spec Sheet
imageRUNNER ADVANCE C3525i | |
MAIN UNIT | |
TYPE | Color Laser Multifunctional |
CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
PROCESSOR | Canon Dual Custom Processor (Shared) |
CONTROL PANEL | 10.1" TFT LCD WSVGA Color Flat-panel |
MEMORY | 3.0 GB RAM |
HARD DISK DRIVE | Standard: 250 GB |
INTERFACE CONNECTION | Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) Others Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
PAPER CAPACITY (LTR, 20LB BOND) | Standard: 1,200 Sheets Maximum: 2,300 Sheets |
PAPER SOURCES (LTR, 20LB BOND) | Standard: Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass Optional: Dual 550-sheet Paper Cassettes (CASSETTE FEEDING UNIT-AP1) |
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) | Standard: 250 Sheets Maximum: 3,450 Sheets (with External Finisher and Copy Tray) |
FINISHING CAPABILITIES | Standard: Collate, Group With Inner Shift Sorter: Collate, Group, Offset With Inner Finisher: Collate, Group, Offset, Staple, Staple-Free Staple, Staple On Demand With External Finishers: Collate, Group, Offset, Staple, Booklet, Staple-Free Staple, Staple On Demand, Hole Punch (Optional) |
SUPPORTED MEDIA TYPES | Paper Cassettes (1/2): Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Transparency, Envelope Stack Bypass: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Labels, Bond, Coated, Transparency, Tracing, Envelope Cassette Feeding Unit-AP1: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Transparency |
SUPPORTED MEDIA SIZES | Paper Cassette 1: Letter, Executive, Statement-R, Envelope [No.10 (COM10), DL, ISO-C5], Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 8-1/2") Paper Cassette 2: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL], Custom Size (5-1/2" x 7-1/8" to 12" x 18") Stack Bypass: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" x 3-7/8" to 12-5/8" x 18"), Custom Size (3-7/8" x 5-1/2" to 12-5/8" x 18"), Free Size (3-7/8" x 5-1/2" to 12-5/8" x 18") Cassette Feeding Unit-AP1: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 12" x 18") |
SUPPORTED MEDIA WEIGHTS | Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) Stack Bypass: 14 lb. Bond to 110 lb. Cover (52 to 300 g/m2) Duplexing: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
PRINT / COPY SPEED (BW AND COLOR) | Up to 25 ppm (Letter) Up to 20 ppm (Letter-R) Up to 15 ppm (Legal) Up to 15 ppm (11" x 17") |
WARM-UP TIME | From Power On: 34 Seconds From Sleep Mode: 10 Seconds Quick Startup Mode: 10 Seconds1 |
DIMENSIONS (W X D X H) | 22-1/4" x 29-1/4" x 45-1/5"(565 mm x 742 mm x 1148 mm)2 |
INSTALLATION SPACE (WXD) | Basic: Stack Bypass + Cassette drawers open: 38-1/2" x 44-1/4" (978 mm x 1123 mm)2 Fully Configured: 63-3/4" x 44-1/4" (1620 mm x 1123 mm)3 |
WEIGHT | Approx. 213.9 lb. (97 kg)4 |
PRINT SPECIFICATIONS | |
PRINT RESOLUTION (dpi) | 1200 x 1200 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
DIRECT PRINT | Available from USB, Advanced Box, Remote UI, and Web Access5 |
SUPPORTED FILE TYPES FOR DIRECT PRINT | PDF, TIFF, JPEG, EPS, XPS |
PRINTING FROM MOBILE AND CLOUD | A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet connected devices and cloud-based services depending on your requirements. |
FONTS | PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),6 Barcode Fonts7 PS fonts: 136 Roman |
OPERATING SYSTEM8 | UFRII/PS: Server 2003/Server 2003 R2/Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later) PCL: Server 2003/Server 2003 R2/Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016 |
PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT TIME (LETTER) | As fast as 5.9 seconds (BW)/8.2 seconds (Color) |
MULTIPLE COPIES | Up to 999 copies |
COPY EXPOSURE | Automatic or Manual (9 Levels) |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
SPECIAL COPY FEATURES | Book to Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different-Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Job Done Notice, Mirror Image, Copy ID Card, Multi Sheet Feed Detection, Free Size Original, Adjust One-Touch Color, Color Balance, Area Designation |
SCAN SPECIFICATIONS | |
TYPE | Single-pass Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | 150 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHT | BW Original: 13 lb. Bond to 58 lb. Cover (50 to 157 g/m2) CL Original: 17 lb. Bond to 58 lb. Cover (64 to 157 g/m2) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS: Windows Vista/7/8/8.1/10/ Server 2008/Server 2008 R2/ Server 2012/Server 2012 R2 |
SCAN RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100 |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements. |
SCAN SPEED (LETTER) | Single-sided Scanning (BW/Color): 80 ipm (300 dpi)/51 ipm (600 dpi) Double-sided Scanning (BW/Color): 160 ipm (300 dpi)/51 ipm (600 dpi) |
SEND SPECIFICATIONS | |
DESTINATION | E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White |
ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
SEND RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100 |
COMMUICATION PROTOCOL | File: FTP, SMB, WebDAV E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full) |
FILE FORMAT | Standard: TIFF, JPEG, PDF(Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable), Office Open XML (PowerPoint®, Word) Optional: PDF (Trace & Smooth, Encrypted), PDF/XPS (Digital Signature) |
UNIVERSAL SEND FEATURES | Original Type Selection,Two-Sided Original, Book to Two Pages, Different-Size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-To, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Multi Sheet Feed Detection |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF CONNECTION LINES | 2 |
MODEM SPEED | Super G3: 33.6 Kbps G3: 14.4 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 Pages |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 Dials |
SEQUENTIAL BROADCAST | Max. 256 Addresses |
MEMORY BACKUP | Yes |
FAX FEATURES | Original Type Selection, Two-Sided Original, Book to Two Pages, Different-Size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Select Line, Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Multi Sheet Feed Detection |
STORE SPECIFICATIONS | |
MAIL BOX (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored |
ADVANCED BOX | Communication Protocol: SMB or WebDAV Supported Client PC: Windows (Windows Vista/7/8/8.1/10) Concurrent Connections (Max.) SMB: 64 WebDAV: 3 (Active Sessions) |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) |
ADVANCED BOX FEATURES | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Universal Login Manager, User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in Optional: uniFLOW |
DATA | Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated) Optional: Hard Disk Drive Removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW) |
NETWORK | Standard: IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
DOCUMENT | Standard: Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration Optional: Encrypted PDF, Encrypted Secure Print, User and Device Signatures, Secure Watermarks, Document Scan Locking |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86 ºF Humidity: 20 to 80 % RH (no condensation) |
POWER REQUIREMENTS | 120-127V AC 60 Hz,7.5 A |
PLUG (MAIN UNIT) | NEMA 5-15P |
POWER CONSUMPTION | Maximum: Approx. 1.5 kWh Standby: Approx. 44.1 W Sleep Mode: Approx. 0.8 W9 Typical Electricity Consumption (TEC) Rating: 1.0 kWh |
STANDARDS | ENERGY STAR® Certified Rated EPEAT® Gold10 |
CONSUMABLES | |
TONER | GPR-53 Toner11/GPR-53L |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black: 36,000 Copies/Bottle Color (C,M,Y):11 19,000 Copies/Bottle Color (C,M,Y): 8,500 Copies/Bottle |
FOOTNOTES | |
1 Time from device power-on to when copy jobs can be programmed. 2 Includes main unit and either Cassette Feeding Unit-AP1 or Cabinet Type-R. 3 Includes main unit and either Cassette Feeding Unit-AP1 or Cabinet Type-R and Staple/Booklet Finisher-AA1. 4 Includes main unit, ADF, consumables, and Cassette Feeding Unit-AP1. 5 PDF print from Web sites is supported. 6 Requires the optional PCL International Font Set-A1. 7 Requires the optional Barcode Printer Kit-D1. 8 Other operating systems and environments, including AS/400, UNIX, Linux and Citrix, may be supported. Some solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative. 9 0.8 W sleep mode not available in all circumstances due to certain settings. 10 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net. 11 GPR-53L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 8,500 images. |
