Canon Support for imageRUNNER ADVANCE C356iF II | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
| Model Name | imageRUNNER ADVANCE C356iF II |
| Type | Color Laser Multifunctional |
| Functions | Print, Copy, Scan, Send, Store, Fax (Line One Standard, Line Two Optional) |
| Operation Panel | 10.1" TFT LCD WSVGA Color Flat-panel |
| Image Server Memory | 3.0 GB RAM |
| Hard Disk Drive | 250 GB |
| Network Interface Connection | 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) |
| Other Interface | Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes |
| Max Pages Stored | 30,000 Maximum Pages Stored |
| Warm Up Time | From Power On: 30 Seconds From Sleep Mode: 10 Seconds Quick Startup Mode: 4 Seconds1 |
| Power Requirements | 120-127V AC 60 Hz, 6.9 A |
| Power Consumption | Maximum: Approx. 1.5 kWh Standby: Approx. 38.9 W Sleep Mode: Approx. 0.8 W9 0.7 kWh |
| Plug | NEMA 5-15P |
| Dimension | Standard(Desktop):20-1/8" x 25-5/8" x 25-1/8"(511 mm x 651 mm x 639 mm) With CassetteFeeding Unit-AJ1 or AK1:20-1/8" x 25-5/8" x 41-7/8(511 mm x 651 mm x 1,064 mm) |
| Installation Space | Basic: 33-1/2" x 35-3/4" (852 mm x 908 mm) With Staple Finisher-Z1: 55-3/8" x 35-3/4" (1,407 mm x 908 mm) |
| Weight | Standard (Desktop): Approx. 108 lb. (49 kg) With Cassette Feeding Unit- AJ1: Approx. 143.3 lb. (65 kg) With Cassette Feeding Unit- AK1: Approx. 149.9 lb. (68 kg) With Cassette Module AE-1: Approx. 130.1 lb. (59 kg)2 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two- Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Two-Sided Original, Finishing, Job Build, N on 1, Density Adjustment, Original Type Selection, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Job Done Notice, Copy ID Card, Multi Sheet Feed Detection |
Advanced Box
| Available Disk Space | Approx. 16 GB |
| Common Protocol | SMB or WebDAV |
| Supported Client PC | Windows (Windows Vista/7/8/8.1/10) |
| Max. Number of Concurrent Connections | SMB: 64 WebDAV: 3 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
Memory Media
| Standard | Standard: USB |
Copy/Print Speed (BW/Color)
| Letter | Up to 36 ppm |
| Legal | Up to 29 ppm |
Copy Specifications
| First Copy Time | As fast as 6.9 seconds (BW)/ 9.4 seconds (Color) |
| Multiple Copies | Up to 999 copies |
| Copy Exposure | Automatic or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 78% |
| Preset Enlargements | 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
| Standard Paper Capacity | 650 Sheets |
| Maximum Paper Capacity | 2,300 Sheets |
| Output Paper Capacity | (LTR, 20 lb. Bond): Standard: 250 Sheets Maximum: 500 Sheets (with STAPLE FINISHER-Z1) |
Output Sizes
| Cassette | Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14") |
| Bypass | Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" x 5-7/8" to 8-1/2" x 14"), Custom Size (3-7/8" x 5-7/8" to 8-1/2" x 14") |
| Other Option | Cassette Module-AE1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14") Cassette Feeding Unit-AJ1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14") Cassette Feeding Unit-AK1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14") |
Acceptable Paper Weights
| Cassette | 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2) |
| Bypass | 16 lb. Bond to 80 lb. Cover (60 to 220 g/m2) Duplexing: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2) |
Duplexing
| Duplexing | Single-pass Duplexing Automatic Document Feeder |
| Paper Size | Legal, Letter, Statement |
| Paper Weight | BW Original: 13 lb. Bond to 34 lb. Cover (50 to 128 g/m2) CL Original: 17 lb. Bond to 34 lb. Cover (64 to 128 g/m2) |
| Toner | GPR-58 Toner |
| Estimated Toner Yield | (Estimated @ 5% Coverage): Black: 23,000 Images Color (C,M,Y): 18,000 Images FOOTNOTES: Time from device power-on to when copy jobs can be programmed. Includes consumables. PDF print from Web sites is supported. Requires the optional PCL International Font Set-A1. Requires the optional Barcode Printer Kit-D1. Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative. 0.8 W sleep mode not available in all circumstances due to certain settings. For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net. Will launch at a later date. Used for corner/double stapling only. 2 cartridges per case. 5,000 staples per cartridge. |
next to your download
