Canon Support for imageRUNNER ADVANCE C5550i II | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE C5500i II Series Spec Sheet
imageRUNNER ADVANCE C5550i II | |
| MAIN UNIT | |
| TYPE | Color Laser Multifunctional |
| CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| PROCESSOR | Canon Dual Custom Processor (Shared) |
| CONTROL PANEL | 10.1" TFT LCD WSVGA Color Flat-panel |
| MEMORY | 4.0 GB RAM |
| HARD DISK DRIVE | Standard: 250 GB Maximum: 1 TB |
| MIRRORING HARD DISK DRIVE | Optional (250 GB, 1 TB) Method: Raid1 |
| INTERFACE CONNECTION | Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) Others Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
| PAPER CAPACITY (LTR, 20LB BOND) | Standard: 1,200 Sheets Maximum: 6,350 Sheets |
| PAPER SOURCES (LTR, 20LB BOND) | Standard: Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass Optional: Dual 550-sheet Paper Cassettes (CASSETTE FEEDING UNIT-AM1), 2,450-sheet High-Capacity Paper Cassette (HIGH CAPACITY CASSETTE FEEDING UNIT-A1), 2,700-sheet Paper Deck (PAPER DECK UNIT-F1) |
| PAPER OUTPUT CAPACITY (LTR, 20LB BOND) | Standard: 250 Sheets Maximum: 3,450 Sheets (with External Finisher and Copy Tray) |
| FINISHING CAPABILITIES | Standard: Collate, Group With Inner Finisher: Collate, Group, Offset, Staple, Hole Punch, Staple-Free Staple, Staple On Demand With External Finishers: Collate, Group, Offset, Staple, Booklet, Hole Punch, Staple-Free Staple, Staple On Demand |
| SUPPORTED MEDIA TYPES | Paper Cassettes (1/2): Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond, Transparency, Tab, Envelope Stack Bypass: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Labels, Letterhead, Bond, Coated, Transparency,Tab, Tracing,1 Envelope |
| SUPPORTED MEDIA SIZES | Paper Cassette 1: Letter, Executive, Statement-R, Envelope [No.10 (COM10), DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 8-1/2") Paper Cassette 2: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 7-1/8" to 12" x 18") Stack Bypass: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" x 3-7/8" to 12-5/8" x 18"), Custom Size (3-7/8" x 5-1/2" to 12-5/8" x 18"), Free Size (3-7/8" x 5-1/2" to 12-5/8" x 18") |
| SUPPORTED MEDIA WEIGHTS | Cassettes: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2) Stack Bypass: 14 lb. Bond to 110 lb. Cover (52 to 300 g/m2) Duplexing: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
| WARM-UP TIME | From Power On: 10 Seconds2 From Sleep Mode: 10 Seconds |
| DIMENSIONS (W X D X H) | 24-3/8" x 29-1/4" x 37-3/8"(620 mm x 742 mm x 950 mm)3 |
| INSTALLATION SPACE (WXD) | Basic: Stack Bypass + Cassette drawers open: 37-1/8" x 46-3/8" (943 mm x 1,176 mm)3 |
| WEIGHT | Approx. 313.1 lb. (142 kg)4 |
| PRINT SPECIFICATIONS | |
| PRINT / COPY SPEED (BW AND COLOR) | Up to 50 ppm (Letter);Up to 30 ppm (Letter-R) ;Up to 29 ppm (Legal); Up to 27 ppm (11" x 17") |
| PRINT RESOLUTION | 1200 dpi x 1200 dpi, 600 dpi x 600 dpi |
| STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
| DIRECT PRINT | Available from USB, Advanced Box, Remote UI, and Web Access5 |
| SUPPORTED FILE TYPES | PDF, TIFF, JPEG, EPS,6 XPS |
| PRINTING FROM MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements. |
| FONTS | PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),7 Barcode Fonts8 PS fonts: 136 Roman |
| OPERATING SYSTEM9 | UFRII: Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later) PCL: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016 PS: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later) |
| PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing |
| COPY SPECIFICATIONS | |
| COPY SPEED (BW AND COLOR) | Up to 50 ppm (Letter); Up to 30 ppm (Letter-R); Up to 29 ppm (Legal); Up to 27 ppm (11" x 17") |
| FIRST-COPY-OUT-TIME | As fast as 3.5 seconds (BW) / 5.2 seconds (Color) |
| COPY RESOLUTION | Reading: 600 dpi x 600 dpi Printing: 1200 dpi x 1200 dpi |
| MULTIPLE COPIES | Up to 9,999 copies |
| COPY EXPOSURE | Automatic or Manual (9 Levels) |
| MAGNIFICATION | 25%-400% (1% Increments) |
| PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
| PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
| BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| SPECIAL COPY FEATURES | Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Color Balance, Adjust One-Touch Color, Area Designation |
| SCAN SPECIFICATIONS | |
| TYPE | Color Platen and Single-pass Duplexing Automatic Document Feeder |
| DOCUMENT FEEDER PAPER CAPACITY | 150 Sheets (20 lb. Bond) |
| DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
| DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | BW Original: 13 lb. Bond to 58 lb. Cover (50 to 157 g/m2) |
| PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
| PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS: Windows Vista/7/8.1/10 Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016 |
| SCAN RESOLUTION | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi |
| SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements. |
| SCAN SPEED (LETTER) | Single-sided Scanning (BW): 80 ipm (300 dpi)/80 ipm (600 dpi) Single-sided Scanning (Color): 80 ipm (300 dpi)/60 ipm (600 dpi) Double-sided Scanning (BW): 160 ipm (300 dpi)/150 ipm (600 dpi) Double-sided Scanning (Color): 160 ipm (300 dpi)/80 ipm (600 dpi) |
| SEND SPECIFICATIONS | |
| DESTINATION | E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
| COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White |
| ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
| SEND RESOLUTION | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi |
| COMMUICATION PROTOCOL | File: FTP, SMB, WebDAV E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full) |
| FILE FORMAT | Standard: TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable), Office Open XML (PowerPoint¿, Word, Digital Signature (PDF/XPS) Optional: PDF (Trace & Smooth) |
| UNIVERSAL SEND FEATURES | Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Direct Send, Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed |
| FAX SPECIFICATIONS | |
| MAXIMUM NUMBER OF LINES | |
| MODEM SPEED | Super G3: 33.6 kbps G3: 14.4 kbps |
| COMPRESSION METHOD | MH, MR, MMR, JBIG |
| RESOLUTION | 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi |
| SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
| FAX MEMORY | Up to 30,000 pages |
| SPEED DIALS | Max. 200 |
| GROUP DIALS / DESTINATIONS | Max. 199 dials |
| SEQUENTIAL BROADCAST | Max. 256 addresses |
| MEMORY BACKUP | Yes |
| FAX FEATURES | Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Select Line, Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed |
| STORE SPECIFICATIONS | |
| MAIL BOX SIMPLE(NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored |
| ADVANCED BOX | Communication Protocol: SMB or WebDAV Supported Client PC: Windows (Windows Vista/7/8/8.1/10) Concurrent Connections (Max.) SMB: 64 WebDAV: 3 (Active Sessions) |
| ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) Approx. 480 GB (1 TB HDD) |
| ADVANCED BOX FEATURES | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
| MEMORY MEDIA | Standard: USB |
| SECURITY SPECIFICATIONS | |
| AUTHENTICATION | Standard: Universal Login Manager, uniFLOW Online Express,10,11 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in Optional: uniFLOW |
| DATA | Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated) Optional: Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW) |
| NETWORK | Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
| DOCUMENT | Standard: Secure Watermark, Encrypted PDF, Encrypted Secure Print, Digital Signatures, Adobe LiveCycle¿ Rights Management ES2.5 Integration Optional: User Signatures, Document Scan Locking |
| ENVIRONMENTAL SPECIFICATIONS | |
| OPERATING ENVIRONMENT | Temperature: 50 to 86 ºF Humidity: 20 to 80 % RH (no condensation) |
| POWER REQUIREMENTS | 120-127V AC 60 Hz,11.5 A |
| PLUG (MAIN UNIT) | NEMA 5-20P |
| POWER CONSUMPTION | Maximum: Approx. 1.8 kWh Standby: Approx. 66.2 W Sleep Mode: Approx. 0.8 W12 Typical Electricity Consumption (TEC) Rating: 2.5 kWh |
| STANDARDS | ENERGY STAR® Certified Rated EPEAT® Gold13 RoHS Compliant |
| CONSUMABLES | |
| TONER | GPR-55 Toner14 |
| TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black: 69,000 Images Color (C,M,Y):14 60,000 Images |
| FOOTNOTES 1 Some types of tracing paper cannot be used. 2 Time from device power-on to when copy jobs can be programmed with Quick Start Up mode. 3 Includes main unit and either Cassette Feeding Unit-AM1, High Capacity Cassette Feeding Unit-A1, or Cabinet Type-N. 4 Includes main unit, consumables, and Cassette Feeding Unit-AM1. 5 PDF print from Web sites is supported. 6 EPS can be printed directly only from the Remote User Interface. 7 Requires the optional PCL International Font Set-A1. 8 Requires the optional Barcode Printer Kit-D1. 9 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative. 10 No charge for this solution; however activation is required. 11 Check for availability. 12 0.8 W sleep mode not available in all circumstances due to certain settings. 13 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net. 14 GPR-55L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 26,000 images. | |
next to your download
