Canon Support for imageRUNNER ADVANCE C7260 | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
| Model Name | imageRUNNER ADVANCE C7260 |
| Type | Color Digital Multifunction Imaging System |
| Functions | Standard: Copy, Print (UFR II), Scan, Send, Store Optional: Print (PCL 5c/6, Adobe® PostScript® 3™), Fax (Up to 4 Lines) |
| Operation Panel | Standard: 8.4" SVGA Full-Color, TFT Screen Optional: 10.4" SVGA Full-Color, TFT Upright Screen |
| Image Server Memory | Standard: 2GB RAM Maximum: 2.5GB RAM |
| Hard Disk Drive | Standard: 160GB Maximum: 1TB |
| Mirroring Hard Disk Drive | Optional (160GB, 1TB), Method: RAID1 |
| Network Interface Connection | Standard: 10Base-T/100Base-TX/1000Base-T Optional: Wireless LAN (IEEE 802.1x via third-party adapter) |
| Other Interface | Standard: USB 2.0 (Host) x2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) x2], Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes |
| Max Pages Stored | 6,000 Maximum Pages Stored |
| Special Media Support | Thin [14 lb. Bond to 16 lb. Bond (52 to 63g/m2)], Plain 1 [17 lb. Bond to 21 lb. Bond (64 to 81g/m2)], Plain 2 [22 lb. Bond to 28 lb. Bond (82 to 105g/m2)], Heavy 1 [29 lb. Bond to 40 lb. Bond (106 to 150g/m2)], Heavy 2 [56 lb. Cover to 80 lb. Cover (151 to 220g/m2)], Heavy 3 [82 lb. Cover to 140 lb. Index (221 to 256g/m2)], Heavy 4 [140 lb. Index to 110 lb. Cover (257 to 300g/m2)], Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Letterhead, Tab, Textured, Coated, Envelopes |
| Warm Up Time | From Power On: 31 Seconds or Less From Sleep Mode: 30 Seconds or Less Quick Startup Mode: 7 Seconds* |
| Power Requirements | 120V AC, 60Hz, 16A |
| Power Consumption | Maximum: 2kW Sleep Mode: 0.9W or Less |
| Plug | NEMA 5-20P |
| Dimension | Without the Upright Control Panel: 48-1/8" x 27-1/8" x 36-3/4" (1221mm x 689mm x 932mm) With the Upright Control Panel (To the right edge of the Upright Control Panel in the right-most position): 55-1/4" x 46-1/2" x 36-3/4" (1403mm x 1180mm x 932mm) |
| Installation Space | 52-7/8" x 36-3/4" (1344mm x 932mm) |
| Weight | Approx. 604 lb. (274kg)** |
| Basic Copy Features | Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying |
| Special Copy Features | Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different-size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox |
| Environmental Features | ENERGY STAR® QualifiedEPEAT® Gold EU RoHS Compliant Ecomark Blue Angel WEEE Directive |
Advanced Box
| Available Disk Space | Approx. 15GB (Standard HDD), Approx. 629GB (1TB HDD) |
| Common Protocol | SMB or WebDAV |
| Supported Client PC | Windows (Windows 2000/XP/7/8/Windows Vista) |
| Max. Number of Concurrent Connections | SMB: 32, WebDAV: 12 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
Memory Media
| Standard | USB Memory |
| Optional | SD, SDHC, CompactFlash, Memory Stick, Microdrive |
Scan Specifications
| Network TWAIN Scan | Standard |
| Network Scan Utility | Color Network ScanGear |
Copy/Print Speed (BW/Color)
| Letter | Up to 60/55 ppm |
| Legal | Up to 35/32 ppm 11" x 17: Up to 30/27 ppm |
Copy Specifications
| First Copy Time | BW: 4.9 Seconds or Less Color: 6.6 Seconds or Less |
| Multiple Copies | 1 to 9,999 |
| Copy Exposure | Automatic or Manual (9 Levels) |
| Magnification | 25% - 400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Standard Paper Capacity | (20 lb. Bond): Dual 1,100-sheet Paper Drawers, Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass |
| Optional | 3,500-sheet Paper Deck Unit or 3,500-sheet POD Deck Lite |
| Maximum Paper Capacity | 6,900 Sheets (w/Paper Deck Unit Option) |
| Output Paper Capacity | (20 lb. Bond): 4,000 Sheets (w/Staple Finisher or Booklet Finisher) |
Output Sizes
| Cassette | 13" x 19", 12-5/8" x 17-11/16", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 13" x 19-1/4") Drawers: Letter |
| Bypass | 13" x 19", 12-5/8" x 17-11/16", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelopes, Custom Size (4" x 5-7/8" to 13" x 19-1/4") |
Acceptable Paper Weights
| Cassette | 14 lb. Bond to 80 lb. Cover (52 to 220g/m2) |
| Bypass | 14 lb. Bond to 110 lb. Cover (52 to 300g/m2) |
Duplexing
| Duplexing | Standard Automatic Trayless Duplexing |
| Paper Size | Up to 13" x 19" |
| Paper Weight | 14 lb. Bond to 80 lb. Cover (52 to 220g/m2) |
Image Reader
| Scan Resolution | Up to 600 x 600 dpi |
| Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2kg)] |
| Maximum Original Size | Up to 11" x 17" |
Security Features
| Standard | Department ID Management, Single Sign-On H, Access Management System (Device and Function Level Log-in), Secure Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, IPsec, Adobe LiveCycle® Rights Management ES2.5 Integration |
| Optional | Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification†† |
| Estimated Toner Yield | Black: 80,000 Copies/Bottle Color (C,M,Y): 52,000 Copies/Bottle (Estimated @ 5% Coverage) |
Feeders
| Acceptable Originals | Paper Sizes: 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
| Scan Method | Single-Pass Duplexing Automatic Document Feeder |
| Scanning Speed | Simplex: Up to 120/120 ipm (300 dpi), Up to 120/70 ipm (600 dpi) Duplex: Up to 200/140 ipm (300 dpi), Up to 120/70 ipm (600 dpi) |
| Capacity | (20 lb. Bond): 300 Sheets |
| Paper Weight | 1-sided scanning: 13 lb. Bond to 80 lb. Cover (50 to 220g/m2) 2-sided scanning (Black-and-white original): 13 lb. Bond to 80 lb. Cover (50 to 220g/m2) 2-sided scanning (Color original): 17 lb. Bond to 80 lb. Cover (64 to 220g/m2) |
Paper Supply Options
| Description | Paper Deck Unit-C1 |
| Number Of Cassettes | 1 |
| Paper Capacity | 3,500 Sheets [20 lb. Bond (80g/m2)] |
| Paper Size | Letter |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched |
| Power Source | From Main Unit |
| Power Consumption | Approx. 44W |
| Dimensions | 22-1/2" x 12-3/4" x 23" (570mm x 323mm x 583mm) |
| Weight | Approx. 81.6 lb. (37kg) |
| Description | POD Deck Lite-A1 |
| Paper Size | 13" x 19", 12-5/8" x 17-11/16", 12" x 18", 11" x 17", Legal, Letter, Letter-R |
| Paper Weight | 14 lb. Bond to 110 lb. Cover (52 to 300g/m2) |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Labels, Bond, Textured, Coated, Letterhead |
| Power Source | 120-127V AC, 60Hz, 2.4A |
| Power Consumption | Approx. 263W |
| Dimensions | 22-1/2" x 23-5/8" x 24-1/2" (570mm x 601mm x 621mm) |
| Weight | Approx. 110 lb. (50kg) |
next to your download
