Canon Support for imageRUNNER ADVANCE C9065S PRO | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
| Model Name | imageRUNNER ADVANCE C9065S PRO |
| System Type | Color Digital Multifunction Imaging System |
| Functions | Copy, Scan, Print |
| Operation Panel | PRISMAsync 15" LCD Standard Configuration: imageRUNNER ADVANCE C9075S PRO/ C9065S PRO Main Unit, Duplex Color Image Reader Unit-A1, PRISMAsync iR-ADV C9000S PRO, Operator Panel, Scanning-B1,⟩ Scheduler-A1,⟩ Multiple Queues/Hot Folders-A1,⟩ E-shredding-B1,⟩ X-Rite Eye-One Spectrophotometer |
| Memory | Standard/Maximum: 2.5GB RAM |
| HDD Drive | Standard: 80GB Maximum: 1TB |
| Network Interface Connection | Standard: Ethernet (10Base-T/100Base-TX/1000Base-T) |
| Other Interface | Standard: USB (at Operator Panel) |
| Copy/Print Speed (BW/Color) | Letter: Up to 65/65 ppm Legal/11" x 17": Up to 39/39 ppm / Up to 33/33 ppm |
| Paper Source | (20 lb. Bond): Standard: Dual 1,100-sheet Paper Drawers/Dual 550-sheet Cassettes/100-sheet Stack Bypass Optional: 3,500-sheet Paper Deck-A1, 3,500-POD Deck Lite-A1, or 6,000-sheet/Multi-Drawer Paper Deck-A1 Maximum: 9,300 Sheets (with Multi-Drawer Paper Deck option)* |
| Output Paper Capacity | (20 lb. Bond): With Copy Tray: 250 Sheets With Staple or Booklet Finisher: 4,250 Sheets |
| Output Paper Sizes | Drawers: Letter Cassettes: 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 13" x 19-1/4") Bypass: 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4" x 5-7/8" to 13" x 19-1/4") |
| Acceptable Paper Weights | Drawers/Cassettes: 14 lb. Bond to 80 lb. Cover Bypass: 14 lb. Bond to 110 lb. Cover |
| Duplexing | Paper Size: Standard Automatic Trayless Duplexing (Up to 13" x 19") Paper Weights: 14 lb. Bond to 80 lb. Cover |
| Special Media Support | Drawers: Transparency Cassettes: Transparency, Tab Bypass: Transparency, Tracing, Labels, Coated, Textured, Envelopes |
| Warm Up Time | From Power On: 5 Minutes From Sleep Mode: 5 Minutes From Energy Saver Mode: 90 Seconds |
| Power Requirements | Main Unit: 208V AC, 60Hz, 15A/NEMA 6-15P PRISMAsync: 120V AC, 60Hz, 10-5A/NEMA 5-15P |
| Power Consumption | (Maximum): Main Unit: 2.5kW or Less; Sleep Mode: 1.5W PRISMAsync: 181W or Less: Sleep Mode: 117W Total: 2.68kW or Less; Sleep Mode: 118.5W |
| Plug | Main Unit: 15A/NEMA 6-15P PRISMAsync: 10-5A/NEMA 5-15P |
| Dimensions | Main Unit: 55-1/10" x 44-1/10" x 36-3/4"** PRISMAsync: 16-1/2" x 7-9/10 x 16-9/10" |
| Installation Space | 50-1/5" x 57-1/10" (1275mm x 1450mm) (when Stack Bypass is extended, Operator Panel is in right-most position, and the Cassette is drawn) |
| Weight | Main Unit:♦ Approx. 635 lb. PRISMAsync: Approx. 35.3 lb. Total:♦ Approx. 670 lb. |
Image Reader Unit
| Scan Resolutions | Up to 600 x 600 dpi |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects (up to 4.4 lb.) |
| Maximum Original Size | Up to 11" x 17" |
Document Feeder
| Scan Method | Single-Pass Duplexing Automatic Document Feeder |
| Acceptable Originals | Paper Sizes: 11" x 17", Legal, Letter, Letter-R,Statement, or Statement-R Paper Weights: BW Originals: 13 lb. Bond to 80 lb. Cover Color Originals: 17 lb. Bond to 80 lb. Cover |
| Scanning Speed | Copy/Scan Simplex: 45/45 ipm (600 dpi) Copy/Scan Duplex: 44/44 ipm (600 dpi) |
| Paper Capacity | (20 lb. Bond): 300 Sheets |
Copy Specifications
| First Copy Output Time | BW: 15 Seconds Color: 15 Seconds |
| Multiple Copies | 1 to 9,999 |
| Color Mode | Black and White, Color |
| Magnification | 25% - 400% (1% Increments) |
| Copy Features | Original: 1- or 2-sided, Original type, Size, Background Output: 1- or 2-sided, Binding edge, Media, Cover, Layout, Zoom, Align, Shift, Print delivery, Margin erase, Adjust image, Color/Black & white, Punching,† Folding,† Binding,† Trimming† Job: Job name, Number of sets, Destination, Separator sheets, Account ID |
Print Specifications
| Processor | Intel® Quad CoreTM i7 Type: External Operating System: Windows® XPe® SP3 First-Print-Out-Time: (Letter): BW: 8 Seconds Color: 8 Seconds |
| Memory | 4GB |
| Hard Disk | 3 x 3.5" SATA II, 250GB, 7200 RPM DVD-ROM: Standard Interface Connections: 10/100/1000Base-T, TCP/IP (LPR/LPD), 9100 Socket (SMB), Static IP/Auto-IP (DHCP) |
| Engine Resolution | 1200 x 1200 dpi |
| PDL Support | Adobe® PS3 (3019), PDF 1.7, [Extension Level 3 (for Acrobat® 9)], PDF/X, Optimized PS, Optimized PDF |
| Print Driver Supported OS | Windows Vista®, Windows 7 (32-bit and 64-bit), MAC® OS X10.4/10.5/10.6 (32-bit), PPD |
| Print Features | Waiting/scheduled jobs queues, printed jobs archive; One queue and job management for printing and copying; Streaming (spool-while-RIP-while-print while- clean-up), unlimited job length at constant print speed via clearing up while printing; Multiple standard and customizable workflow profiles; Media based operation with PRISMA media catalog; Web-based controller Settings Editor; Professional high-speed color management with Adobe ACE Color Management module and dedicated GPU; Calibration per media family and halftone; Spot color editing including CMYK value definition for spot color tints; Unlimited color pre-set definition for easy and timesaving re-use; Scheduler at operating panel: 8 hours plan-ahead functionality for multiple jobs simultaneously; Workflow automation via LPR queues and PDF/PS Hot Folders Fonts: 136 Type 1 fonts for Roman languages; User import of PS fonts via Settings Editor Spot Color Libraries: HKS K, HKS K3000+, HKS N, HKS N 3000+, PANTONE® Goe un/coated, PANTONE®+ Solid un/coated Scan Specifications Standard: Scan-to-E-mail, Scan-to-FTP, Scan-to-USB Option: Scan-to-PRISMAaccess Scan Resolution: Up to 600dpi File Format: (Single/Multi-page) TIFF, JPEG, PDF |
| Security Specifications | Standard: E-shredding, HTTPS, Password protection per user role (key operator, system administrator, service technician) Optional: Removable HDD |
| Environmental Information | ENERGY STAR® Qualified RoHS Compliant WEEE Directive |
Paper Supply Options
| Description | Paper Deck Unit-A1 |
| Paper Capacity | 3,500 Sheets (20 lb. Bond) |
| No Of Drawers | 1 |
| Acceptable Paper Weight | 14 lb. Bond to 80 lb. Cover |
| Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched |
| Acceptable Paper Size | Letter |
| Power Source | From Main Unit |
| Maximum Power Consumption | 44W |
| Dimensions | 22-1/2" x 12-3/4" x 23" |
| Weight | Approx. 81.6 lb |
| Description | POD Deck Lite-A1 |
| No Of Drawers | 1 |
| Acceptable Paper Weight | 14 lb. Bond to 110 lb. Cover |
| Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-punched, Transparency, Labels, Bond, Letterhead, Coated, Textured |
| Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R |
| Power Requirement | 120-127V AC, 60Hz, 5A |
| Maximum Power Consumption | 288W |
| Plug | NEMA 5-15P |
| Dimensions | 22-1/2" x 23-5/8" x 24-1/2" |
| Weight | Approx. 110 lb. |
| Description | Multi-Drawer Paper Deck-A1 |
| Paper Capacity | 6,000 Sheets (20 lb. Bond) |
| No Of Drawers | 3 (2,000 Sheets each) |
| Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Labels, Tab, Bond, Letterhead, Coated, Textured |
| Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Custom Size [5-1/2" x 7-1/8" to 13" x 19-1/4" (140mm x 182mm to 330mm x 488mm)] |
| Power Requirement | 120-127V 60Hz 4A |
| Maximum Power Consumption | Approx. 753W |
| Plug | NEMA 5-15P |
| Dimensions | 41" x 37-3/8" x 31-3/8" |
Output Options
| Description | Copy Tray-P1 |
| Total Output Capacity | 250 Sheets (20 lb. Bond) |
| Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size [4" x 5-7/8" to 13" x 19-1/4" |
| Dimensions | 6-7/8" x 16-1/2" x 15" |
| Weight | Approx. 2.9 lb. |
| Description | Staple Finisher-A1 |
| Number Of Trays | 3 |
| Tray Capacity | Tray A: 1,500 Sheets (Letter, Statement-R, Executive) 750 Sheets (13" x 19", 12" x 18", 11" x 17", Legal, Letter-R) Tray B: 250 Sheets (Letter) 125 Sheets (13" x 19", 12" x 18", 11" x 17", Legal, Letter-R, Executive) Tray C: 2,500 Sheets (Letter) 1,250 Sheets (Statement-R, Executive) 750 Sheets (13" x 19", 12" x 18", 11" x 17", Legal, Letter-R) |
| Total Output Capacity | 4,250 Sheets (Letter, Statement-R,Executive) |
| Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, Coated, Textured, Envelopes |
| Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size [(4" x 5-7/8" to 13" x 19-1/4") (100mm x 148mm to 330mm x 488mm)] |
| Staple Positions | Corner/Double Stapling: 11" x 17", Legal, Letter, Letter-R,Executive |
| Max Stapling Capacity | 100 Sheets (20 lb. Bond) (Letter, Executive) 50 Sheets (20 lb. Bond) (11" x 17", Legal, Letter-R) |
| Paper Capacity of Staple Mode | Tray A/C: 1,500 Sheets/100 Sets(Letter, Statement-R, Executive),750 Sheets/50 Sets (13" x 19", 12" x 18",11" x 17", Legal, Letter-R) |
| Type of Staples | Staple-G1 (5,000 x 3) |
| Power Requirement | 100-240V, 50/60Hz, 2.8A |
| Max Power Consumption | 207W |
| Plug | NEMA 5-15P |
| Dimensions | 41" x 25-3/4" (30-3/4"††) x 30-1/8" |
| Weight | Approx. 134 lb. |
| Description | Booklet Finisher-A1 |
| Total Output Capacity | 4,250 Sheets (Letter, Statement-R, Executive) |
| Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre- Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, Coated, Textured, Envelopes |
| Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size [4" x 5-7/8" to 13" x 19-1/4" (100mm x 148mm to 330mm x 488mm)] |
| Staple Positions | Corner Stapling: 11" x 17", Legal, Letter, Letter-R, Executive Double Stapling: 11" x 17", Legal, Letter, Letter-R, Executive Saddle-Stitch: 13" x 19", 12" x 18", 11" x 17", Legal, Letter-R |
| Max Saddle Stitch Capacity | 20 Sheets (including one cover page 110 lb. Bond) (20 lb. Bond) |
| Paper Capacity Saddle Stich Mode | 1 to 5 Sheets/25 Sets, 6 to 10 Sheets/ 15 Sets, 11 to 16 Sheets/10 Sets, 17 to 20 Sheets/5 Sets |
| Type of Staples | Staple-G1 (5,000 x 3) Staple-P1 (5,000 x 2) |
| Power Requirement | 100-240V 50/60Hz, 2.8A |
| Max Power Consumption | 255W |
| Plug | NEMA 5-15P |
| Dimensions | 41" x 30-1/4" (35-1/4"††) x 30-1/8" |
| Weight | Approx. 238 lb. |
| Description | Document Insertion Unit-H1ΔΔ |
| Number Of Trays | 2 |
| Acceptable Media | Covers and Inserts |
| Tray Capacity | Upper: 200 Sheets (20 lb. Bond) Lower: 200 Sheets (20 lb. Bond) |
| Acceptable Paper Type | Thin, Plain, Heavy, Color, Recycled, Pre-punched, Tab, Bond, Letterhead, Coated, Textured |
| Acceptable Paper Size | 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Custom Size [7-1/8" x 7-1/8" to 13" x 19-1/4" (140mm x 182mm to 330mm x 488mm)] |
| Power Requirement | 100-240V/2.8A, 50/60Hz |
| Max Power Consumption | 103W |
| Plug | NEMA 5-15P |
| Dimensions | 55-3/8" x 13-1/4" x 31-1/4" 55-3/8" x 29-3/8" x 31-1/4" (with Insertion Feeding Tray) |
| Description | Paper Folding Unit-G1ΔΔ |
| Folding Method | Roller Pressure Folding |
| Folding Type | Z-Fold, Accordion Z-Fold, C-Fold, Half-Fold, Double Parallel Fold |
| Acceptable Paper Weight | 14 lb. Bond to 28 lb. Bond |
| Acceptable Paper Type | Thin, Plain, Color, Recycled, Bond |
| Acceptable Paper Size | Accordion Z-Fold, C-Fold, Half-Fold: Letter-R Z-Fold: 11" x 17", Legal, Letter-R Double Parallel Fold: Legal, Letter-R |
| Power Requirement | From Finisher |
| Max Power Consumption | 130W |
| Dimensions | 46-7/8" x 13-1/4" x 31-1/4" |
| Weight | Approx. 156.5 lb. |
| Description | Puncher Unit-BF1††† |
| Acceptable Punch Paper Weight | 14 lb. Bond to 140 lb. Index |
| Acceptable Punch Paper Type | Thin, Plain, Heavy, Color, Recycled, Tab, Bond, Letterhead, Coated, Textured |
| Acceptable Punch Paper Size | 11" x 17", Legal, Letter, Letter-R |
| Punch Type | 2 Holes (Legal, Letter-R) 3 Holes (11" x 17", Letter) |
| Distance Between Punch Holes | 2 Holes: 2-3/4" (70mm) 3 Holes: 4-1/4" (108mm) |
| Punch Waste Tray Capacity | Approx. 5,000 Sheets (20 lb. Bond) |
| Max Power Consumption | Approx. 56W (when in operation) |
| Dimensions | Inside the Finisher (15-1/2" x 3-3/4" x 15-1/2") |
| Weight | Approx. 8.2 lb. |
| Description | Professional Puncher-C1/ Professional Puncher Integration Unit-B1ΔΔ |
| Acceptable Punch Paper Weight | Letter (3-hole, 5-hole, Velo Bind 11-hole, Plastic Comb 19-hole, Twin Loop 21-hole/ 32-hole, Color Coil 44-hole): 20 lb. Bond to 80 lb. Cover Letter (ProClick 32-hole): 20 lb. Bond to 65 lb. Cover |
| Acceptable Punch Paper Type | Plain, Heavy, Color, Recycled, Tab, Coated |
| Acceptable Punch Paper Size | Letter |
| Punch Patter Die Sets | Plastic Comb (19-hole) Twin Loop (21/32-hole) Color Coil (44-hole) Velo Bind (11-hole) Loose Leaf (3/5-hole) ProClick (32-hole) |
| Punch Waste Tray Capacity | Approx. 25,000 Sheets or more of 20 lb. Bond with 4 holes punched |
| Power Requirement | 120-127V/5.5A-60Hz |
| Max Power Consumption | Professional Puncher-C1: 300W Professional Puncher Integration Unit-B1: 130W Max. |
| Plug | NEMA 5-15P |
| Dimensions | Professional Puncher-C1: 41" x 12" x 31-1/4" Professional Puncher Integration Unit-B1: 41" x 9-7/8" x 31-1/4" |
| Weight | Professional Puncher-C1: Approx. 176 lb. Professional Puncher Integration Unit-B1: Approx. 88.2 lb. |
| Description | Inner Booklet Trimmer-A1Δ |
| Trimming Method | Face Trim |
| Trim Thickness | 40 Sheets (2mm to 20mm Trimming Width) |
| Waste Tray Capacity | 1,500 Sheets of Trimmed Strips (Width 0.78" (20mm), Letter, 20 lb. Bond) |
| Acceptable Paper Weight | 16 lb. Bond to 110 lb. Cover |
| Acceptable Paper Type | Thin, Plain, Heavy, Recycled, Color, Coated |
| Total Output Capacity | 30 Booklets |
| Max Power Consumption | 51W (when in operation) |
| Dimensions | Inside the Finisher 15-7/8" x 9-7/8" x 24-5/8" |
| Weight | Approx. 70.5 lb. Other Optional Accessories: Operator Attention Light Removable HDD Kit-AB1 3.5-inch/1TB HDD-B1 Key Switch Unit-B1 ADF Access Handle-A1 Remote Viewer-B1 Fontset Simplified Chinese-B1 Fontset Traditional Chinese-B1 Fontset Japanese-B1 Fontset Korean-B1⟩ PRISMAsync license accessories. * Stack Bypass is not available when Multi-Drawer Paper Deck is installed. ** With Operator Panel in left-most position. *** With Operator Panel in right-most position. ♦ Includes ADF, consumables, Operator Panel. † Requires optional accessories. †† When the Auxiliary Tray is extended. ††† Puncher Unit-BF1 installs internally with either Staple Finisher-A1 or Booklet Finisher-A1. Δ Option for Booklet Finisher-A1. ΔΔ Requires Staple Finisher-A1 or Booklet Finisher-A1. |
next to your download
