Canon Support for imageRUNNER ADVANCE DX C3730i | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
MAIN UNIT
TYPEColor Laser Multifunctional
CORE FUNCTIONSStandard: Print, Copy, Scan, Send, Store
Optional: Fax
PROCESSOR1.75 GHz Dual Core Processor
CONTROL PANEL10.1" TFT LCD WSVGA Color Flat-panel
MEMORY3.0 GB RAM
HARD DISK DRIVEStandard: 250 GB/Maximum: 1 TB
INTERFACE CONNECTIONNetwork: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth Low Energy
Others
Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 1,200 Sheets
Maximum: 2,300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)Standard: Dual 550-sheet Paper Cassettes, 100-sheet Multipurpose Tray
Optional: Dual 550-sheet Paper Cassettes (CASSETTE FEEDING UNIT-AP1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)Standard: 250 Sheets
Maximum: 3,450 Sheets (with Staple Finisher-AA1/Booklet FinisherAA1 and Copy Tray-J2)
FINISHING CAPABILITIESStandard: Collate, Group
With Finishers: Collate, Group, Offset, Staple, Saddle Stitch, Hole Punch, Eco Staple, Staple On Demand
SUPPORTED MEDIA TYPESMulti-purpose Tray: Thin, Plain, Heavy, Recycled, Coated, Color, Tracing, Bond, Transparency, Label, Prepunched, Envelope
Upper Cassette: Thin, Plain, Heavy, Recycled, Color, Tracing, Bond, Transparency, Pre-punched, Envelope
Lower Cassette: Thin, Plain, Heavy, Recycled, Color, Bond, Transparency, Pre-punched, Envelope5
SUPPORTED MEDIA SIZES
Multi-purpose Tray: 12"x18", 11"x17", Legal, Letter, Letter-R, Executive, Statement, Statement-R Custom Size/Free Size: 3-7/8" x 5-1/2" to 12-5/8" x 18", Envelopes (COM10 No.10, Monarch, ISO-C5, DL), Envelope Custom Size ( 3-7/8" x 3-7/8" to 12-5/8" x 18")
Upper Cassette: Letter, Executive, Statement-R Custom Size (4-1/8" x 5-7/8" to 11-3/4" x 8-1/2"), Envelopes (ISO-C5)
Lower Cassette: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4-1/8" x 5-7/8" to 12" x 18"), Envelopes1 (COM10 No.10, Monarch, DL)
SUPPORTED MEDIA WEIGHTSCassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Multipurpose Tray: 14 lb. Bond to 110 lb. Cover (52 to 300 g/m2)
Duplexing: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
PRINT/COPY SPEED (BW AND COLOR) Up to 30 ppm (Letter); Up to 20 ppm (Letter-R); Up to 15 ppm (Legal); Up to 15 ppm (11" x 17")
WARM-UP TIMEFrom Power On: Approx. 10 Seconds2
From Sleep Mode: Approx. 10 Seconds3
Quick Startup Mode: Approx. 4 Seconds4
DIMENSIONS (W x D x H)22-1/4" x 28-1/2" x 34-7/8" (565 mm x 722 mm x 887 mm)5
INSTALLATION SPACE (W x D x H)Basic: Multi-purpose Tray + Cassette Drawers open: 38-1/2" x 44" (978 mm x 1118 mm)6
Fully Configured: 65" x 44" (1651 mm x 1118 mm)7
WEIGHTApprox. 175.5 lb. (79.6 kg)8
PRINT SPECIFICATIONS
PRINT RESOLUTION (dpi)1200 x 1200, 600 x 600
STANDARD PAGE DESCRIPTION LANGUAGESUFR II, PCL®6, Adobe® PS® 3
SUPPORTED FILESPDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICESA range of standard and optional software and MEAP-based solutions (including AirPrint, Mopria, Universal Print by Microsoft, Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information.
FONTSPCL Fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),9 Barcode Fonts10
PS Fonts: 136 Roman
OPERATING SYSTEM 11UFRII/PS: Windows®7/8.1/10/Server 2008/Server 2008 R2/Server2012/Server 2012 R2/ Server 2016/Server 2019, Mac OS X(10.10 or later)
PCL: Windows®7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/ Server 2016/Server 2019
PPD: Windows®7/8.1/10, Mac OS X(10.9 or later)
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIMAs fast as 5.9 seconds (BW)/8.2 seconds (Color)
COPY RESOLUTION (dpi)600 x 600
MULTIPLE COPIESUp to 999
MAGNIFICATION25%-400% (1% Increments)
PRESET REDUCTION / ENLARGEMENT25%, 50%, 64%, 73%, 78%, 100%(1:1), 121%, 129%, 200%, 400%
SCAN SPECIFICATIONS
TYPESingle-pass Duplexing Automatic Document Feeder12
DOCUMENT FEEDER PAPER CAPACITYUp to 200 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Custom size: 2-3/4" x 5-1/2" to 12" x 17"
(70 x 139.7 mm to 304.8 x 431.8 mm)
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTSBW/Color Original: 13.3 lb. Bond to 80 lb.
Cover (50 to 220 g/m2)
PLATEN ACCEPTABLE ORIGINALSSheet, Book, 3-Dimensional Objects
PLATEN MAXIMUM SCANNING SIZEUp to 11-3/4" x 17" (297.0 mm x 431.8 mm)
PULL SCANColor Network ScanGear2 for both Twain and WIA
Supported OS: Windows 7/8.1/10/ Server 2008/Server 2008 R2/ Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTIONScan for Copy: 600 x 600
Scan for Send: Push (600 x 600), SMB/FTP/WebDAV, Pull (600 x 600)
Scan for Fax: 600 x 600
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICESA range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER)Single-sided Scanning BW/Color: 135 ipm (300 dpi)/51 ipm (600 dpi)
Double-sided Scanning BW/Color: 270 ipm (300 dpi)/51 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATIONStandard: E-mail/Internet FAX (SMTP), SMB 3.0, FTP, WebDAV, Mail Box
Optional: Super G3 FAX, IP Fax
ADDRESS BOOKLDAP (2,000)/Local (1,600)/Speed Dial (200)
SEND RESOLUTIONPush: Up to 600 x 600 dpi
Pull: Up to 600 x 600 dpi
COMMUICATION PROTOCOLFile: FTP (TCP/IP), SMB 3.0 (TCP/IP), WebDAV
Email: SMTP, POP3
FILE FORMATTIFF, JPEG, PDF(Compact, Searchable, Apply Policy, Optimize for Web, PDF/A-1b, Trace & Smooth, Encrypted, Device Signature, User Signature), XPS (Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word)
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES2
MODEM SPEEDSuper G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHODMH, MR, MMR, JBIG
RESOLUTION400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZEStatement-R to 11" x 17"
FAX MEMORYUp to 30,000 Pages (2,000 Jobs)
SPEED DIALSMax. 200
GROUP DIALS / DESTINATIONSMax. 199 Dials
SEQUENTIAL BROADCASTMax. 256 Addresses
MEMORY BACKUPYes
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED)100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, Maximum 10,000 Pages (2,000 Jobs Stored)
ADVANCED BOXCommunication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 8.1/10)
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACEApprox. 16 GB (Standard HDD)
Approx. 480 GB (With Optional 1 TB HDD)
SECURITY SPECIFICATIONS
AUTHENTICATIONStandard: Universal Login Manager, uniFLOW Online Express,13 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in
Optional: uniFLOW
DATAStandard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control14
Optional: IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORKStandard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (v1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENTStandard: Secure Watermark, Secure Print, Adobe LiveCycle¿ Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Digital Signature, User Signature
Environmental
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENTTemperature: 50 to 86 ºF Humidity: 20 to 80 % RH (Relative Humidity)
POWER REQUIREMENTS110V-127V, 60Hz, 7.5A
POWER CONSUMPTIONMaximum: Approx. 1,500 W
Standby: Approx. 47.0 W15
Sleep Mode: Approx. 0.8 W16
Typical Electricity Consumption (TEC) Rating:17 0.35 kWh
STANDARDS
CONSUMABLES
TONER
GPR-53 Toner18
TONER YIELD (ESTIMATED @ 5% COVERAGE)
Black: 36,000 Images
Color (C,M,Y): 19,000 Images
FOOTNOTES
  1. Envelope Feeder Attachment A (standard) is required.
  2. Time from device power-on, until copy ready (not print reservation).
  3. Time from exiting Sleep mode to when printing is operational.
  4. Time from device power-on to when the copy icon appears and is enabled to operate on the touch panel display.
  5. Includes Single Pass DADF.
  6. With right cover open + Multi-purpose tray extension extended + paper cassette open.
  7. Includes Staple Finisher-AA1/Booklet Finisher-AA1 + Copy Tray-J2 extension extended + paper cassette open.
  8. Includes toner.
  9. Requires the optional PCL International Font Set-A1.
  10. Requires the optional Barcode Printer Kit-D1.
  11. Other operating systems and environments, including AS/400, UNIX, Linux and Citrix, may be supported. Some solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  12. Detect Feeder Multi Sheet Feed is supported.
  13. No charge for this solution; however activation is required.
  14. Requires Unified Firmware Platform v3.9 or greater.
  15. Reference value (measured one unit).
  16. 0.8 W sleep mode not available in all circumstances due to certain settings.
  17. Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
  18. GPR-53L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 8,500 images.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
