Canon Support for KS-1200TS | Canon U.S.A., Inc.
KS-1200TS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
Display
| Display Type | Liquid Crystal Display |
| Digits Displayed | 12-digits |
| Adjustable Display | No (Fixed angle) |
Functionality
| Decimal Point System | '+(Add mode) 4 3 2 1 0 F (Floating position) |
| Rounding | up / off / down |
| Square | Yes |
| Tax Calculation Tip | Yes |
| Types Of Calculation | Cost-Sell-Margin & Tax |
| Automatic Power Off | Approx. 7 minutes |
| Battery Solar | Yes |
| Sign Change | Yes |
| Memory | (M+=, M-=, RM/CM) |
| Double Zero Triple Zero | Double Zero |
General
| Dimensions | 7.80" (L) x 5.91" (W) x 1.5" (H) 172 x 107 x 24 mm |
| Weight | 6.5 oz. (183g) |
Calculator Warranty
The limited warranty set forth by Canon U.S.A., Inc., (Canon U.S.A.) and Canon Canada Inc., (Canon Canada) with respect to Calculators purchased in the United States and Canada respectively.
This limited warranty is only effective upon presentation of proof of purchase (bill of sale) to a Canon U.S.A. or Canon Canada Factory Service Center. Canon Calculators, when delivered to you in a new condition in the original container, are warranted against defective materials or workmanship as follows: for a period of one (1) year from the date of purchase, defective parts or Calculators returned to a Canon U.S.A. or Canon Canada Factory Service Center and proved to be defective upon inspection, will be exchanged at Canon U.S.A. or Canon Canada sole option, for new comparable rebuilt parts or calculators (of the same or similar model). Warranty for replacement shall not extend the original warranty period of the defective calculator.
When returning Calculators under this warranty, you must pre-pay the shipping charges, if any, and enclose a complete explanation of the problem. Calculators covered by this limited warranty will be repaired at Canon U.S.A. or Canon Canada sole option, and returned to you without charge by any Canon U.S.A. or Canon Canada Factory Service Center. This warranty does not cover rechargeable batteries that may be supplied with the Calculator , as to which batteries there shall be no warranty or replacement.
A listing of Canon U.S.A. CONSUMER PRODUCTS INFORMATION CENTER AND CANON INFORMATION/SERVICE CENTER in Canada is included with the Calculator. The Canon U.S.A. CONSUMER PRODUCTS INFORMATION CENTER and CANON CANADA INFORMATION/SERVICE CENTER will refer you to the nearest Factory Service Center. Repairs not under warranty will be at such cost as Canon U.S.A. or Canon Canada may from time to time generally establish.
This limited warranty covers all defects encountered in normal use of the calculators, and does not apply to the following cases:
- Loss or damage to the Calculators due to abuse, mishandling, alteration, accident, electrical current fluctuations, failure to follow operating instructions, maintenance and environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's manual or service performed by other than a Canon U.S.A. or Canon Canada Factory Service Center.
- Use of parts (other than those distributed by Canon U.S.A. or Canon Canada) which damage the Calculator or cause abnormally frequent service calls or service problems.
- If any Calculator has had its serial number or dating altered or removed.
- Loss or damage to the Calculator due to leaking batteries (other than rechargeable batteries supplies as original equipment with the Calculator by Canon U.S.A. or Canon Canada) or water damage.
NO IMPLIED WARRANTY (OR CONDITION)* INCLUDING ANY IMPLIED WARRANTY (OR CONDITION)* OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE CALCULATORS AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY STATED ABOVE. AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY OTHER PERSON, FIRM OR CORPORATION WITH RESPECT TO THE CALCULATORS SHALL BIND CANON U.S.A. OR CANON CANADA. (SOME STATES OR PROVINCES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU) NEITHER CANON U.S.A. OR CANON CANADA SHALL BE LIABLE FOR LOSS OF REVENUE OR PROFITS, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, OR FOR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSE BY THE USE, MISUSE, OR INABILITY TO USE THE CALCULATOR, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON U.S.A. OR CANON CANADA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON U.S.A. OR CANON CANADA BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE CALCULATOR SOLD BY CANON U.S.A. OR CANON CANADA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS. DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE, OR INABILITY TO USE THE CALCULATOR SOLD BY CANON U.S.A. OR CANON CANADA NOT CAUSE DIRECTLY BY THE NEGLIGENCE OF CANON U.S.A. OR CANON CANADA . (SOME STATES OR PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF ANY CALCULATOR OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT AND STATES YOUR EXCLUSIVE REMEDY.
This warranty gives you specific legal rights, and you may also have other rights. which vary from state to state or province to province.
Canon U.S.A., Inc. One Canon Park, Melville, NY 11747
Canon Canada 6390 Dixie Road, Mississauga, Ontario L5T 1P7 *Canada
Canon Consumer Information/Service Centers in the United States
For all general inquiries, operational assistance, accessory orders or for the location of the nearest service facility for this product, please contact Canon U.S.A., Inc at 1-800-828-4040. Please keep a copy of your original bill of sale. In order to obtain warranty service, you will need to provide a copy of your original bill of sale from your consumer calculator retailer at the time of service. Also, please keep all packing materials and the original packing box to protect your equipment, should you need to transport it for service.
Canon Information/Service Centers in Canada
Should service be necessary, please call 1-800-OK-CANON for information regarding the nearest Authorized Service Facility.
next to your download
