Canon Support for LX-MU700 | Canon U.S.A., Inc.
LX-MU700
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
| Standard / Presentation / Dynamic / Video / Cinema / Photo / sRGB / Vivid Photo / DICOM SIM / User 1 / User 2 / User 3 / User 4 / User 5 | |
| (Input) HDMI | |
| Digital RGB Input | |
| (Input) DVI-D 29pin | |
| Digital RGB / Digital Video Input (supports Deep Color) | |
| (Input) Mini D-Sub 15pin | |
| Analog RGB / Component Video Input | |
| Power | |
| 336W |
Projector Specifications
| Imaging Device | DLP x1 |
| Aspect Ratio | 16:10 |
| Native Resolution | 1920 x 1200 (WUXGA) |
| Brightness | 7500 Lumens (Dual Lamp, Lamp Mode: Normal)*2*3 |
| Uniformity | 85%*2 |
| Contrast Ratio | 2100:1*2 |
| Digital Keystone (Vertical) | ± 40 degrees |
| Digital Keystone (Horizontal) | ± 40 degrees |
Optics
| Zoom | Powered |
| Focus | Powered |
Image Adjustments
| Image Mode | Presentation, Standard, Video |
| Mounting | Front table, Rear table, Front ceiling, Rear ceiling, Upward & Downward. |
Input Signals
| Scanning Frequency | H: 15.62 , 91.15 KHz, V: 24 , 85.06 Hz |
| Analog PC Input | WUXGA/WSXGA+ /UXGA/SXGA+/WXGA+/WXGA/SXGA/XGA/SVGA/VGA |
| Digital PC Input | WUXGA/WSXGA+ /UXGA/SXGA+/WXGA+/WXGA/SXGA/XGA/SVGA/VGA |
| Component Input | 1080p/1080i/720p/576p/480p |
| Digital Video Input | 1080p/1080i/720p/576p/480p/576i/480i |
Terminals
| (Input) D-Sub 15pin | Analog PC / Component Video Input |
| (Input) 5BNC | Analog PC / Component Video Input |
| (Input) RJ-45 | HDbaseT Input / Network Connection (100BASE-TX / 10BASE-T) |
| (Input) Stereo Mini Jack | Audio Input x2 |
| (Output) D-Sub 15pin | Image Output |
| (Output) Stereo Mini Jack | Audio Output x1, Connecting Wired Remote |
| Control Terminal | Dsub9: RS-232 Connection USB Mini B: Service Port RJ-45: Network Connection (1000BASE-T / 100BASE-TX / 10BASE-T) |
Lamp
| Lamp Type | Super-high Pressure Lamp (x2) |
| Lamp Life | 2000 (Normal), 4000 (Eco) Hours |
Ratings
| Fan Noise (Quiet/Normal) | Dual Lamp: 41/36 dB, Single Lamp: 38/35/ dB *1 |
| Power Consumption (Normal/Quiet/Stand-By) | Dual Lamp: 850/680W, Single Lamp: 440/370W *1 |
| Heat Dissipation | Up to 2,901 BTU/h |
| Power Voltage | AC 100 - 240V, 50/60Hz |
| Temperature Operating | 40°F - 104°F (0°C - 40°C) |
| Dimension (WxHxD) | 19.8" x 20.8" x 8.7" |
| Weight | 42.2 lbs. *5 |
| Warranty | 3 Years (parts and labor),120 Days lamp |
| 1.49 - 2.24:1 | |
| Focal Length | |
| 23.0 - 34.5 mm, 1.5x Optical Zoom | |
| F-Number | |
| 1.89 - 2.65 | |
| Projection Distances | |
| 4.26 - 95.14 ft. (1.3 - 29 m) | |
| Lens Shift (Vertical) | |
| Down 15% to Up 55% | |
| Lens Shift (Horizontal) | |
| Left 10% to Right 10% | |
| Screen Sizes | |
| 40" - 600" | |
| Throw Ratio | |
| 2.19 - 3.74:1 | |
| Focal Length | |
| 34.0 - 57.7 mm, 1.7x Optical Zoom | |
| F-Number | |
| 1.99 - 2.83 | |
| 6.23 - 159.12 ft. (1.9 - 48.5 m) | |
| Screen Sizes | |
| 40" - 600" | |
| Throw Ratio | |
| 0.80:1 | |
| Focal Length | |
| 12.8 mm | |
| F-Number | |
| 2.0 | |
| 2.26 - 17 ft. (0.69 - 5.17m) | |
| Down 5% to Up 5% | |
| Left 2% to Right 2% | |
| Screen Sizes | |
| 40" - 300" | |
| Throw Ratio | |
| 3.55 - 6.94:1 | |
| Focal Length | |
| 53.6 - 105.6mm, 1.95 x Optical Zoom | |
| F-Number | |
| 2.34 - 2.81 | |
| 15.1 - 292 ft. (4.6 - 89.0m) | |
| Screen Sizes | |
| 60" - 600" | |
| Throw Ratio | |
| 1.00 - 1.50:1 | |
| Focal Length | |
| 15.56 - 23.44mm, 1.5x Optical Zoom | |
| F-Number | |
| 2.09 - 2.34 | |
| 2.95 - 64 ft. (0.9 - 19.5m) | |
| Screen Sizes | |
| 40" - 600" |
CANON LASER PROJECTOR LIMITED WARRANTY
Canon U.S.A., Inc. (“Canon U.S.A.”) and Canon Canada Inc. (“Canon Canada”) warrant to the original end-user purchaser that this Canon Laser Projector (the "Product"), when purchased and used in the United States or Canada, will be free from defects in workmanship and materials as follows: (a) for a period of five (5) years or 12,000 hours from the date of original purchase, whichever occurs first, under Normal Use and Service (as defined herein), or (b) for a period of one (1) year from the date of original purchase, under Extended Use and Service (as defined herein). Canon U.S.A. and Canon Canada are collectively referred to herein as “Canon”. "Normal Use and Service" means that use of the Product does not exceed an average of sixty (60) hours per week. Product usage in excess of “Normal Use and Service” is considered "Extended Use and Service". “Accessories” will be free from defects in workmanship and materials for a period of one (1) year from the date of original purchase. “Accessories” means any item packaged in the same box as the Product, except for consumable items, if any. The Product and Accessories are collectively referred to in this Limited Warranty as "Equipment". During the warranty period for the Product, and depending upon the service selected, Product returned to a Canon repair facility and proven to be defective upon inspection will, in Canon's sole discretion and without charge, be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts; (b) exchanged for a new Product or; (c) exchanged for a refurbished or reconditioned Product, as determined by the Canon repair facility. During the warranty period for the Accessories, Canon will, in its sole discretion and without charge, exchange defective Accessories for new, refurbished or reconditioned Accessories. This Limited Warranty does not cover consumable items as to which there is no warranty or replacement. Warranty exchange or replacement does not extend the original warranty periods of the Equipment.
ADVANCED WARRANTY EXCHANGE SERVICE PROGRAM
The Advanced Warranty Exchange Service Program (the “Program”) is a program in which a replacement Product is sent to you by Canon and you return to Canon the Product you originally purchased, which becomes the property of Canon. To use the Program, contact a Canon Customer Care Representative using the applicable Canon contact information below. The Canon Customer Care Representative will attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the Canon Customer Care Representative determines that the Product is eligible for coverage under this Limited Warranty and that the problem cannot be corrected over the telephone, a reference number and an End User Activation Form will be issued to you. Submission of your signed End User Activation Form (the “Form”) will activate your request for an exchange, and the terms and conditions in the Form will govern Canon’s provision of services under the Program. The Form, including the Program terms and conditions, can be found at:
for Canon U.S.A. [www.usa.canon.com/AdvancedWarrantyExchange]
for Canon Canada [www.canon.ca/AdvancedWarrantyExchange]
MAIL-IN SERVICE
MAIL-IN SERVICE is a program under which your Product is repaired by a Canon U.S.A. or a Canon Canada authorized service center. Authorized service center information can be obtained by visiting www.usa.canon.com/support (US customers only) or by contacting the Canon U.S.A., Customer Care Center or Canon Canada Customer Care Department at 1-800-OK-CANON (1-800-652-2666). When you call, have your Product serial number and your date of purchase available to expedite service. A Canon Customer Care representative will attempt to diagnose the nature of the problem and correct it over the telephone. If the problem cannot be corrected over the telephone, you will be asked to follow the applicable procedures for MAIL-IN SERVICE. Note that a dated proof of purchase is required at the time of service. This requirement will be satisfied by providing a copy of your dated bill of sale.
You will be given the name, address and phone number of an authorized service center for the Product. It is your responsibility to properly package and send the defective Product, together with a copy of your dated proof of purchase, a complete explanation of the problem and a return address, to the authorized service center at your expense. Do not include any other items with the defective Product. The Product covered by this Limited Warranty and proven to be defective upon inspection will be repaired and returned to you without charge by the authorized service center. Any Product received by the authorized service center that is not covered by the Limited Warranty will be returned unrepaired, or at the discretion of the authorized service center, you may receive a written estimate of repair at such cost as the authorized service center may establish from time to time.
This Limited Warranty shall only apply if the Equipment is used in conjunction with compatible computers, peripheral equipment and software. Canon shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD "AS IS", WITHOUT WARRANTY OR CONDITION OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES, REPRESENTATIONS AND CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES, REPRESENTATIONS AND CONDITIONS REGARDING MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE EQUIPMENT. NO OTHER EXPRESS WARRANTY, REPRESENTATION, CONDITION OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE EQUIPMENT WILL BIND CANON. NO WARRANTY IS GIVEN ON ANY USED EQUIPMENT.
This Limited Warranty shall be void and of no force and effect if the Equipment is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon's instruction manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon who are acting in accordance with Canon's service bulletins, (d) use of supplies or parts (other than those distributed by Canon) which damage the Equipment or cause abnormally frequent service calls or service problems, or (e) use of the Equipment with non-compatible computers, peripheral equipment or software, including the use of the Equipment in any system configuration not recommended in any manual distributed with the Equipment. Nor does this warranty i) extend to any Equipment on which the original identification marks or serial numbers have been defaced, removed or altered, ii) cover the adjustment of customer-operated controls as explained in the instruction manual, iii) extend to any external interface equipment, iv) apply to the cabinet or cosmetic parts, knobs or routine maintenance, or v) cover uncrating, set up, installation, removal of the Equipment for repair or reinstallation of the Equipment after repair.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE EQUIPMENT, CONTAINED ON THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE EQUIPMENT OR DOWNLOADED FROM CANON'S WEB SITE), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE EQUIPMENT IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CANON WILL NOT BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, STORAGE CHARGES OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT OR ANY COMPONENT THEREOF, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR WILL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE EQUIPMENT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE EQUIPMENT SOLD BY CANON NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON THIS WARRANTY WILL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE EQUIPMENT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
In order to obtain warranty service:
Canon U.S.A.
You may obtain technical support* for the Equipment as follows:
Canon Canada
E-mail support via our Web site at www.canon.ca/support
* Technical support program specifics subject to change without notice.
CANON U.S.A., INC
CANON CANADA INC.
next to your download
