Canon Support for MegaTank MAXIFY GX2020 | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.07.25
File Size 63.10 KB
Date 08.28.24
File Size 771.01 KB
Date 05.25.25
File Size 5.20 MB
Date 10.03.23
File Size 150.17 KB
Date 08.28.24
File Size 760.69 KB
Date 08.28.24
File Size 770.22 KB
Date 10.14.25
File Size 6.14 MB
Date 08.28.24
File Size 781.78 KB
Date 10.03.23
File Size 150.17 KB
Date 10.28.25
File Size 1.16 MB
Date 12.08.25
File Size 6.13 MB
Date 10.13.26
File Size 78.41 KB
Date 10.14.25
File Size 5.99 MB
Date 10.28.25
File Size 1.15 MB
Date 12.08.25
File Size 6.10 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Print and scan wirelessly from any Wi-Fi® enabled computer, Android™ or iOS tablet and smartphones from your local network connection. Wireless printing requires a working network with wireless 802.11b/g/n capability. You will need a Wi-Fi enabled Computer or mobile device, a wireless router and a wireless printer. All devices must be connected to the same wireless network connection. Click on the specific topic below to get detail information.
Wireless Setup
Need additional information or assistance?
Products Windows 7 Windows 10 Windows 11
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
Products ChromeOS
Print
Printer Functions Print, Copy, Scan, Fax
Print Features Document Printing, Photo Printing, Wireless PrintingFootnote8, Mobile Device Printing, Business Card Printing, Greeting Card Printing, Label Printing, Square Media Printing Support, Double-sided Matte Paper Support, Auto Duplex Printing
Printing Capability Single Sided (Simplex/Duplex) Printing
Fast First Print Out (FPOT) As fast as 9 Seconds = BW (from Ready Mode/Simplex)Footnote9
As fast as 11 Seconds = CL (from Ready Mode/Simplex)Footnote9
Print Speed (ESAT) Black Document Simplex: Approx. 15.0 ipm (Letter)Footnote9
Color Document Simplex: Approx. 10.0 ipm (Letter)Footnote9
Print Resolution Up to 600 x 1200 dpiFootnote10
Number of Nozzles Color (C/M/Y): 768x3 / Pigment Black: 832 / Total: 3,136
Duty Cycle Up to 27,000 Pages / Month
Media Handling 1 Cassette: 250 sheets
Supported Paper / Media Sizes Cassette: LTR, A5, B5, A4, 4" x 6", 5" x 7", 7" x 10", 8" x 10"
Custom Size: 3.5 - 8.5 / Length: 5.0 x 14.0
Canon Paper / Media Compatibility Plain: Plain Paper, Canon High Resolution Paper; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster; Matte: Matte Photo Paper, Double-sided Matte Paper; Other (Canon): Magnetic Photo Paper, Restickable Photo Paper; Other (non-Canon): Cardstock, Greeting Card, U.S. #10 Envelopes, Recycled Paper and Chlorine-free Paper can be used
Supported Media Thickness / Weight Cassette: Plain Paper: 64 - 105 g/m2 OR Canon Paper: Max. approx. 265 g/m2 (Canon Photo Paper Plus Glossy II)
Copy
Copy Features Standard Copy, Two Side Copy, Manual Two- Sided Copy with ADF, 4-on-1 / 2-on-1 Copy, Document Copy, Collated Copy, Frame Erase Copy (Flatbed Only), ID Card Copy, Auto Exposure Copy, Preset Copy Ratios, Reduction / Zoom Copy (25% - 400%), Fit-to- Page, Preview
Copy Speed FCOT (Color/Simplex): Approx. 17 secondsFootnote9
Maximum Document Size Flatbed: Letter / A4
ADF: Legal
Scan & ADF
Scan Features Save to PC, Attach to E-mail, Multi-Page PDF, Scan to Folder
Scanner Type Flatbed / ADF
Scanning Method Contact Image Sensor (CIS)
Scanning Resolution 1200 x 2400 dpi (Optical)Footnote11
Maximum Color Scanning Bit Depth Grayscale: 16-bit / 8-bit
Color: 16-bit / 8-bit Per Color
ADF: Legal
ADF Sheet Capacity Letter Size: 35 Sheets Plain Paper
Legal Size: 5 Sheets Plain Paper
Fax
Fax Features Caller Rejection, Fax Reception Reject, Fax Number Reentry, Check RX Fax Info, Dial Search, Memory Transmission, Remote Reception, Redial, Double Sided Printing (fax images), FAX to Folder
Fax Resolution Up to 300 x 300 dpi (Extra Fine)
Modem Speed Max. 33.6 kbps (Automatic Fall Back)Footnote12
Transmission Speed Black: Approx. 3 sec Color: Approx. 1 minFootnote13
Memory Capacity Approx. 250 pagesFootnote14
Group Dialing Max. 99 locations
Ink Information
Ink System & Information 4-Color Pigment Continuous Ink Supply System (CISS), FINE Print Heads, Integrated Ink Tanks, Squeeze-Free Ink Bottles For Easy & Mess Free Ink Filling, Unique Color Bottle Tip Shape for Correct Filling Every Time
Ink Type GI-25 Pigment-Based Ink Bottles (Cyan, Magenta, Yellow, Black)
Ink Tank & Fill Volume GI-25 Black Ink Bottles: 70.0 ml
GI-25 C, M, Y Ink Bottles: 37.0 ml (each)
High Page Yield Up to 3,000 (Black & White) / 3,000 (Color) Pages (Per Full Ink Bottle Set)
(Set Up Ink Bottles are slightly larger - Black 91ml / C,M,Y 53 ml)Footnote6
CONNECTIVITY & SOFTWARE/APPS
Connectivity Options Hi-Speed USB
Wi-Fi® (Wireless LAN, 2.4/5 GHz, IIEEE 802.11b/g/n/a/ac)
Wired LAN 100BASE-TX / 10BASE-T
Wireless Information Standard: IEEE 802.11b/g/n/a/ac
Security: WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES), WPA3-SAE (AES)
Wireless LAN Frequency Band(s): 2.4 GHz / 5 GHz
Wireless Direct Connection Capable/ Wireless ConnectFootnote1 Capable: Yes
OS Compatibility Windows:Footnote15 Windows® 11, Windows® 10, Windows® 8.1, Windows® 7 SP1; Windows Server 2008 R2 SP1, Server 2012 R2, Windows Server 2016, Windows Server 2019, Windows Server 2022
Mac:Footnote16 macOS v10.15.7 - 13
Mobile Operating Systems:Footnote17 iOS®, iPadOS, Android
Chromebook Compatible18: Yes
Smart Assistant Support Amazon AlexaFootnoteTM,19
Mobile Printing Solutions & Apps (iOS®/ ANDROID) AirPrint®Footnote3, Mopria® Print ServiceFootnote4, Canon PRINT appFootnote2, Easy PhotoPrint Editor AppFootnote20, Canon Print ServiceFootnote21 (Android), PIXMA Cloud LinkFootnote2, Creative Park AppFootnote22
Software MAXIFY GX2020/GX1020 Driver, Easy-PhotoPrint Editor SoftwareFootnote20, PosterArtist Web Version SoftwareFootnote7, Canon Inkjet Smart Connect
General
General Features Auto Power On/Off, Print/Scan/Copy, Quiet Mode, Wireless Direct ConnectionFootnote1, Wireless ConnectFootnote1, Auto Paper Width Detection, User Replaceable Print Head, User Replaceable Maintenance Cartridge.
Display 2.7 LCD Touch Screen
Supported Languages 33 Supported Languages: Japanese, English (mm & inch), German, French, Italian, Spanish, Portuguese, Dutch, Danish, Norwegian, Swedish, Finnish, Russian, Ukrainian, Polish, Czech, Slovenian, Hungarian, Slovakian, Croatian, Romanian, Bulgarian, Turkey, Greek, Estonian, Latvian, Lithuanian, Simplified Chinese, Korean, Traditional Chinese, Thai, Indonesia, Vietnamese
Power Information Energy Efficiency: Rated EPEAT Gold, Energy Star® CertifiedFootnote23
Auto Power On / Off Capable: Yes
Input Voltage: AC 100 240 V, 50 / 60 Hz
Power Consumption: 22W (0.8W Standby / 0.1W Off)
TEC (Typical Electricity Consumption): 0.14 kWh
Sound Management Quiet Mode: Available
Noise Level: Approx. 46.5 dB(A) (Plain Paper)
Operating Environment Operating Temperature: 41° - 95° F (5° - 35° C)Footnote24
Operating Humidity: 10 - 90% RHFootnote24
Printer Size (Closed) L x W x H 14.8 x 15.0 x 8.9
Printer Size (Trays Extended) L x W x H 14.8 x 20.1 x 10.3
Printer Weight Approx. 17.8 lbs.
Note Specifications are subject to change without notice. All viewscreen and output images are simulated.
Canon U.S.A., Inc. LIMITED WARRANTY – (USA Only)
The limited warranty set forth below is given by Canon U.S.A., Inc. (“Canon USA”) with respect to the new or refurbished Canon-brand MAXIFY GX-Series inkjet printer product (“Product”) packaged with this limited warranty, when purchased and used in the United States only. This limited warranty will apply to a warranty repaired or replacement Product only as set forth below.
The Product is warranted against defects in materials and workmanship under normal use and service for three (3) years from the date of original purchase, or the printing of 60,000 pages, whichever comes first. Product returned to a Canon USA repair facility, and proven to be defective upon inspection, in Canon USA’s sole discretion and at no charge, will be (a) repaired utilizing new, remanufactured, repaired and/ or recycled parts (b) exchanged for new Product or; (c) exchanged for a refurbished Product, as determined by Canon USA, Inc. This limited warranty applies to a warranty repaired or replacement Product only as follows: a warranty repaired or replacement Product will be warranted under this limited warranty only until the end of the warranty period of the original Product purchased. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink bottles, or maintenance cartridges, as to which there shall be no warranty or replacement. This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold “as is” and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
a) Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA’s user’s manual or other documentation, or services performed by someone other than a Canon USA repair facility. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user’s manual or other documentation for the Product.
b) Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink bottles or refilled ink bottles, that cause damage to the Product or cause abnormally frequent service calls or service problems.
c) If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON, OR IN, THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER’S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER’S LICENSE AGREEMENT.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE PRODUCT. NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT. CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU.) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
A range of Canon USA customer technical support* options are available:
• Interactive troubleshooting, the latest driver downloads, hours of operation, and answers to frequently asked questions (www.usa.canon.com/support)
• Toll-free live technical support Monday–Friday (excluding Canon-observed holidays) at 1-844-4-MAXIFY (1-844-462-9439)
• Telephone Device for the Deaf (TDD-1-855-270-3277)
• Warranty Service:
In the event service is required for the Product during the limited warranty period, a Canon USA Customer Care Center representative will attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the problem cannot be corrected over the telephone, you will be provided instructions for Canon USA’s then current warranty service procedures. You may be asked for the Product serial number and/or other information pertaining to your Product.
This limited warranty give you specific legal rights, and you may also have other rights, which vary from state to state.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747 USA
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
