Canon Support for PIXMA TR4522 | Canon U.S.A., Inc.
PIXMA TR4522
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.07.25
File Size 63.10 KB
Date 10.07.25
File Size 78.41 KB
Date 10.14.25
File Size 6.14 MB
Date 08.10.23
File Size 14.02 MB
Date 05.25.25
File Size 5.20 MB
Date 08.19.18
File Size 12.78 MB
Date 09.13.18
File Size 12.10 MB
Date 09.13.18
File Size 14.16 MB
Date 10.14.25
File Size 6.26 MB
Date 10.14.25
File Size 4.52 MB
Date 10.14.25
File Size 4.62 MB
Date 10.28.25
File Size 1.16 MB
Date 10.28.25
File Size 1.15 MB
Date 12.08.25
File Size 6.13 MB
Date 08.10.23
File Size 12.78 MB
Date 08.10.23
File Size 12.01 MB
Date 12.08.25
File Size 6.10 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Print and scan wirelessly from any Wi-Fi® enabled computer, Android™ or iOS tablet and smartphones from your local network connection. Wireless printing requires a working network with wireless 802.11b/g/n capability. You will need a Wi-Fi enabled Computer or mobile device, a wireless router and a wireless printer. All devices must be connected to the same wireless network connection. Click on the specific topic below to get detail information.
Wireless Setup
Need additional information or assistance?
Products Windows 8 Windows 10 Windows 10s Windows 11
PIXMA TR4522 1
PIXMA TR4522
Products ChromeOS
PIXMA TR4522
Printer
Print Speed (up to) 4" x 6" Photo: Approx. 70.0 Seconds (Borderless)Footnote11
Black:ESAT Approx. 8.8 ipmFootnote11
Color:ESAT Approx. 4.4 ipmFootnote11
Number of Nozzles Color: 960 / Pigment Black: 320 / Total: 1,280
Print Resolution (Up to) Up to 4800 x 1200 dpiFootnote12
Ink Compatibility INK TYPE
PG-245/PG-243 Pigment Black Ink
CL-246/CL-244 Dye Based Inks
INK TANK & FILL VOLUME
PG-245 Black 8.9 ml (Std.) | 12.0 ml (XL)
CL-246 Color 9.0 ml (Std.) | 13.0 ml (XL)
PG-243 Black 5.6 ml
CL-244 Color 6.2 ml
Paper Sizes 4" x 6", 5" x 7", 8" x 10", Letter, Legal, U.S. #10 Envelopes
Paper Compatibility Plain: Plain Paper, Canon High Resolution Paper;
Super High Gloss: Photo Paper Pro Platinum;
Matte: Matte Photo Paper
Other: Greeting Cards, T-Shirt Transfers, U.S. #10 Envelopes
Printer Features AirPrintFootnote2, Mopria® Print ServiceFootnote5, Auto 2-Sided (Duplex) Printing, Borderless PrintingFootnote4, Canon PRINT appFootnote3, Document Printing, Easy-PhotoPrint Editor Software/appFootnote8, Greeting Cards, Message In PrintFootnote10, Photo Printing, Template Print, Wireless PrintingFootnote1
Paper Handling Front Paper Cassette: 100 Sheets of Plain Paper OR 20 Sheets of 4" x 6" / 10 Sheets of 5" x 7" Photo Paper
Copier
Copy Speed (up to) FCOT (Color): Approx. 27 seconds Footnote12
Document Feeder Capacity: 20 Sheets of Plain Paper / 5 Sheets of Legal Size Paper
Copy Features 4-on-1/2-on-1 Copy, Auto Document Feeder (ADF), Auto Exposure (AE) Copy, Borderless Copy, Collated Copy (ADF Only), Document Removal Reminder, Fit-to-Page, Frame Erase Copy (Flatbed Only), ID Card Copy, Multiple Copy (Up To 99 Pages), Preset Copy Ratio, Reduction/Enlargement (25% - 400%), Standard Copy, Two Sided Copy
Scanner
Scanner Type Flatbed & ADF (Auto Document Feeder)
Scanning Element Contact Image Sensor (CIS)
Max. Resolutions Optical:Flatbed: 600 x 1200 dpi (Optical)Footnote14
ADF: 600 x 600 dpi (Optical)Footnote14
Scanner Features Auto Document Feeder (ADF), Auto Scan ModeFootnote13, Document Removal Reminder, Save to PC, Scan to Canon PRINT AppFootnote3, Multi-Page PDF, Wireless ScanningFootnote1
Color Depth 16-bit Internal (Per RGB Channel)
8-bit External (Per RGB Channel)
Max. Document Size Flatbed: 8.5" x 11.7" (Letter/A4)
ADF: 8.5" x 14.0" (Legal)
Fax
Modem Speed Up to 33.6 Kbps (Super G3 Color Fax)Footnote15
Transmission Speed (approx.) Black: Approx. 3 Seconds per PageFootnote16
Color: Approx. 60 Seconds (1 Minute) per PageFootnote16
Memory Capacity Approx. 50 PagesFootnote15
Group Dialing 19 Locations
Fax Features Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Dial Search, Double Sided Printing (Fax Images), Extra Fine Mode, Fax Reception Reject, Fax Number Re-Entry, Memory Transmission, Redial, Remote Reception
Photo Connect
Media Card Support SD, SDHC, SDXC, miniSD, miniSDHC, microSD, microSDHC , microSDXC Footnote12
General
Other Features Full Dot Matrix LCD, Auto Power On/Off, Canon PRINT appFootnote3, CREATIVE PARK PREMIUMFootnote18, Document Removal Reminder, Energy Star® Certified, FINE (Full-photolithography Inkjet Nozzle Engineering) Cartridge, Hybrid Ink System, Wireless Connect Footnote6
OS Compatibility Windows:Footnote19 Windows® 10, Windows 8.1, Windows 7 SP1
Mac:Footnote20 Mac OS® X v10.10.5 - macOS v10.13 (High Sierra)
Mobile Operating Systems:Footnote21 iOS®, Android™, Windows 10 Mobile, and Fire OS (Amazon Fire) devicesFootnote22
Standard Interface Hi-Speed USB
Wi-Fi® (802.11b/g/n wireless networking, 2.4 GHz)Footnote1
Software Included (WINDOWSFootnote19/MACFootnote20)
PIXMA TR4522 Wireless Office All-In-One Printer Driver
Scan Utility (Win/Mac) / Scan Utility Lite (Mac Only)
Easy-PhotoPrint Editor SoftwareFootnote8
Master Setup
My Printer (Windows Only)
Quick Menu
Dimension (W x D x H) (Closed) 17.2" (W) x 11.7" (D) x 7.5" (H)
(Paper Installed) 17.2" (W) x 16.2" (D) x 7.5" (H)
Weight 13.0 lbs.
Warranty 1-Year Limited Warranty with InstantExchange Program.Footnote23
SMART ASSISTANT & AUTOMATION SUPPORT IFTTT (IF This Then That) SupportFootnote7
MOBILE APPS (iOS®/ ANDROID™) Canon PRINT appFootnote3
Easy-PhotoPrint Editor appFootnote8
Message In Print appFootnote10
Limited Warranty & InstantExchange Program Details
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the new or refurbished Canon-brand product ("Product") packaged with this limited warranty, when purchased and used in the United States only.
The Product is warranted against defects in materials and workmanship under normal use and service (a) for a period of one (1) year from the date of original purchase when delivered to you in new condition in its original container or (b) for (1) year from the date of original purchase for refurbished Products. Product returned to a Canon USA repair facility or a Canon USA Authorized Service Facility ("ASF"), and proven to be defective upon inspection will be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts (b) exchanged for new or; (c) exchanged for a refurbished Product, as determined by the Canon USA repair facility or the ASF. Warranty repair or replacement shall not extend the original warranty period of the Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold "as is" and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
  1. Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility or ASF. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user's manual or other documentation for the Product.
  2. Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink cartridges or refilled ink cartridges, that cause damage to the Product or cause abnormally frequent service calls or service problems.
  3. If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROMS ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
Canon USA offers a full range of customer technical support* options:
Interactive troubleshooting, the latest driver downloads, hours of operation, and answers to frequently asked questions (www.usa.canon.com/support)
Toll-free live technical support Monday–Friday (excluding Canon-observed holidays) at 1-800-OK-CANON (1-800-652-2666)
Telephone Device for the Deaf (TDD-1-855-270-3277)
Repair or Exchange Service Options: In the event service is required for the Product during the limited warranty period, Canon USA offers two hardware support options:
Canon USA's Carry-In/Mail-In Service provides repair or exchange, at Canon USA's option, through Canon USA's Authorized Service Facility (ASF) network. The name and telephone number of the ASF(s) near you may be obtained from Canon USA's Web site at www.canontechsupport.com or by calling the Canon USA Customer Care Center at 1-800-828-4040, or any time while speaking to a technical support person. A Product covered by this limited warranty will be repaired or exchanged, as determined by Canon USA, and returned without charge by the ASF.
InstantExchange Service**
The Canon USA repair facility will ship out the replacement Product prepaid by Canon USA. After receipt of the replacement Product (with instructions and a prepaid waybill), follow the enclosed instructions on how to ship your product to the Canon USA repair facility. Your Product must be returned in the shipping carton in which the replacement Product was packed and include the reference number, A COPY OF YOUR DATED PROOF OF PURCHASE (BILL OF SALE), and a complete explanation of the problem. DO NOT INCLUDE ANY OTHER ITEMS WITH THE YOUR PRODUCT IN THE RETURN SHIPPING CARTON, AND BE SURE TO RETAIN YOUR PRINTHEAD, INK CARTRIDGE(S) AND TANK(S).
InstantExchange Service exchanges your Product with a replacement Product, which will normally be shipped the same day if your request for this service is by 3 p.m. E.T. Monday through Friday, except holidays. Canon USA does not guarantee same day shipment in the event of the occurrence of factors beyond its reasonable control. The replacement Product you receive may be a refurbished or reconditioned unit and will be covered for the balance of the period remaining on your original limited warranty. NOTE THAT BY USING THIS SERVICE YOU WILL KEEP THE REPLACEMENT PRODUCT THAT IS SENT TO YOU. CANON USA WILL RETAIN THE PRODUCT THAT YOU ORIGINALLY PURCHASED, WHICH SHALL BECOME THE PROPERTY OF CANON USA. InstantExchange warranty program service is available only during the express limited-warranty period for your Product and only in the continental United States, Alaska and Hawaii during such period.
InstantExchange warranty service is subject to the availability of refurbished or new replacement units.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
Title Canon Support | Canon print services provided on the IFTTT platform will discontinued
Advisory Type
Date 07.14.20
Title Statement on Use of So-Called Edible Inks and Icing Sheets with Canon Inkjet Printers
Advisory Type
Date 09.08.23
Title CPA2026-002: Vulnerability Remediation for IJ Scan Utility for Windows
Advisory Type
Date 02.26.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
