Canon Support for PIXMA TS4320 | Canon U.S.A., Inc.
PIXMA TS4320
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.28.25
File Size 1.16 MB
Date 10.28.25
File Size 1.15 MB
Date 12.08.25
File Size 6.10 MB
Date 12.08.25
File Size 6.13 MB
Date 09.17.25
File Size 2.90 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Print and scan wirelessly from any Wi-Fi® enabled computer, Android™ or iOS tablet and smartphones from your local network connection. Wireless printing requires a working network with wireless 802.11b/g/n capability. You will need a Wi-Fi enabled Computer or mobile device, a wireless router and a wireless printer. All devices must be connected to the same wireless network connection. Click on the specific topic below to get detail information.
Wireless Setup
Need additional information or assistance?
Products Windows 7 Windows 8 Windows 10 Windows 11
PIXMA TS4320 1
Products Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26
PIXMA TS4320
Products ChromeOS
PIXMA TS4320
Print Features AirPrintFootnote4, Black Ink / Color Ink Only Printing (Windows Only), Borderless PrintingFootnote6, Canon PRINT appFootnote2, Document Printing, Easy-PhotoPrint Editor Software appFootnote9, Greeting Card Printing, ID Photo PrintingFootnote9, Label Printing, Mopria Print ServiceFootnote5, Photo Printing, PIXMA Cloud Integration ServiceFootnote2, Square Photo Printing, Wireless Direct Printing, Wireless PrintingFootnote1
Printing Capability 2-Sided (Duplex) Printing, BorderlessFootnote6 Printing (4 x 6 to 8.5 x 11)
First Print Out Time (FPOT) Black Document (Letter) Simplex: Approx. 7.5 SecondsFootnote3
Color Document (Letter) Simplex: Color Document (Letter) Simplex: Approx. 9.5 SecondsFootnote3
Print Speed (ESAT) Black Document (Letter) Simplex: Approx. 14.0 ipmFootnote3
Color Document (Letter) Simplex: Approx. 9.0 ipmFootnote3
4 x 6 Borderless Photo (PP-201): Approx. 39 Seconds
Print Head FINE (Full-photolithography Inkjet Nozzle Engineering) Print Head
User Replaceable: No
Number of Nozzles CMY: 768 / Black: 832 / Total: 3,136
RMPV 500 Pages / MonthFootnote24
Print Resolution Up to 1200 x 1200 dpiFootnote22
Media Handling Cassette
Supported Paper Sizes 4 x 6, 5 x 5 (Square), 5 x 7, 7 x 10, 8 x 10, Letter (8.5 x 11), U.S. #10 Envelopes, Card Size (91mm x 55mm)
Paper / Media Compatibility Plain: Plain Paper, Canon High Resolution Paper; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Matte: Matte Photo Paper Other: Greeting Cards, Restickable Photo Paper, U.S. #10 Envelopes, Recycled paper and Chlorine-free paper can be used
Paper Capacity Cassette: 100 Sheets of Plain Paper
Supported Media Thickness / Weight Plain Paper: 64 - 105 gsm
Photo Paper: Approx. 275 gsm (Canon PP-301 Media)
Copy Features 4-on-1 / 2-on-1 Copy, Auto Exposure Copy, Borderless Copy, Fit-to-Page, Frame Erase Copy, ID Card Copy, Standard Copy, Two-Sided Copy
Copy Speed FCOT (Color): Approx. 18 seconds, Speed ESAT: 7.0 ipmFootnote14
Reduction / Enlargement 25% 400%
Ink Replenishment Options PIXMA Print Plan, (PPP), Automatic Replenishment System (ARS) Capable, Easy Ink Delivery (EID), Individual Ink / Pack Purchase
Scan Features Save to PC, Attached to E-mail, Multi-page PDF, Scan to Canon PRINT appFootnote3, Wireless ScanningFootnote2
Scanner Type Flatbed
Scanning Method Contact Image Sensor (CIS)
Scanning Resolution 1200 x 2400 dpi (Optical)Footnote15
Maximum Color Scanning Bit Depth N/A
Maximum Document Size Flatbed: 8.5 x 11.7 (A4 / Letter)
ADF Capacity N/A
Ink System Hybrid Ink System, 2 Ink Tanks
Ink Types PG-295 Pigment-Based Black Ink Tank
CL-286 Dye-Based Color Ink Tank (Cyan, Magenta, Yellow, Black)
Ink Tanks & Fill Volume PG-295 BK: 6.7 ml
CL-286 CL: 9.9 ml
Print Longevity The ChromaLife100 SystemFootnote8 protects your photos from fading up to; 100 Years Album Life, or 30 Years Behind Glass (Light Fastness), or 20 Years Without The Glass (Gas Fastness).
Ink Replenishment Options PIXMA Print Plan (PPP) Eligible, Automatic Replenishment System (ARS) Capable, Easy Ink Delivery (EID), Individual Ink / Pack Purchase
Connectivity Hi-Speed USB
Wi-Fi® (Dual-Band) / Wireless LANFootnote1
Wireless Information Wireless Standard1,9: IEEE 802.11 b/g/n/a
Wireless Security1,9: WPA-PSK, WPA2-PSK, WPA3-SAE
Wireless LAN Frequency Band(s)1,9: 2.4 GHz / 5.0 GHz
Wireless Direct Connection Capable1,9: Yes
Wireless Connect Setup Capable1,9: Yes
General Features PIXMA Cloud LinkFootnote2, Quiet Mode, Wireless Connect SetupFootnote9, Wireless Direct Connection
Display N/A
Supported Languages N/A
Smart Assistant & Automation Support Amazon AlexaFootnoteTM,10
OS Compatibility Windows:Footnote11 Windows® 11, Windows® 10, Windows® 8.1, Windows® 7 SP1
Mac:Footnote12 Mac OS® v14 macOS v12
Mobile Operating Systems:Footnote13 iOS®, AndroidTM, and iPadOS
Chromebook23: Yes
Mobile Apps & Plug-Ins (iOS® / ANDROIDTM) AirPrintFootnote®4, Canon PRINT appFootnote2, Canon Print ServiceFootnote17, Creative Park appFootnote18, Easy-PhotoPrint Editor appFootnote9, Mopria® Print ServiceFootnote5
Software (WINDOWSFootnote11 / MACFootnote15)
PIXMA TR4320 Printer Driver
Easy-PhotoPrint Editor SoftwareFootnote7
PosterArtist Online VersionFootnote18
Power Energy Efficiency: ENERGY STAR® certified
Auto Power On / Off Capable: Yes
Input Voltage: AC 100 240 V, 50 / 60 Hz
Power Consumption: 21W (0.9W Standby, 0.1W Off)
TEC (Typical Energy Consumption): N/A
Security N/A
Sound Management Quiet Mode: Available
Noise Level: Approx. 47.0 dB(A) (Plain Paper)
Operating Environment Operating Temperature: 41° - 95° F (5° - 35° C)
Operating Humidity: 5 - 95% RH
Printer Dimensions (Closed) 14.8 (L) x 14 (W) x 6.7 (H)
Printer Dimensions (Paper Installed) 14.8 (L) x 21 (W) x 6.7 (H)
Printer Weight 11.4 lbs.
Warranty 1-Year Limited Warranty with InstantExchange ProgramFootnote20
Note Specifications are subject to change without notice. All viewscreen and output images are simulated.
The limited warranty set forth below is given by Canon U.S.A., Inc. (“Canon USA”) with respect to the Canon PIXMA Series product (“Product”) packaged with this limited warranty, when purchased and used in the United States only.
The Product is warranted against defects in materials and workmanship under normal use and service for one (1) year from the date of original purchase. Product returned to a Canon USA repair facility, and proven to be defective upon inspection, in Canon USA’s sole discretion and at no charge, will be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts (b) exchanged for a new Product or; (c) exchanged for a refurbished Product, as determined by the Canon USA repair facility. Warranty replacement shall not extend the warranty period of the malfunctioning Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold “as is” and without warranty of any kind by Can¬on USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty if any with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
a) Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations.
b) Improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA’s user’s manual or other documentation.
c) Services performed by someone other than a qualified Canon USA representative who are acting in accordance with Canon USA’s service bulletins or Canon USA repair facility. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user’s manual or other documentation for the Product.
d) Use of parts, media, software or supplies (other than those sold by Canon USA), including, without limitation, non-Canon ink cartridges or refilled ink cartridges, that cause damage to the Product or cause abnormally frequent service calls or service problems.
e) If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON OR IN THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER’S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER’S LICENSE AGREEMENT.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE PRODUCT. NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT. CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU.) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY. NEITHER CANON NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY SER¬VICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, LOSS OR CORRUPTION OF DATA INCLUDING, WITHOUT LIMITATION, DATA STORED ON THE PRODUCT’S HARD DISK DRIVE, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS, ARISING OUT OF THE POSSESSION, USE, MISUSE OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY SERVICE PROVIDER. THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE PURCHASER, AND STATES SUCH PURCHASER’S EXCLUSIVE REMEDY.
A range of Canon USA customer technical support* options are available:
• Interactive troubleshooting, the latest driver downloads, hours of operation, and answers to frequently asked questions (www. usa.canon.com/support)
• Toll-free live technical support Monday–Friday (excluding Canon-observed holidays) at 1-800-OK-CANON (1-800-652-2666)
• Telephone Device for the Deaf (TDD-1-855-270-3277)
• Warranty Service:
In the event service is required for the Product during the limited warranty period, a Canon USA Customer Care Center representative wil attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the problem cannot be corrected over the tele¬phone, you will be provided instructions for Canon USA’s then current warranty service procedures. You may be asked for the Product serial number and/or other information pertaining to your Product.
This limited warranty gives you specific legal rights, and you may also have other rights, which vary from state to state. * Support program specifics are subject to change without notice.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
