Canon Support for PowerShot A10 | Canon U.S.A., Inc.
PowerShot A10
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Image Capture Device
| Type | 1/2.7 in. charge-coupled device (CCD) |
| Total Pixels | Approx. 1.32 million-pixel |
| Effective Pixels | Approx. 1.25 million |
Lens
| Focal Length | f/2.8 |
| Digital Zoom | Maximum 2.0x (Maximum 6x with optical zoom) |
| Focusing Range | Normal: 76cm (2.5 ft.) - infinity Macro: 16 - 76cm (6.3 in. - 2.5 ft.)(Wide angle); 26 - 76cm (10.2 in. - 2.5 ft.)(Telephoto) |
| Autofocus System | TTL 3 point AiAF |
Viewfinders
| Optical Viewfinder | Real-image optical zoom viewfinder |
| LCD Monitor | 1.5-inch low-temperature polycrystalline silicon TFT color LCD |
| LCD Pixels | 117,600 effective pixels |
| LCD Coverage | Approx. 80% |
Aperture and Shutter
| Maximum Aperture | f/2.8 - 4.8; 5.4mm (Wide angle) - 16.2mm (Telephoto) (35 mm film equivalent: 35 - 105mm) |
| Shutter Speed | 1 - 1/1500 sec.* 1 sec. in manual mode with the flash off or in slow synchro mode.* Noise reduction processing on speeds slower than 1/6 sec. |
Exposure Control
| Sensitivity | ISO 100 equivalent (automatically raised to ISO 150 in low light) |
| Light Metering Method | Evaluative metering (linked to focusing point) |
| Exposure Control Method | Program AE; Exposure is locked once focusing is complete. |
| Exposure Compensation | +/-2 stops in 1/3-stop increments |
White Balance
| White Balance Control | TTL Auto/Pre-set (daylight, cloudy, tungsten, fluorescent)/Black & White |
Flash
| Built-in Flash | Red-eye reduction Auto/Auto/On/Off |
| Flash Range | Normal Mode: 76cm - 4.2m (2.5 - 13.8 ft.) (Wide angle), 76cm - 2.5m (2.5 - 8.2 ft.) (Telephoto) Macro Mode: 26 - 76cm (10.2 in. - 2.5 ft.) (Wide angle/Telephoto) |
Shooting Specifications
| Shooting Modes | Auto/Manual/Stitch Assist/Playback |
| Self Timer | Shoots after approx. 10 sec. |
| Continuous Shooting | Approx. 2.5 images/sec (Large/ Fine mode, LCD monitor off) |
Image Storage
| Storage Media | CompactFlash Card (Type I) |
| File Format | JPEG (Design rule for Camera File system, DPOF compliant) |
| JPEG Compression Mode | SuperFine/Fine/Normal |
| Number of Recording Pixels | Large: 1,280 x 960 pixels; Medium: 1,024 x 768 pixels; Small: 640 x 480 pixels |
Number of Recordable Images
| Image data |
Playback Specifications
| Playback Modes File | Single image replay/Index replay (9 thumbnails)/Zoomed view (LCD monitor zooms images up to 2.5x)/Auto play/Printing with Card Photo Printer CP-10 (print image directly) |
Interfaces
| Computer Interface | USB (mini-B) |
| Power Supply | Four AA alkaline batteries or four AA rechargeable NiMH batteries Compact Power Adapter CA-PS500 |
| Power Source | Four AA alkaline batteries or four AA rechargeable NiMH batteries Compact Power Adapter CA-PS500 |
Physical Specifications
| Operating Temperature | 0 - 40°C (32 - 104°F) |
| Operating Humidity | 10 - 90 % |
| Dimensions (W x H x D) | 4.3 x 2.8 x 1.5 in. (110.3 x 71.0 x 37.6mm) (excluding protrusions) |
| Weight | Approx. 250g (8.8 oz.) (excluding batteries and CF card) |
Computer System Requirements
| Mac Requirements | Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 8.6 through 9.1, Quicktime 3.0 or higher CPU: Power PC Interface: USB - Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3/G4, iMac, iBook) RAM: 20MB or more of application memory |
| PC Requirements | Hardware: IBM PC/AT compatible. OS Windows 98 (including the Second Edition)/ Windows 2000/Windows ME. CPU: Pentium 133 MHz or better. Interface: USB - Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems. RAM: 32MB or more (Windows 98); 64MB or more (Windows 2000/Windows ME). |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
