Canon Support for PowerShot A100 | Canon U.S.A., Inc.
PowerShot A100
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 03.31.07
File Size 1.86 MB
Date 03.31.07
File Size 3.11 MB
Date 11.13.07
File Size 1.53 MB
Date 03.04.10
File Size 6.07 MB
Date 03.04.10
File Size 6.23 MB
Date 04.19.10
File Size 201.00 KB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact Digital Still Camera with Built-in Flash and 3.2x Digital Zoom
Image Capture Device
Type 1/3.2 inch Charge-Coupled Device (CCD)
Total Pixels Approx. 1.3 million
Effective Pixels Approx. 1.2 million
Lens
Focal Length 5mm (35mm film equivalent: 39mm)
Digital Zoom 3.2x Digital Zoom
Autofocus System TTL AiAF (3 focusing points), TTL AF (user-select focusing point)
Viewfinders
Optical Viewfinder Reverse Galilean type.
LCD Monitor 1.5 inch low temperature polycrystalline silicon TFT color LCD
LCD Coverage 88.7%
Aperture and Shutter
Maximum Aperture f/2.8
Shutter Speed 1-1/2000 sec.
Exposure Control
Sensitivity At Auto setting, camera automatically adjusts speed according to ambient light, from ISO 64 to ISO 150 equivalent; user set manual ISO 64, 100, 200, 400
Light Metering Method Evaluative Metering
Exposure Control Method Program AE
Exposure Compensation +/- 2.0 EV in 1/3 step increments
White Balance
White Balance Control TTL Auto White Balance, Pre-Set White Balance (Available Settings: Daylight, Cloudy, Tungsten, Fluorescent, or Fluorescent H).
Flash
Built-in Flash Operation Modes: Auto/On/Off, Auto Red-Eye Reduction Auto/On, Slow-Sync.
Shooting Specifications
Shooting Modes Auto, Program, Manual, Stitch Assist, Movie, Photo Effect (Vivid Color, Neutral Color, Low Sharpening, Sepia, Black & White).
Continuous Shooting Approx. 2.5 images/sec.
Image Storage
Storage Media CompactFlash (CF) Card Type I
File Format Design rule for Camera File system (DCF*1)
Print Order Format Digital Print Order Format (DPOF) Version 1.1; EXIF Print Compliant (EXIF 2.2)
Image Recording Format Still Image: JPEG Movie: AVI
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels Small: 640 x 480, Medium: 1,024 x 768, Large: 1,280 x 960, Movie: 320 x 240 or 160 x 120.
Number of Recordable Images
Image data &#160;These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Description
&#160;
Time of Recordable Movies
Movie data &#160;Figures for Movie Mode represent total capacity of CompactFlash Card. Individual clips are limited to 10 or 30 seconds. Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings.
Playback Specifications
Playback Modes File Single, Index (9 thumbnail images), Magnification (2x to 10x), or Slide Show
Erasing Specifications
Erase Modes Single Image, All Images
Interfaces
Computer Interface Universal Serial Bus (USB)
Other CF card slot (complied with CF Type I standard). Direct connection to Canon Card Photo Printer CP-100 and CP-10 (no computer required).
Power Supply 2 AA-size batteries (Alkaline, Rechargeable NiMH).2. NB-5H Nickel-Metal Hydride Battery (Rechargeable)3. DR100A DC Coupler plus CA-PS100E Compact Power Adapter (Dedicated AC Adapter)LR 6/Size AA Battery LCD ON: Approx. 100 images LCD OFF: Approx. 380 images, Size AA/NiMH Battery, LCD ON: Approx. 210 images, LCD OFF: Approx. 630 imagesLR 6/Size AA Battery: Approx. 90 min. Size AA/NiMH Battery (NB-1AH): Approx. 120 min.
Power Source 2 AA-size batteries (Alkaline, Rechargeable NiMH).2. NB-5H Nickel-Metal Hydride Battery (Rechargeable)3. DR100A DC Coupler plus CA-PS100E Compact Power Adapter (Dedicated AC Adapter)
Shooting Capacity LR 6/Size AA Battery LCD ON: Approx. 100 images, LCD OFF: Approx. 380 images, Size AA/NiMH Battery, LCD ON: Approx. 210 images, LCD OFF: Approx. 630 images
Playback Time LR 6/Size AA Battery: Approx. 90 min. Size AA/NiMH Battery (NB-1AH): Approx. 120 min.
Physical Specifications
Dimensions (W x H x D) 4.3 x 2.3 x 1.4 in. / 110 x 58 x 36.6 mm
Weight 5.6 oz. / 160g
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 8.6 through 9.1 (Please see our Mac OS X Compatibility Statement)CPU: Power PC Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook).RAM: 20MB and over for application
PC Requirements Hardware: IBM PC/AT compatible OS: Windows 98 (including the Second Edition), Windows 2000, Windows Me, Windows XPCPU: Pentium 150 MHz and over, Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME or Windows XP systems. RAM: 32MB or more (Windows 98)RAM: 64MB or more (Windows 2000/Windows ME)RAM: 128MB or more (Windows XP)
*1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronics and Information Technology Industries Association (JEITA).
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
