Canon Support for PowerShot A310 | Canon U.S.A., Inc.
PowerShot A310
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
| Type | Compact digital still camera with built-in flash and 5.1x digital zoom |
Image Capture Device
| Type | 1/2.7 inch type |
| Total Pixels | Approx. 3.3 Million |
| Effective Pixels | Approx. 3.2 Million |
Lens
| Focal Length | 5.0mm (35mm film equivalent: 33mm) |
| Digital Zoom | 5.1x |
| Focusing Range | Normal AF: 20cm (7.9 in.) - Infinity Macro AF: 5 - 20cm (2 - 7.9 in.) |
| Autofocus System | 5-point AiAF/1-point AF (Fixed to center) |
Viewfinders
| Optical Viewfinder | Inverted Galilean type |
| LCD Monitor | 1.5" low-temperature polycrystalline silicon TFT color LCD |
| LCD Pixels | Approximately 7,800 pixels |
| LCD Coverage | 100% |
Aperture and Shutter
| Maximum Aperture | f/3.6 - 5.6 |
| Shutter Speed | 1 - 1/2,000 sec. Shutter speeds slower than 1/6 sec. are only available in select modes |
Exposure Control
| Sensitivity | AUTO; ISO 50/100/200/400 equivalent |
| Light Metering Method | Evaluative / Center-weighted average / Spot* *Metering frame when spot is center fixed |
| Exposure Control Method | Program AE |
| Exposure Compensation | +/- 2.0EV in 1/3-stop increments |
| AE Lock | Not Available |
White Balance
| White Balance Control | Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), or Custom White Balance |
Flash
| Built-in Flash | Operation Modes: Auto, Red-Eye Reduction On/Off, Slow-Sync |
| Flash Range | 20cm - 2.0m/7.9 in. - 6.6 ft. (When ISO speed is set to AUTO) |
| Recycling Time | Approx. 10 sec. or less |
Shooting Specifications
| Shooting Modes | Auto, Manual, Stitch Assist, Movie |
| Photo Effects | Vivid, Neutral, Low Sharpening, Sepia and Black & White |
| Self Timer | Operates with approx. 2 sec. or approx 10 sec. count-down |
| Wireless Control | Not Available |
| Continuous Shooting | Approx. 2.2 shots/sec. (Large/Fine Mode and LCD monitor is Off) |
Image Storage
| Storage Media | CompactFlash (CF) Card Type I |
| File Format | AVI (Image data: Motion JPEG; Audio data: WAVE (Monaural)) |
| Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
| Image Recording Format | JPEG (Exif 2.2 compliant) |
| JPEG Compression Mode | SuperFine, Fine or Normal |
| Number of Recording Pixels | Still Image: 2,048 x 1,536 (Large), 1,600 x 1,200 (Medium 1), 1,024 x 768 (Medium 2), 640 x 480 (Small) Movie: 640 x 480, 320 x 240, 160 x 120 |
Number of Recordable Images
| Image data |  These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode. |
Time of Recordable Movies
| Movie data |  Individual movie clips are limited to 30sec. (640 x 480) or 3 minutes each maximum per clip. Above figures show total movie capacity on various CF cards, measured under Canon's standard test conditions, and may vary depending upon scene, subjects or camera settings. |
Playback Specifications
| Playback Modes File | Single, Index (9 thumbnails), Magnification (approx. 2x to 10x) |
Erasing Specifications
| Erase Modes | Still Image: Single Image, All Images Movie: Part of Movie, All Movie |
Interfaces
| Computer Interface | Universal Serial Bus (USB) (mini-B jack) |
| Video Out | None |
| Other | CF card slot (accept type I cards). Direct connection to Canon CP Printers and select Bubble Jet Photo Printers (no computer required). |
| Power Supply | 1. Size AA Alkaline battery x2 2. Rechargeable size AA NiMH battery x2 3. Compact power adapter CA-PS800 AA ALKALINE: LCD On - Approx. 75 shots; LCD Off - Approx. 250 shots AA NIMH: LCD On - Approx. 350 shots; LCD Off - Approx. 950 shotsApprox. 90 min/Approx 240 min. (Alkaline battery/NB-2AH) |
| Power Source | 1. Size AA Alkaline battery x2 2. Rechargeable size AA NiMH battery x2 3. Compact power adapter CA-PS800 |
| Shooting Capacity | AA ALKALINE: LCD On - Approx. 75 shots; LCD Off - Approx. 250 shots AA NIMH: LCD On - Approx. 350 shots; LCD Off - Approx. 950 shots |
| Playback Time | Approx. 90 min/Approx 240 min. (Alkaline battery/NB-2AH) |
Physical Specifications
| Operating Temperature | 32 - 104°F (0 - 40°C) |
| Operating Humidity | 10 - 90% |
| Dimensions (W x H x D) | 4.33 x 22.8 x 14.4 in./110.0 x 58.0 x 36.6mm (Excluding protrusions) |
| Weight | Approx. 6.17 oz./175g (Camera body only) |
Computer System Requirements
| Mac Requirements | OS: Mac OS 9.0 - 9.2, Mac OS X (v10.1/10.2/10.3). Computer Model: The above OS should be pre-installed on computer with built-in USB ports. CPU: PowerPC. Interface: USB (Models with Apple genuine USB interface only). |
| PC Requirements | OS: Microsoft Windows 98 (including Second Edition)/ME/2000/XP. Computer Model: The above OS should be pre-installed on computer with built-in USB ports. CPU: Pentium 150MHz or higher processor (Windows 98/ME/2000), Pentium 300MHz or higher processor (Windows XP). Interface: USB (Windows 98/ME/2000/XP pre-install model only). |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
