Canon Support for PowerShot A3300 IS | Canon U.S.A., Inc.
PowerShot A3300 IS
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 01.24.11
File Size 8.36 MB
Date 01.24.11
File Size 10.55 MB
Date 02.08.11
File Size 8.69 MB
Date 01.24.11
File Size 8.69 MB
Date 02.08.11
File Size 8.36 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
The Canon EOS Digital Camera Software Development Kit (EDSDK) enables developers to integrate select Canon cameras directly into their software application solutions, giving them access to remote camera control and communication functionality of the camera. There are two versions of the EDSDK compatible with Windows or Macintosh.
The Software Developer Kit is provided free of charge and can be found at https://developercommunity.usa.canon.com. To learn more please visit the Canon Developer Community site and register to download Canon’s SDKs.
Our Knowledge Base with curated Q&As will point you in the right direction to troubleshoot your error code yourself. Be sure to search the error code you are struggling with along with your product model number in our Knowledge Base.
Type
16.0 Megapixel 1/2.3-inch type Charge Coupled Device (CCD)
Total Pixels
16.4 Megapixels
Effective Pixels
16.0 Megapixels
Focal Length
5.0 (W) - 25.0 (T) mm (35mm film equivalent: 28 (W) - 140 (T) mm)
Digital Zoom
4x
Focusing Range
1.2 in. (3cm) - infinity (W), 3.0 ft. (90cm) - infinity (T)
Macro: 1.8 in (3cm) (W) - 1.6 ft. (50cm) (T)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
3.0-inch TFT Color (wide viewing angle type)
LCD Pixels
Approx. 230,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.8 (W) - f/5.9 (T)
Shutter Speed
1 - 1/1600 sec.
15 - 1/1600 sec. (Total shutter speed range)
Sensitivity
Auto, ISO 80/100/200/400/800/1600
Low Light: ISO 400-6400
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Control to incorporate facial brightness in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method
AE Lock
Exposure Compensation
+/-2 stops in 1/3 stop increments
White Balance Control
Auto, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
Built-in Flash
Auto, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE Lock, Slow Synchro, Smart Flash
Flash Range
12 in. - 13 ft. (W), 1.6 - 6.6 ft. (T) (30cm - 4.0m (W), 50cm - 2.0m, (T))
Recycling Time
10 seconds or less (Battery Voltage: 3.7V)
Flash Exposure Compensation
N/A
Shooting Modes
P, Live View Control, Auto, Easy, SCN1, Creative Filters2, Discreet, Movie3
1 Portrait, Landscape, Kids & Pets, Smart Shutter4, Low Light, Beach, Foliage, Snow, Fireworks, Long Shutter
2 Fish-eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect
3 Standard, Miniature Effect
4 Smile, Wink Self-timer, Face Self-timer
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Custom*
*Adjustment of contrast, sharpness and saturation available.
Self Timer
Approx. 10-sec delay/approx 2-sec delay/custom*
* Shooting start time (0-15 sec (in one-second increments), 20/25/30 sec.) and number of shots (1-10 (in one-second increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Approx: 0.8 shots/sec. (In P Mode)
Approx. 2.5 shots/sec. (In Low Light Mode)
Storage Media
SD/SDHC/SDXC Memory Card, MultiMediaCard, MMCplus Card, HC MMCplus Card
File Format
Design rule for Camera File System, DPOF (Version 1.1) compliant
JPEG Compression Mode
Exif. 2.3 (JPEG)
Video: MOV (Image data: H.264; Audio data: Linear PCM (monoaural))
Number of Recording Pixels
Still Image: 4608 x 3456 (Large), 3264 x 2448 (Medium 1), 1600 X 1200 (Medium 2), 640 x 480 (Small), 4608 x 2592 (Widescreen)
Image data
* When shooting is Low Light
Movie data
** Actual frame rate is 29.97 fps.
Playback Modes File
- Easy, Auto Rotate (Automatic vertical/horizontal detection), Resume Playback, Image Advance (Operation Tools, Transition effects, Scroll Display), Rotate, Favorites, My Category, Jump, Smart Shuffle, Slide Show (Playback Interval, Repeat, Effect, Playlist)
- Still Images: Single, Index, Magnification, Trimming, Resize, i-Contrast, Focus Check, Histogram, Overexposure Warning, Red-eye Correction
- Movies: Normal Playback*, Editing, slow motion **, first frame, last frame, next frame, previous frame, fast forward, rewind
*Audio settings available in 5 levels
** 5 levels (including normal playback), sound not available.
Erase Modes
Still Image: single image, select range, all images
Video: any video file
Computer Interface
USB 2.0 Hi-Speed (mini-B jack)
Video Out
NTSC/PAL
Audio Out
Monaural
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Source
1.Battery Pack NB-8L
2.Compact Power Adapter CA-DC10
Shooting Capacity
Approx. 230 shots
Playback Time
Approx. 5 hours
The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Operating Temperature
32-104°F/0-40°C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.74 x 2.23 x 0.94 in. (95.1 x 56.7 x 23.9mm)
Weight
Approx. 5.25 oz./149 g (Including the battery and memory card)
Approx. 4.60 oz./130 g (Camera body only)Note: 26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, and Farsi).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
