Canon Support for PowerShot A3400 IS | Canon U.S.A., Inc.
PowerShot A3400 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
16.0 Megapixel 1/2.3-inch CCD
Total Pixels
16.6 Megapixels
Effective Pixels
16.0 Megapixels
Focal Length
5.0 (W) - 25.0 (T) mm (35mm film equivalent: 28 (W) - 140 (T) mm)
Digital Zoom
4x
Focusing Range
Normal: 2.0 in. (5cm) - infinity (W), 3.9 ft. (1.2m) - infinity (T)
Auto: 1.2 in. (3cm) - infinity (W), 3.9 ft. (1.2m) - infinity (T)Macro: 1.2 in. - 2.0 ft. (3-60cm) (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
3.0-inch TFT Color, Touch Panel LCD with wide-viewing angle
LCD Pixels
Approx. 230,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.8 (W) - f/6.9 (T)
Shutter Speed
1 - 1/2000 sec.
15 - 1/2000 sec. (Total shutter speed range)
Sensitivity
Auto, ISO 100/200/400/800/1600 (in P mode)
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated in Face Detect (Face Detect AE)
** Fixed to center
Exposure Control Method
AE Lock
Exposure Compensation
+/-2 stops in 1/3 stop increments(Not available when shooting movies)
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom*Facial color is evaluated in Face Detect (Face Detect WB)
Built-in Flash
Auto, On, Slow Synchro, OffFacial brightness is also evaluated in Face Detect.
Flash Range
1.6 - 9.8 ft. (W), 3.3 - 6.6 ft. (T) (50 cm - 3.0 m (W), 1.0 - 2.0 m (T)
Recycling Time
10 seconds or less (Battery Voltage: 3.7V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto, P, Live View Control, Portrait, Face Self-timer, Low Light, Fisheye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Snow, Fireworks, Long Shutter, Discreet, iFrame Movie*
*Shooting movies is possible with the movie button.
Photo Effects
N/A
Self Timer
Approx. 10-sec delay/approx 2-sec delay/custom*
* Delay time (0 - 15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1 - 10 shots (in one-shot increments) can be specified.
Wireless Control
N/A
Continuous Shooting
Approx: 0.8 shots/sec. (In P Mode)
Approx. 2.7 shots/sec. (In Low Light Mode)
Storage Media
SD Memory Card, SDHC Memory Card, SDXC Memory Card
File Format
Design rule for Camera File System, DPOF (Version 1.1) compliant
JPEG Compression Mode
Still Images: Exif 2.3 (JPEG)
Movies: MOV (Image data: H.264; Audio data: Linear PCM (2 channel monoaural))
Number of Recording Pixels
Still Images:[Large]: 4608 x 3456
[Medium 1]: 3264 x 2448
[Medium 2]: 1600 x 1200
[Small]: 640 x 480
[Widescreen]: 4608 x 2592Movies:[Miniature Effect]
1280 x 720*1, 640 x 480*2[iFrame Movie]
1280 x 720 (25 fps)[Other than the above]
1280 x 720 (25 fps), 640 x 480 (30 fps*3)*1 Shooting: 5 fps / 2.5 fps / 1.25 fps
Playback: 25 fps
*2 Shooting: 6 fps / 3 fps / 1.5 fps
Playback: 30 fps*3 *3 Actual frame rate is 29.97 fps.
Image data
*When shooting in Digital IS or Low Light*The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
Playback Modes File
Still Images and Movies:
Discreet, Auto Rotate, Rotate, Search Jump (Shot Date, 10 images, 100 images, Movies, Still Images), SlideshowStill Images:
Single, Index (4-100 Thumbnails), Magnification (Approx. 2x-10x), Information Display, Histogram, Overexposure Warning, Resume Playback, Red-Eye Correction, i-Contrast, Resize,Movies:
Normal Playback*1, Pause, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2 Displays playback position and shooting time*1 Audio settings available in 5 levels
*2 Approximately 4 seconds
*3 Rewind and Fast-forward are also available
Erase Modes
Single Image*, Erase AllThe image data in the memory card stored with the design rule for camera file systems format can be erased (however, protected images cannot be erased).* Movies can be erased individually.
Computer Interface
Hi-Speed USB*1 (Dedicated connector (female) with unified type of digital, audio and video*2)*1 Use of USB logomark is not allowed.*2 mini-B compatible.
Video Out
NTSC/PAL (unified type dedicated connector (female)) with digital, audio and video
Audio Out
Monaural (unified type dedicated connector (female)) with digital, audio and video
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Source
1. Rechargeable Lithium-ion Battery NB-11L
2. Compact Power Adapter CA-DC10 (included with AC Adapter Kit ACK-DC90)
Shooting Capacity
Approx. 180 shots
Playback Time
Approx. 4 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.72 x 2.22 x 0.84 in. (94.4 x 56.3 x 21.3mm)
Weight
Approx. 4.97 oz. / 141 g (Including the battery and memory card)
Approx. 4.41 oz. / 125 g (Camera body only)Note: 30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Ukrainian, Malaysian, Indonesian, Norwegian, Swedish, Spanish, Simplified Chinese, Traditional Chinese, Korean, Russian, Portuguese, Hungarian, Polish, Czech, Greek, Turkish, Thai, Arabic, Romanian, Farsi, Hindi, Vietnamese, and Japanese)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
