Canon Support for PowerShot A610 | Canon U.S.A., Inc.
PowerShot A610
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
| Type | Compact digital still camera with built-in flash, 4x Optical/4x Digital/16x Combined Zoom |
Image Capture Device
| Type | 5.0 Megapixel, 1/1.8 inch type Charge Coupled Device (CCD) |
| Total Pixels | Approx. 5.3 Megapixels |
| Effective Pixels | Approx. 5.0 Megapixels |
Lens
| Focal Length | 7.3 - 29.2mm f/2.8-4.1 (35mm film equivalent: 35-140mm) |
| Digital Zoom | 4x |
| Focusing Range | Normal: 1.5 ft./45cm-infinityMacro: 0.4 in.-1.5 ft./1-45cm (WIDE), 9.8 in. - 1.5 ft./25-45cm (except WIDE) |
| Autofocus System | TTL Autofocus (continuous/single) |
Viewfinders
| Optical Viewfinder | Real-image optical zoom viewfinder |
| LCD Monitor | 2.0 inch low-temperature polycrystalline silicon TFT color LCD (vari-angle) |
| LCD Pixels | Approx. 115,000 pixels |
| LCD Coverage | 100% |
Aperture and Shutter
| Maximum Aperture | f/2.8 (W) - f/4.1 (T) |
| Shutter Speed | 15-1/2000 sec.; Slow shutter operates with noise reduction when manually set at 1.3-15 sec. |
Exposure Control
| Sensitivity | AUTO, ISO 50/100/200/400 equivalent |
| Light Metering Method | Evaluative, Center-weighted average, Spot* * Metering frame with Spot Mode fixed to center or linked to AF frame. |
| Exposure Control Method | Program AE, Shutter-priority AE, Aperture-priority AE, Manual.AE Lock is available |
| Exposure Compensation | +/- 2 stops in 1/3-stop increments |
White Balance
| White Balance Control | Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Underwater), Custom |
Flash
| Built-in Flash | Operation Modes: Auto, On/Off, Red-Eye Reduction On/Off, Slow Synchro |
| Flash Range | Normal: 1.5-13.8 ft./45cm - 4.2m (W), 1.5-9.8 ft./45cm - 3.0m (T) Macro: 0.8-1.5 ft./25-45cm (when sensitivity is set to ISO 100 equivalent) |
| Recycling Time | Approx. 10 sec. or less (battery voltage=6.0V) |
| Flash Exposure Compensation | +/- 2 stops in 1/3-stop increments |
Shooting Specifications
| Shooting Modes | Auto; Creative: P, Av, Tv, M, C; Image: Portrait, Landscape, Night Scene, Special Scene (Foliage, Snow, Beach, Fireworks, Underwater, Indoor, Kids & Pets, Night Snapshot), My Colors, Stitch Assist, Movie |
| Photo Effects | Vivid, Neutral, Low Sharpening, Sepia, Black & White |
| Self Timer | Activates shutter after an approx. 2 sec./10 sec. delay, Custom |
| Wireless Control | Not available |
| Continuous Shooting | Approx. 2.4 fps |
Image Storage
| Storage Media | SD Memory Card, MultiMediaCard |
| File Format | Design rule for camera file system, DPOF Version 1.1 (Digital Print Order Format) |
| Image Recording Format | Still Image: Exif 2.2 (JPEG) Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural)) |
| JPEG Compression Mode | Normal, Fine, SuperFine |
| Number of Recording Pixels | Still Image: 2,592 x 1,944 (Large), 2,048 x 1,536 (Medium 1), 1,600 x 1,200 (Medium 2), 640 x 480 (Small)Movie: 640 x 480/320 x 240 (30 fps/15 fps), 320 x 240 (1 min. at 60 fps), 160 x 120 (3 min. at 15 fps) |
Number of Recordable Images
| Image data |
Time of Recordable Movies
| Movie data | Note: N=Normal F=Fine SF=SuperFine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
Playback Specifications
| Playback Modes File | Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotation, Histogram, Index (9 thumbnails), Sound Memos, Slide Show Movie: Normal Playback, Special Playback, Slow Motion, Editing |
Erasing Specifications
| Erase Modes | Still Image: Single image, All images Movie: Part of movie, All of movie |
Interfaces
| Computer Interface | USB 2.0 Hi-Speed (mini-B PTP) |
| Video Out | NTSC/PAL |
| Audio Out | Monaural |
| Other | Memory card slot. Direct connection to Canon CP, SELPHY, PIXMA Photo Printers and PictBridge compatible printers via camera's USB cable. |
| Power Supply | 1. AA-size Alkaline Battery (x4) 2. Rechargeable AA-size NiMH Battery (x4) 3. AC Adapter Kit ACK600Still Image: approx. 350 shots (AA-size Alkaline Battery), approx. 500 shots (AA-size NiMH Battery) *1Approx. 960 min. (AA-size Alkaline Battery), approx. 960 min. (AA-size NiMH Battery)* |
| Power Source | 1. AA-size Alkaline Battery (x4) 2. Rechargeable AA-size NiMH Battery (x4) 3. AC Adapter Kit ACK600 |
| Shooting Capacity | Still Image: approx. 350 shots (AA-size Alkaline Battery), approx. 500 shots (AA-size NiMH Battery) *1 |
| Playback Time | Approx. 960 min. (AA-size Alkaline Battery), approx. 960 min. (AA-size NiMH Battery)* |
Physical Specifications
| Operating Temperature | 32-104° F/0-40° C |
| Operating Humidity | 10-90% |
| Dimensions (W x H x D) | 4.13 x 2.60 x 1.93 in./104.8 x 66.0 x 49.1mm |
| Weight | Approx. 8.29 oz./235g (camera body only) |
| *1 |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
