Canon Support for PowerShot G5 X Mark II | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 07.10.19
File Size 147.89 KB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 12.12.19
File Size 16.48 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type Digital camera with built-in flash, 5x Optical, 4x Digital and 20x Combined Zoom with Optical Image Stabilizer
Type 20.1 Megapixel*, 1.0-inch stacked CMOS (sensor aspect ratio: 3:2)
* Image processing may cause a decrease in the number of pixels.
Pixels Effective Pixels: Approx. 20.1 Megapixels
Total Pixels: Approx. 20.9 Megapixels
Focal Length 8.8 (W) 44.0(T) mm (35mm film equivalent: 24120mm)
Optical Zoom Approx. 5x
Digital Zoom Approx. 4x
Focusing Range Auto/Manual: 2.0 in. (5cm) infinity (W), 7.9 in. (20cm) infinity (T)
Normal: 2.0 in. (5cm) infinity (W), 7.9 in. (20cm) infinity (T)
Macro: 2.0 in. 1.6 ft. (550cm) (W)
Autofocus System TTL Autofocus, Manual Focus
Viewfinder Electronic Viewfinder (Approx. 2.36 million dots)
LCD Monitor 3.0-type TFT color liquid crystal (Vari-angle)
LCD Pixels Approx. 1.04 million dots
LCD Coverage Approx. 100%
Maximum Aperture f/1.8 (W), f/2.8 (T)
Shutter Speed 11/2000 sec. (in Auto mode)
151/2000 sec. (in Tv, M, and Manual Movie Modes)
1/4000 sec. (Movie Shooting)
1/2000 sec. (Time-lapse Movie)
ISO Sensitivity Auto, ISO 125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200/4000/5000/6400 (When in Auto mode)
Max. ISO Speed 12800 (When in P mode)
Light Metering Method Evaluative, Center Weighted Average, Spot (Still image only)
Exposure Control Method Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation Still Images: &plusmn;3 stops in 1/3-stop increments
Videos: &plusmn;3 stops in 1/3-stop increments
White Balance Control Auto (Ambience & White priority), Day Light, Shade, Cloudy, Tungsten, White Fluorescent Light, Flash, Color Temperature, Custom
Built-in Flash Auto, On, Slow Synchro, Off
Flash Range 1.6 ft.(50cm) 24.6 ft. (7.5m) (W), 1.6 ft. (50cm) 14.8 ft. (4.5m) (T)
Image brightness may diminish depending on the shooting distance.
Flash Exposure Compensation &plusmn;2 stops in 1/3-stop increments
Picture Style C, M, Av, Tv, P, Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def.1-3
Creative Filters Grainy B/W, Soft Focus, Fish-eye Effect, Art Bold Effect, Water Painting Effect, Toy Camera Effect, Miniature Effect
*Applicable only to images taken with same model.
Self Timer Off, 2 sec., 10 sec., Custom, Remote Shooting
Wireless Control Unavailable
Electronic Level Horizontal Roll Calibration, Vertical Pitch Calibration, Reset
Continuous Shooting JPEG, RAW, C-RAW:
One Shot AF: Approx. 20 shots/sec.
JPEG Servo AF: Approx. 8 shots/sec.
RAW Burst Mode:
Approx. 30 shots/sec.
Storage Media SD/SDHC/SDXC and UHS-I Memory Cards
File Format Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible
Image Recording Format Superfine / Fine
JPEG Compression Mode Still Image: Exif 2.3 (DCF 2.0), RAW (Canon original: 14-bit, CR2)
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC [Stereo])
Number of Recording Pixels
Still Images:
16:9
3:2
4:3
1:1
Large
5472 x 3072 5472 x 3648 4864 x 3648 3648 x 3648
Medium
3648 x 2048 3648 x 2432 3248 x 2432 2432 x 2432
Small (S1)
2736 x 1536 2736 x 1824 2432 x 1824 1824 x 1824
Small (S2)
2400 x 1344 2400 x 1600 2112 x 1600 1600 x 1600
RAW
-5472 x 36485472 x 3648-
RAW + JPEG
C- RAW
- 5472 x 3648 5472 x 3648 -
C-RAW + JPEG
Panoramic Shooting:
Min. Number of Recording Pixels
Max. Number of Recording Pixels
Vertical Shooting
3840 x 3648 16000 x 3840
Horizontal Shooting
5472 x 2560 26064 x 2560
Approx. Number of Shots Recordable to 32 GB Memory Card
3:2
4:3
Large (L)
F
4535 4535
N
8062 8062
Medium
F
7742 7742
N
9999 9999
Small 1 (S1)
F
9999 9999
N
9999 9999
Small 2 (S2)
9999 9999
RAW
13351335
RAW + JPEG
1031 1031
C- RAW
2301 2301
C-RAW + JPEG
15251525
Note: F=Fine N=Normal
* The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Time of Recordable Videos
Shooting Mode
Pixels
Frame Rate
Approx. Total Movie Time Recordable to 32 GB Memory Card
Single Clip Approx. Recording Time*1
Video Recording Bit Rate
Shooting
Playback
Standard Movie
4K
(3840 x 2160)
29.97 fps 29.97 fps 35 min. 29 sec. 9 min. 59 sec. Approx. 120 Mbps
FULL HD
(1920 x 1080)
119.9 fps 119.9 fps 35 min. 33 sec. 7 min. 29 sec. Approx. 120 Mbps
59.94 fps*1 59.94 fps*1 1 hr. 10 min. 48 sec. 29 min. 59 sec. Approx. 60 Mbps
29.97 fps 29.97 fps 2 hr. 20 min. 59 sec. 29 min. 59 sec. Approx. 30 Mbps
HD
(1280 x 720)
59.94 fps 59.94 fps 2 hr. 42 min. 28 sec. 29 min. 59 sec. Approx. 26 Mbps
*1 Using an SD Speed Class 10 / UHS-I compatible memory card.
Single-time recording will stop automatically when single recording reaches maximum recordable time or memory card becomes full. Recording may stop even if the max. recording time per single-time recording has not elapsed depending on the card used.
On memory cards with a capacity of 32GB and below, movies that exceed 4GB are divided into multiple files (Max. approx. 4GB each). On memory cards with a capacity of 64GB and above, the movies are not divided and will save as a single file.
* Measured on a card that was formatted with this camera.
Playback Functions Story Highlights, Protect, Favorites, Erase, Print, Play Movie, Image Search, Slideshow, Rotate, Play Creative Shot Movies, Short Clip Mix, Resize, Red-Eye Correction, Print Settings, Photobook Set-up, Group Images, Auto Rotate, Resume, Image Jump with Control Ring/Front Dial, Set Touch Actions
Video Out NTSC
Audio Out Stereo
Wired USB (Type-C), HDMI (Type D)
Wireless Bluetooth: Ver. 4.1
Wi-Fi&reg;*
Specifications: IEEE 802. 11b/g/n
Frequency: 2.4 GHz
Channels: 111
Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES-TKIP)
* Compatible with iOS&reg; versions 9.3/10.3/11.2-11.4/12.2, Android&trade; smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
Other Remote switch terminal available; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source Battery Pack NB-13L, Battery Charger CB-2LH
In-Camera Charging via USB Cable available through USB Power Adapter PD-E1 (Charging time: Approx. 110 min.)*
* Charging time varies considerably depending on the remaining battery power
Shooting Capacity Still Images:
Approx. 230 shots with Screen On
Approx. 180 shots with Viewfinder On
Approx. 320 shots with ECO Mode
Movie Recording Time:Approx. 55 min. with Screen On
Approx. 45 min. with Viewfinder On
Playback Time Approx. 4 hr.
Operating Temperature 32104&deg;F / 040&deg;C
Operating Humidity 1090%
Dimensions (W x H x D) 4.37 x 2.4 x 1.81 in. / 110.9 x 60.9 x 46.0mm
Weight
Approx. 12 oz. / 340g (including battery and memory card)
Approx. 11.1 oz. / 316g (camera body only)
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
Wireless API Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: PowerShot G5 X Mark II: Firmware Version 1.1.0
Advisory Type
Date 12.11.19
Title Canon Support | Firmware Notice: PowerShot G5 X Mark II: Firmware Version 1.1.0.0.
Advisory Type
Date 04.14.20
Title Canon Support | Service Notice: Picture Style File Registration
Advisory Type
Date 12.15.19
Title Canon Support | Future Firmware plan to support 24p video recording mode for select EOS and PowerShot models.
Advisory Type
Date 10.08.19
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
