Canon Support for PowerShot G5 X Mark II | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital camera with built-in flash, 5x Optical, 4x Digital and 20x Combined Zoom with Optical Image Stabilizer |
Type | 20.1 Megapixel*, 1.0-inch stacked CMOS (sensor aspect ratio: 3:2) * Image processing may cause a decrease in the number of pixels. |
Pixels | Effective Pixels: Approx. 20.1 Megapixels Total Pixels: Approx. 20.9 Megapixels |
Focal Length | 8.8 (W) 44.0(T) mm (35mm film equivalent: 24120mm) |
Optical Zoom | Approx. 5x |
Digital Zoom | Approx. 4x |
Focusing Range | Auto/Manual: 2.0 in. (5cm) infinity (W), 7.9 in. (20cm) infinity (T) Normal: 2.0 in. (5cm) infinity (W), 7.9 in. (20cm) infinity (T) Macro: 2.0 in. 1.6 ft. (550cm) (W) |
Autofocus System | TTL Autofocus, Manual Focus |
Viewfinder | Electronic Viewfinder (Approx. 2.36 million dots) |
LCD Monitor | 3.0-type TFT color liquid crystal (Vari-angle) |
LCD Pixels | Approx. 1.04 million dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/1.8 (W), f/2.8 (T) |
Shutter Speed | 11/2000 sec. (in Auto mode) 151/2000 sec. (in Tv, M, and Manual Movie Modes) 1/4000 sec. (Movie Shooting) 1/2000 sec. (Time-lapse Movie) |
ISO Sensitivity | Auto, ISO 125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200/4000/5000/6400 (When in Auto mode) Max. ISO Speed 12800 (When in P mode) |
Light Metering Method | Evaluative, Center Weighted Average, Spot (Still image only) |
Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock |
Exposure Compensation | Still Images: ±3 stops in 1/3-stop increments Videos: ±3 stops in 1/3-stop increments |
White Balance Control | Auto (Ambience & White priority), Day Light, Shade, Cloudy, Tungsten, White Fluorescent Light, Flash, Color Temperature, Custom |
Built-in Flash | Auto, On, Slow Synchro, Off |
Flash Range | 1.6 ft.(50cm) 24.6 ft. (7.5m) (W), 1.6 ft. (50cm) 14.8 ft. (4.5m) (T) Image brightness may diminish depending on the shooting distance. |
Flash Exposure Compensation | ±2 stops in 1/3-stop increments |
Picture Style | C, M, Av, Tv, P, Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def.1-3 |
Creative Filters | Grainy B/W, Soft Focus, Fish-eye Effect, Art Bold Effect, Water Painting Effect, Toy Camera Effect, Miniature Effect *Applicable only to images taken with same model. |
Self Timer | Off, 2 sec., 10 sec., Custom, Remote Shooting |
Wireless Control | Unavailable |
Electronic Level | Horizontal Roll Calibration, Vertical Pitch Calibration, Reset |
Continuous Shooting | JPEG, RAW, C-RAW: One Shot AF: Approx. 20 shots/sec. JPEG Servo AF: Approx. 8 shots/sec. RAW Burst Mode: Approx. 30 shots/sec. |
Storage Media | SD/SDHC/SDXC and UHS-I Memory Cards | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
File Format | Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
Image Recording Format | Superfine / Fine | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
JPEG Compression Mode | Still Image: Exif 2.3 (DCF 2.0), RAW (Canon original: 14-bit, CR2) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC [Stereo]) |
Number of Recording Pixels | Still Images:
Panoramic Shooting:
Approx. Number of Shots Recordable to 32 GB Memory Card |
Note: F=Fine N=Normal |
Time of Recordable Videos |
*1 Using an SD Speed Class 10 / UHS-I compatible memory card. |
Playback Functions | Story Highlights, Protect, Favorites, Erase, Print, Play Movie, Image Search, Slideshow, Rotate, Play Creative Shot Movies, Short Clip Mix, Resize, Red-Eye Correction, Print Settings, Photobook Set-up, Group Images, Auto Rotate, Resume, Image Jump with Control Ring/Front Dial, Set Touch Actions |
Video Out | NTSC |
Audio Out | Stereo |
Wired | USB (Type-C), HDMI (Type D) |
Wireless | Bluetooth: Ver. 4.1 Wi-Fi®* Specifications: IEEE 802. 11b/g/n Frequency: 2.4 GHz Channels: 111 Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES-TKIP) * Compatible with iOS® versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app. |
Other | Remote switch terminal available; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers |
Power Source | Battery Pack NB-13L, Battery Charger CB-2LH In-Camera Charging via USB Cable available through USB Power Adapter PD-E1 (Charging time: Approx. 110 min.)* * Charging time varies considerably depending on the remaining battery power |
Shooting Capacity | Still Images: Approx. 230 shots with Screen On Approx. 180 shots with Viewfinder On Approx. 320 shots with ECO Mode Movie Recording Time:Approx. 55 min. with Screen On Approx. 45 min. with Viewfinder On |
Playback Time | Approx. 4 hr. |
Operating Temperature | 32104°F / 040°C |
Operating Humidity | 1090% |
Dimensions (W x H x D) | 4.37 x 2.4 x 1.81 in. / 110.9 x 60.9 x 46.0mm |
Weight | Approx. 12 oz. / 340g (including battery and memory card) Approx. 11.1 oz. / 316g (camera body only) |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
Wireless API | Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
