Canon Support for PowerShot G7 X Mark III | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital camera with built-in flash, 4.2x Optical, 4x Digital and 17x Combined Zoom with Optical Image Stabilizer |
Type | 20.1 Megapixel*, 1.0-inch stacked CMOS (sensor aspect ratio: 3:2) * Image processing may cause a decrease in the number of pixels. |
Total Pixels | Approx. 20.9 megapixels |
Effective Pixels | Approx. 20.1 megapixels |
Focal Length | 8.8 (W) 36.8 (T) mm (35mm film equivalent: 24100mm) |
Optical Zoom | Approx. 4.2x |
Digital Zoom | Approx. 4x |
Focusing Range | Normal/Auto: 2.0 in. (5cm) infinity (W), 1.3 ft. (40cm) infinity (T) Macro: 2.0 in. 1.6 ft. (550 cm) (W) Quick: 5.065.6 ft. (1.520m) (W), 5.065.6 ft. (1.520m) (T) |
Autofocus System | TTL Autofocus, Manual Focus |
Optical Viewfinder | N/A |
LCD Monitor | 3.0-inch tilt-type TFT color liquid crystal, with biaxial tilt for low and high angle shooting |
LCD Pixels | Approx. 1.04 million dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/1.8 (W), f/2.8 (T) |
Shutter Speed | 11/2000 sec. (in Auto mode) 301/25600 sec. (in Tv, M, and Manual Movie Modes) BULB (in M mode only) 1/8 minimum in Manual Movie Mode |
Sensitivity | Still Images: ISO 1253200 (in Auto mode) Max. ISO Speed in P mode is ISO 12800 Videos:
Light Metering Method | Evaluative, Center Weighted Average, Spot (Still Images only) | ||||||||||||
Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock | ||||||||||||
Exposure Compensation | Still Images: ±3 stops in 1/3-stop increments Videos: ±3 stops in 1/3-stop increments |
White Balance Control | Auto (Ambience & White Priority), Day Light, Shade, Cloudy, Tungsten, White Fluorescent Light, Flash, Color Temperature, Custom |
Built-in Flash | Auto, On, Slow Synchro, Off |
Flash Range | 1.6 (50cm) 23 ft. (7.0m) (W), 1.6 ft. (50cm) 13 ft. (4.0m) (T) *Image brightness may diminish depending on the shooting distance. |
Flash Exposure Compensation | ±2 stops in 1/3-stop increments |
Shooting Modes | C, M, Av, Tv, P, Hybrid Auto, Auto, Self Portrait, Portrait, Panning, Star Portrait, Star Nightscape,Star Trails, Star Time-Lapse Movie, Handheld Night Scene, High Dynamic Range, Fish-eye Effect, Art Bold Effect, Water Painting Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Grainy B/W, Fireworks, Standard Movie, Short Clip, Manual Movie, Time-Lapse Movie, iFrame Movie |
Picture Style | Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 13 |
Self Timer | Off, 2 sec., 10 sec., Custom, Remote Shooting |
Wireless Control | Wi-Fi® |
Continuous Shooting | JPEG: One Shot AF (H): Approx. 20.0 shots/sec. One Shot (L): Approx. 3.0 shots/sec. Servo AF (H): Approx. 8.3 shots/sec. Servo AF (L): Approx. 3.0 shots/sec. RAW & C-RAW: One Shot AF (H): Approx. 20.0 shots/sec. One Shot (L): Approx. 3.0 shots/sec. RAW Burst Mode: Max: Approx. 30.0 shots/sec. |
Storage Media | SD/SDHC/SDXC and UHS-I Memory Cards | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
File Format | Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
Image Recording Format | Superfine / Fine | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
JPEG Compression Mode | Still Image: Exif 2.31 (DCF 2.0), RAW (Canon original: 14-bit, CR2) * JPEG/RAW (CR3 Canon original: 14-bit RAW format) RAW images are A/D converted into 12-bit format Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC [Stereo]) |
Number of Recording Pixels | Still Images:
Panoramic Shooting:
Approx. Number of Shots Recordable to 32 GB Memory Card |
* The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Time of Recordable Videos |
*1 Using an SD Speed Class 10 / UHS-I compatible memory card. |
Playback Functions | List/Play Digest Movies, Story Highlights, Protect, Favorites, Erase, Image Search, Slideshow, Rotate, Album Playback, Short Clip Mix, Resize, Cropping, Red-Eye Correction, Face ID Info, Creative Filters, RAW Image Processing, Photobook Set-up, Image Transition Effect, Index Effect, Scroll Display, Group Images, Auto Rotate, Resume, Image Jump with Control Ring/Front Dial, Set Touch Actions, Playback Information Display |
Audio Out | Stereo |
Wired | USB Type-C, HDMI (Type D) |
Wireless | Wi-Fi®* Specifications: IEEE 802. 11b/g/n Frequency: 2.4 GHz Channels: 111 Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES-TKIP) * Compatible with iOS® versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app. |
Other | Direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers |
Power Source | Battery Pack NB-13L, Battery Charger CB-2LH In-Camera Charging via USB Cable available through USB Power Adapter PD-E1 (Charging time: Approx. 110 min.)* * Charging time varies considerably depending on the remaining battery power |
Shooting Capacity | Approx. 235 shots with Screen On (CIPA compliant) Approx. 320 shots with ECO Mode |
Playback Time | Approx. 5 hrs. |
Operating Temperature | 32104°F / 040°C |
Operating Humidity | 1090% |
Dimensions (W x H x D) | 4.13 x 2.40 x 1.63 in. / 105.0 x 60.9 x 41.4mm |
Weight | Black & Silver Models: Approx. 10.7 oz. / 304g (including battery and memory card) Approx. 9.9 oz. / 280g (camera body only) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
