Canon Support for PowerShot G7 X Mark III | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type Digital camera with built-in flash, 4.2x Optical, 4x Digital and 17x Combined Zoom with Optical Image Stabilizer
Type 20.1 Megapixel*, 1.0-inch stacked CMOS (sensor aspect ratio: 3:2)
* Image processing may cause a decrease in the number of pixels.
Total Pixels Approx. 20.9 megapixels
Effective Pixels Approx. 20.1 megapixels
Focal Length 8.8 (W) 36.8 (T) mm (35mm film equivalent: 24100mm)
Optical Zoom Approx. 4.2x
Digital Zoom Approx. 4x
Focusing Range Normal/Auto: 2.0 in. (5cm) infinity (W), 1.3 ft. (40cm) infinity (T)
Macro: 2.0 in. 1.6 ft. (550 cm) (W)
Quick: 5.065.6 ft. (1.520m) (W), 5.065.6 ft. (1.520m) (T)
Autofocus System TTL Autofocus, Manual Focus
Optical Viewfinder N/A
LCD Monitor 3.0-inch tilt-type TFT color liquid crystal, with biaxial tilt for low and high angle shooting
LCD Pixels Approx. 1.04 million dots
LCD Coverage Approx. 100%
Maximum Aperture f/1.8 (W), f/2.8 (T)
Shutter Speed 11/2000 sec. (in Auto mode)
301/25600 sec. (in Tv, M, and Manual Movie Modes)
BULB (in M mode only)
1/8 minimum in Manual Movie Mode
Sensitivity Still Images:
ISO 1253200 (in Auto mode)
Max. ISO Speed in P mode is ISO 12800
Videos:
Pixels
Frame Rate
Min. ISO Speed
Max. ISO Speed
4K
(3840 x 2160)
29.97 fps ISO 125-3200
FULL HD
(1920 x 1080)
59.94 fps ISO 125-6400
29.97 fps
HD
(1280 x 720)
Light Metering Method Evaluative, Center Weighted Average, Spot (Still Images only)
Exposure Control Method Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation Still Images: &plusmn;3 stops in 1/3-stop increments
Videos: &plusmn;3 stops in 1/3-stop increments
White Balance Control Auto (Ambience & White Priority), Day Light, Shade, Cloudy, Tungsten, White Fluorescent Light, Flash, Color Temperature, Custom
Built-in Flash Auto, On, Slow Synchro, Off
Flash Range 1.6 (50cm) 23 ft. (7.0m) (W), 1.6 ft. (50cm) 13 ft. (4.0m) (T)
*Image brightness may diminish depending on the shooting distance.
Flash Exposure Compensation &plusmn;2 stops in 1/3-stop increments
Shooting Modes C, M, Av, Tv, P, Hybrid Auto, Auto, Self Portrait, Portrait, Panning, Star Portrait, Star Nightscape,Star Trails, Star Time-Lapse Movie, Handheld Night Scene, High Dynamic Range, Fish-eye Effect, Art Bold Effect, Water Painting Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Grainy B/W, Fireworks, Standard Movie, Short Clip, Manual Movie, Time-Lapse Movie, iFrame Movie
Picture Style Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 13
Self Timer Off, 2 sec., 10 sec., Custom, Remote Shooting
Wireless Control Wi-Fi&reg;
Continuous Shooting JPEG:
One Shot AF (H): Approx. 20.0 shots/sec.
One Shot (L): Approx. 3.0 shots/sec.
Servo AF (H): Approx. 8.3 shots/sec.
Servo AF (L): Approx. 3.0 shots/sec.
RAW & C-RAW: One Shot AF (H): Approx. 20.0 shots/sec.
RAW Burst Mode:
Max: Approx. 30.0 shots/sec.
Storage Media SD/SDHC/SDXC and UHS-I Memory Cards
File Format Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible
Image Recording Format Superfine / Fine
JPEG Compression Mode Still Image: Exif 2.31 (DCF 2.0), RAW (Canon original: 14-bit, CR2)
* JPEG/RAW (CR3 Canon original: 14-bit RAW format) RAW images are A/D converted into 12-bit format
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC [Stereo])
Number of Recording Pixels
Still Images:
16:9
3:2
4:3
1:1
Large
5472 x 3072 5472 x 3648 4864 x 3648 3648 x 3648
Medium
3648 x 2048 3648 x 2432 3248 x 2432 2432 x 2432
Small (S1)
2736 x 1536 2736 x 1824 2432 x 1824 1824 x 1824
Small (S2)
2400 x 1344 2400 x 1600 2112 x 1600 1600 x 1600
RAW
-5472 x 36485472 x 3648-
RAW + JPEG
C- RAW
- 5472 x 3648 5472 x 3648 -
C-RAW + JPEG
Panoramic Shooting:
Min. Number of Recording Pixels
Max. Number of Recording Pixels
Vertical Shooting
3840 x 3648 16000 x 3840
Horizontal Shooting
5472 x 2560 26064 x 2560
Approx. Number of Shots Recordable to 32 GB Memory Card
Large (L)
Fine
Approx. 4535 shots
Normal
Approx. 8062 shots
Medium
Fine
Approx. 7742 shots
Normal
Approx. 9999 shots
Small (S)
Fine
Normal
Small 1 (S1)
Fine
Approx. 9999 shots
Normal
Small 2 (S2)
Approx. 9999 shots
RAW
Approx. 1355 shots
RAW + JPEG
Approx. 1031 shots
C- RAW
Approx. 2301 shots
C-RAW + JPEG
Approx. 1525 shots
* The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Time of Recordable Videos
Shooting Mode
Pixels
Frame Rate
Approx. Total Movie Time Recordable to 32 GB Memory Card
Single Clip Approx. Recording Time*1
Video Recording Bit Rate
Standard Movie
4K
(3840 x 2160)
29.97 fps 35 min. 29 sec. 9 min. 59 sec. Approx. 120 Mbps
FULL HD
(1920 x 1080)
119.88 fps 35 min. 33 sec. 7 min. 29 sec. Approx. 120 Mbps
59.94 fps 1 hr. 10 min. 48 sec. 29 min. 59 sec. Approx. 60 Mbps
29.97 fps 2 hr. 20 min. 59 sec. 29 min. 59 sec. Approx. 30 Mbps
HD
(1280 x 720)
59.94 fps 2 hr. 42 min. 28 sec. 29 min. 59 sec. Approx. 26 Mbps
*1 Using an SD Speed Class 10 / UHS-I compatible memory card.
Single-time recording will stop automatically when single recording reaches maximum recordable time or memory card becomes full. Recording may stop even if the max. recording time per single-time recording has not elapsed depending on the card used.
On memory cards with a capacity of 32GB and below, movies that exceed 4GB are divided into multiple files (Max. approx. 4GB each). On memory cards with a capacity of 64GB and above, the movies are not divided and will save as a single file.
* Measured on a card that was formatted with this camera.
Playback Functions List/Play Digest Movies, Story Highlights, Protect, Favorites, Erase, Image Search, Slideshow, Rotate, Album Playback, Short Clip Mix, Resize, Cropping, Red-Eye Correction, Face ID Info, Creative Filters, RAW Image Processing, Photobook Set-up, Image Transition Effect, Index Effect, Scroll Display, Group Images, Auto Rotate, Resume, Image Jump with Control Ring/Front Dial, Set Touch Actions, Playback Information Display
Audio Out Stereo
Wired USB Type-C, HDMI (Type D)
Wireless Wi-Fi&reg;*
Specifications: IEEE 802. 11b/g/n
Frequency: 2.4 GHz
Channels: 111
Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES-TKIP)
* Compatible with iOS&reg; versions 9.3/10.3/11.2-11.4/12.2, Android&trade; smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
Other Direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source Battery Pack NB-13L, Battery Charger CB-2LH
In-Camera Charging via USB Cable available through USB Power Adapter PD-E1 (Charging time: Approx. 110 min.)*
* Charging time varies considerably depending on the remaining battery power
Shooting Capacity Approx. 235 shots with Screen On (CIPA compliant)
Approx. 320 shots with ECO Mode
Playback Time Approx. 5 hrs.
Operating Temperature 32104°F / 040°C
Operating Humidity 1090%
Dimensions (W x H x D) 4.13 x 2.40 x 1.63 in. / 105.0 x 60.9 x 41.4mm
Weight
Black & Silver Models:
Approx. 10.7 oz. / 304g (including battery and memory card)
Approx. 9.9 oz. / 280g (camera body only)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: PowerShot G7 X Mark III: Firmware Version 1.2.0
Advisory Type
Date 12.11.19
Title Canon Support | Service Notice: To Users of Canon's PowerShot G7X Mark III Compact Digital Camera
Advisory Type
Date 09.09.19
Title Canon Support | Service Notice: Picture Style File Registration
Advisory Type
Date 12.15.19
Title Firmware Notice: PowerShot G7 X Mark III: Firmware Version 1.3.2
Advisory Type
Date 06.07.22
Title Canon Support | Future Firmware plan to support 24p video recording mode for select EOS and PowerShot models.
Advisory Type
Date 10.08.19
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
