Canon Support for PowerShot S10 | Canon U.S.A., Inc.
PowerShot S10
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Image Capture Device
| Type | 1/1.8 inch Charge-Coupled Device(CCD) |
| Total Pixels | Approx. 2.11 million |
| Effective Pixels | Approx. 2.02 million |
Lens
| Focal Length | 6.3mm(Wide-angle) to 12.6mm(Telephoto)(35mm film equivalent: 35 - 70mm) |
| Focusing Range | Standard:46cm (1.5 ft) to infinity Macro: 12cm (4.7 in.) - 46cm (1.5 ft) |
Viewfinders
| Optical Viewfinder | Real-image optical viewfinder. Magnification: 0.35 (Wide-angle) - 0.70 (Telephoto). Coverage: (V) 80% (H) 80% (when object is 2m away). |
| LCD Monitor | 1.8 inch low-temperature polycrystalline silicon TFT LCD |
| LCD Pixels | 113,578 dots (521 x 218) |
| LCD Coverage | 88.7% |
Aperture and Shutter
| Maximum Aperture | Maximum: F/2.8-F/8.0 (Wide-angle) Minimum: F/4.0-F/8.0 (Telephoto) |
| Shutter Speed | 2-1/1,000 sec. (2 sec. for Slow Shutter or Night Scene mode) |
Exposure Control
| Sensitivity | Equivalent to ISO 100-400 (ISO 400 for gain up setting) |
| Light Metering Method | Center-weighted metering/spot metering |
| Exposure Control Method | Program AE |
| Exposure Compensation | +/- 2EV in 1/3-stop increments |
White Balance
| White Balance Control | TTL |
Flash
| Flash Range | 0.17 (0.6 ft) - 3.3m (10.8 ft) (wide-angle), 0.17 (0.6 ft) - 2.3m (7.5 ft) (telephoto)in total darkness |
| Recycling Time | Approx. 10 sec. or shorter (battery voltage = 6.0V) |
Shooting Specifications
| Shooting Modes | Auto, manual, flash, self-timer, macro, continuous, (1.7 fps), Stitch Assist, Image (5 menu) |
| Continuous Shooting | 1.7 images/sec. (in Large/Fine mode using optical finder) |
Image Storage
| Storage Media | CompactFlash card (Type I and II) |
| File Format | Design rule for Camera File System |
| Print Order Format | DPOF |
| Image Recording Format | JPEG or CCD-RAW |
| JPEG Compression Mode | Normal, Fine, Super Fine |
| Number of Recording Pixels | Large: 1,600 (H) x 1,200 (V)Middle: 1280 (H) x 960 (V)Small: 800 (H) x 600 (V) |
Number of Recordable Images
| Image data |  Storage capacity varies depending on the scene or subjects. This data is estimated from Canon's standard shooting conditions. These numbers are the values in the Auto or Program modes. In the Stitch Assist mode there is a possibility that the shooting capacity will be slightly lower than in the full Auto or Program Mode. |
Playback Specifications
| Playback Modes File | Single image, multiple images (9 thumbnails) |
Erasing Specifications
| Erase Modes | Single image, all images |
Interfaces
| Computer Interface | Serial (RS 232C)/USB |
| Video Out | NTSC |
| Other | CF Card Slot (Type I and Type II) |
| Power Supply | 1. 2CR5 Lithium-manganese Battery (Non-rechargeable) 2. NB-5H Nickel-Metal Hydride Battery (Rechargeable) 3. DR100A DC Coupler plus CA-PS100E Compact Power Adapter (Dedicated AC Adapter) |
| Power Source | 1. 2CR5 Lithium-manganese Battery (Non-rechargeable) 2. NB-5H Nickel-Metal Hydride Battery (Rechargeable) 3. DR100A DC Coupler plus CA-PS100E Compact Power Adapter (Dedicated AC Adapter) |
Physical Specifications
| Operating Temperature | 32°F - 104°F (0°C - 40°C) |
| Operating Humidity | 10% - 90% |
| Dimensions (W x H x D) | 4.1 x 2.7 x 1.3 in / 105.4 x 69.4 x 33.8 mm |
| Weight | Approx. 270g (9.5 oz) excluding battery and CompactFlash card |
Computer System Requirements
| Mac Requirements | Hardware Power Macintosh, PowerBook, iMac or iBook OS Mac OS 7.5, Quicktime 2.1 (Please see our Mac OS X Compatibility Statement.) CPU PowerPC RAM 20 MB or more of application memory Interface USB (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook)- Limited to genuine Apple Computer brand models with built-in USB interface - iMac computers running Mac OS 8.1 require installation of the "iMac Update 1.0" and "iMac Firmware Update 1.0" RS 422 (Printer or modem port for PowerShot S10/S20 models only) Free Hard Disk Space Canon Utilities Image Browser: 20 MB or more Canon Utilities PhotoStitch: 30 MB or more Canon Digital Camera Plug-in Module: 15 MB or more Adobe PhotoDeluxe: 70 MB or more Display Minimum: 800 x 600 pixels, 256 colors Recommended: 1,024 x 768 pixels, Thousands of colors or more |
| PC Requirements | Hardware IBM PC/AT compatible OS Windows 95/98 (including the Second Edition) Windows NT 4.0 (Service Pack 3 or higher required) Windows 2000Windows ME(Please see our Windows XP Compatibility Statement.) CPU Pentium 133 MHz or better RAM 32 MB or more (Windows 95/98) 64 MB or more (Windows NT/2000/ME) Interface USB (Limited to pre-installed Windows 98, Windows 2000 or Windows ME Systems as well as Windows ME Systems upgraded from Windows 98) RS-232C (Serial/COM port for PowerShot S10/S20 only) Free Hard Disk Space Canon Utilities ZoomBrowser EX: 120 MB or more (including the PhotoRecord printing utility) Canon Utilities PhotoStitch: 40 MB or more Canon Digital Camera USB TWAIN Driver: 15 MB or more Canon Digital Camera RS-232C TWAIN Driver: 15 MB or more Adobe PhotoDeluxe Home Edition: 140 MB or more (works with the Windows 95/98/NT 4.0 operating systems) Display Minimum: 800 x 600 pixels, 256 colors Recommended: 1,024 x 768 pixels, High Color (16 bit) or more |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
