Canon Support for PowerShot S120 | Canon U.S.A., Inc.
PowerShot S120
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/1.7-inch CMOS
Total Pixels
Approx. 12.8 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
5.2 (W) - 26.0 (T) mm (35mm film equivalent: 24-120mm)
Optical Zoom
5.0x
Digital Zoom
4.0x
Focusing Range
Normal: 2.0 in. (5cm) - infinity (W), 12 in. (30cm) - infinity (T)
Auto/Manual: 1.2 in. (3cm) - infinity (W), 12 in. (30cm) - infinity (T)
Macro AF: 1.2 in. - 1.6 ft. (3-50cm) (W), 12 in. - 1.6 ft. (30-50cm) (T)
Quick: 4.9 - 66 ft. (1.5 - 20m) (W,T)
Autofocus System
TTL Autofocus, Manual Focus
Optical Viewfinder
Not available
LCD Monitor
3.0-inch TFT Color LCD with wide viewing angle capacitive touch-screen panel
LCD Pixels
Approx. 922,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/1.8 (W), f/5.7 (T)
Shutter Speed
1-1/2500 sec.
15-1/2500 sec. (in Tv mode)
250-1/2500 sec. (in M mode)
Sensitivity
Auto, ISO 80-12800 (in P mode)
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation
Still Images: &plusmn;3 stops in 1/3-stop increments
Videos: &plusmn;3 stops in 1/3-stop increments (not available during shooting)
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater, Custom 1, Custom 2
* Camera automatically sets the optimal ISO speed according to shooting mode.
Built-in Flash
Auto, Flash On, Slow Synchro, Flash Off
Facial brightness is also evaluated in Face Detect.
Flash Range
1.6 ft. - 23 ft. (W), 1.6 - 7.5 ft. (T) (50cm - 7m (W), (50cm - 2.3m (T))
Image brightness may diminish depending on the shooting distance.
Recycling Time
10 sec. or less (battery voltage: 3.7 V)
Flash Exposure Compensation
&plusmn; 2 stops in 1/3-stop increments
Shooting Modes
C, M, Av, Tv, P, Hybrid Auto, Auto, SCN*1, Creative Filters*2, Movie*3
Shooting movies is possible with the movie button
*1 Portrait, Smart Shutter*4, Star*5, Handheld Night Scene, Underwater, Snow, Fireworks
*2 High Dynamic Range, Nostalgic, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Monochrome, Super Vivid, Poster Effect
*3 Standard, Super Slow Motion Movie
*4 Smile, Wink Self-timer, Face Self-timer
*5 Star Nightscape, Star Trails, Star Time-Lapse Movie
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
*Adjustment of contrast sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
*Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
Not available
Continuous Shooting
Normal: Approx. 12.1 shots/sec.; 9.4 shots/sec* (in P mode) AF: Approx. 5.5 shots/sec. (in P mode) LV: Approx. 5.6 shots/sec. (in P mode) Under conditions where the flash does not fire automatically Differs depending on the zoom position*From the sixth shot
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
Superfine / Fine
JPEG Compression Mode
Still Image: Exif. 2.3 (JPEG)
Video: MOV (Image: H.264; Audio: Linear PCM (Stereo))
Number of Recording Pixels
Still Images:
1) 16:9 - Large: 4000 x 2248; Medium 1: 2816 x 1584; Medium 2: 1920 x 1080; Small: 640 x 360; RAW: 4000 x 2248
2) 3:2 - Large: 4000 x 2664; Medium 1: 2816 x 1880; Medium 2: 1600 x 1064; Small: 640 x 424; RAW: 4000 x 2664
3) 4:3 - Large: 4000 x 3000; Medium 1: 2816 x 2112; Medium 2: 1600 x 1200; Small: 640 x 480; Raw: 4000 x 3000
4) 1:1 - Large: 2992 x 2992; Medium 1: 2112 x 2112; Medium 2: 1200 x 1200; Small: 480 x 480; RAW: 2992 x 2992
5) 4:5 - Large: 2400 x 3000; Medium 1: 1696 x 2112; Medium 2: 960 x 1200; Small: 384 x 480; RAW: 2400 x 3000
Videos:
Full HD 1920 x 1080: 60 fps (59.94), 30 fps
Full HD Star Time-Lapse Movie: 15 fps
HD 1280 x 720: 30 fps (29.97)
Miniature Effect HD 1280 x 720: 6 fps / 3 fps / 1.5 fps
Miniature Effect 640 x 480: 6 fps / 3 fps / 1.5 fps
Super Slow Motion Movie 640 x 480: 120 fps
Super Slow Motion Movie 320 x 240: 240 fps
640 x 480: 30 fps (29.97)
Image data
Note: SF=Superfine F=Fine
The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
&#42;1Actual frame rate is 29.97 fps.
&#42;2Playback frame rate is 30 fps.&#42;1
&#42;3Actual frame rate is 14.985 fps.
&#42;4Actual frame rate is 59.94 fps.
Playback Modes File
Stills & Videos:
Auto Rotate, Index Continuous Display, Image Advance (Transition Effects, Scroll Display), Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Slideshow, Erase, Resume, Protect
Still Images:
Single, Index, Magnification (2-10x), Switch to other images while zoomed, Information Display, Red-eye Correction, i-Contrast, Photobook Setup, Cropping, Resize, My Colors, Face ID Info, Histogram, RGB Histogram, Focus Checker, Location Information, Overexposure Warning
Videos:
Normal Playback, Pause, Slow Motion, Skip Backward, Previous Frame, Next Frame, Skip Forward, Erase Clip, Editing, Movie Transcoding
Using the software included with the camera (ImageBrowser EX), there are 8 levels (1.8x to 1x) of playback speed for Super Slow Motion Movies possible on a computer.
Erase Modes
Select Image, Select Range, Select All Images
The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).Using the Movie editing function, sections of the movie can be deleted.
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video), Mini-HDMI connector
Audio Out
Stereo (dedicated connector (female) with unified type of digital, audio and video)
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
Battery Pack NB-6LH, Compact Power Adapter CA-DC10 (included with AC Adapter Kit ACK-DC40)
Shooting Capacity
Approx. 230 shots
Approx. 300 shots with ECO Mode
Playback Time
Approx. 4 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.94 x 2.32 x 1.14 in. / 100.2 x 59.0 x 29.0mm
Weight
7.65 oz. / 217g (CIPA standard)
6.81 oz. / 193g (camera only)30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malay, Indonesian and Vietnamese).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Insufficient Contact to the Camera's Battery Terminal
Advisory Type
Date 01.13.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
