Canon Support for PowerShot S2 IS | Canon U.S.A., Inc.
PowerShot S2 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.25.07
File Size 1.04 MB
Date 03.05.10
File Size 6.07 MB
Date 05.23.08
File Size 3.36 MB
Date 10.25.07
File Size 3.36 MB
Date 03.05.10
File Size 6.23 MB
Date 10.25.07
File Size 420.60 KB
Date 10.25.07
File Size 3.19 MB
Date 05.23.08
File Size 1.20 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital camera with built-in flash and 12x Optical / 4x Digital / 48x Combined Zoom
Image Capture Device
Type 5.0 Megapixel, 1/2.5 inch type Charge Coupled Device (CCD)
Total Pixels Approx. 5.3 Megapixels
Effective Pixels Approx. 5.0 Megapixels
Lens
Focal Length 6.0 - 72.0mm f/2.7-3.5 (35mm film equivalent: 36-432mm)
Digital Zoom 4x
Focusing Range Normal: 1.6 ft./50cm-Infinity (W), 3.0 ft./90cm-Infinity (T)
Macro: 3.9 in.-1.6 ft./10-50cm
Super Macro: 0-3.9 in./0-10cm
Autofocus System TTL Autofocus (continuous/single)
Viewfinders
Optical Viewfinder 0.33 inch low-temperature polycrystalline silicon TFT color LCD
LCD Monitor 1.8 inch low-temperature polycrystalline silicon TFT color LCD with variable-angle function
LCD Pixels Approx. 115,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.7 (W) - 3.5 (T)
Shutter Speed 15-1/3200 sec.; Slow shutter speed of 15-1.3 sec. is only available in select modes.
Exposure Control
Sensitivity AUTO, ISO 50/100/200/400 equivalent
Light Metering Method Evaluative, Center-weighted Average, Spot** Metering frame with Spot Mode is center-fixed.
Exposure Control Method Program AE, Shutter speed-priority AE, Aperture-priority AE, Manual AE Lock is available
Exposure Compensation +/-2 stops in 1/3-stop increments
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash), Custom
Flash
Built-in Flash Operation Modes: Auto, Red-Eye Reduction ON/OFF
Flash Range Normal: 2.3-17.1 ft./0.7-5.2m (W), 2.3-13.1 ft./0.7-4.0m (T)
Macro: 1.0 ft.-2.3 ft./0.3-0.7m (when sensitivity is set to ISO 100 equivalent)
Recycling Time Approx. 10 sec. or less (battery voltage=7.4V)
Flash Exposure Compensation +/- 2 stops in 1/3-stop increments
Shooting Specifications
Shooting Modes Auto; Creative zone: P, Av, Tv, M, C; Image zone: Portrait, Landscape, Night Scene, Special Scene (Foliage, Snow, Beach, Fireworks, Indoor, Night Snapshot), Stitch Assist, Movie, My Colors
Photo Effects Off, Vivid, Neutral, Low Sharpening, Sepia, Black & White, Custom
Self Timer Activates shutter after an approx. 2 sec., approx. 10 sec. delay, Custom
Wireless Control Not available
Continuous Shooting High-speed: approx. 2.4 shots/sec.
Normal: approx. 1.5 shots/sec. (Large/Fine mode)
Image Storage
Storage Media SD Memory Card
File Format Design rule for camera file system, DPOF Version 1.1 (Digital Print Order Format)
Image Recording Format Normal, Fine, SuperFine
JPEG Compression Mode Still Image: Exif 2.2 (JPEG)
Movie: AVI (Image data: Motion JPEG;
Audio data: WAVE (Stereo))
Number of Recording Pixels Still Image: 2,592 x 1,944 (Large), 2,048 x 1,536 (Medium 1), 1,600 x 1,200 (Medium 2), 640 x 480 (Small)
Movie: 640 x 480 (VGA Fine/VGA), 320 x 240 (QVGA)
Number of Recordable Images
Image data
Time of Recordable Movies
Movie data Note: N=Normal F=Fine SF=SuperFine Storage capacity varies depending on the scene or the subjects. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of SD memory card.
Playback Specifications
Playback Modes File Single, Index (9 thumbnail images), Slide show, Magnification (approx. 2 to 10x), Jump, Movie
Erasing Specifications
Erase Modes Still Image: Single image, All images
Movie: Part of movie, All of movie
Interfaces
Computer Interface USB 2.0 Hi-Speed (mini-B PTP)
Video Out NTSC, PAL
Audio Out Stereo
Other SD memory card slot. Direct connection to Canon CP Printers and PIXMA Photo Printers via camera's USB cable (no computer required) or PictBridge compatible printers.
Power Supply 1. AA-size Alkaline Battery (x4)
2. AA-size NiMH Battery (x4)
3. Compact Power Adapter CA-PS700Still Image: approx. 130 shots (AA-size Alkaline Battery), approx. 550 shots (AA-size NiMH Battery)
*1Movie: approx. 210 min. (AA-size Alkaline Battery), approx. 300 min. (AA-size NiMH Battery) *1Approx. 800 min. (AA-size Alkaline Batteries), approx. 900 min. (AA-size NiMH Batteries)*
*Under Canon's standard conditions.
*1 With fully charged battery
Power Source 1. AA-size Alkaline Battery (x4)
Shooting Capacity Still Image: approx. 130 shots (AA-size Alkaline Battery), approx. 550 shots (AA-size NiMH Battery)
Playback Time Approx. 800 min. (AA-size Alkaline Batteries), approx. 900 min. (AA-size NiMH Batteries)*
Physical Specifications
Operating Temperature 32-104&deg F/0-40&deg C
Operating Humidity 10-90%
Dimensions (W x H x D) 4.45 x 3.07 x 2.97 in. / 113.0 x 78.0 x 75.5mm (excluding protrusions)
Weight Approx. 14.3 oz./405g (camera body only)
21 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish)
Note: *1 Normal temperature (73&deg F/23&deg C). Shoot images at wide-angle and at telephoto and alternatively with 30 second intervals. Use flash every two shots. Turn camera off and on after every ten shots. LCD brightness setting by Factory default.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
