Canon Support for PowerShot S40 | Canon U.S.A., Inc.
PowerShot S40
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 03.31.07
File Size 2.45 MB
Date 03.31.07
File Size 2.92 MB
Date 03.04.10
File Size 6.07 MB
Date 03.04.10
File Size 6.23 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact Digital Still Camera with Built-in Flash and 3x Optical Zoom Lens.
Image Capture Device
Type 1/1.8-inch Charge-Coupled Device (CCD
Total Pixels Approx. 4.1 million
Effective Pixels Approx. 4 million
Lens
Focal Length 7.1-21.3mm (35mm film equivalent: 35 - 105mm)
Digital Zoom 3.6x (Maximum 11x digital zoom is available when combined with optical zoom.)
Focusing Range Normal AF: 80cm (2.7 ft.) - infinity
Macro AF: 10cm (0.3 ft.) (wide-angle) / 20cm (0.7 ft.) (telephoto) - 70cm (2.3 ft.)
Manual focus: 6cm (0.2ft.) (wide-angle) / 30cm (1.0 ft.) (telephoto) - 80cm (2.7 ft.)
Autofocus System TTL autofocus (Continuous or Single); AF lock and Manual focus are available
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.8-inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels 117,600 dots (490 x 240)
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8 - f/8.0 (wide-angle), f/4.9 - f/8.0 (telephoto)
Shutter Speed 15 - 1/1,500 sec. Slow shutter operates with noise reduction.
Exposure Control
Sensitivity Auto, or user-set ISO 50, 100, 200, 400 equivalent (At Auto setting, camera automatically adjusts sensitivity in the range of ISO 50 to ISO 100 equivalent.)
Light Metering Method Evaluation metering, Center-weighted average metering or Spot metering (Fix to center/Link to AF frame).
Exposure Control Method Program AE, Shutter priority AE, Aperture priority AE or Manual exposure control; AE lock is available.
Exposure Compensation +/- 2.0EV in 1/3-step increments. Auto Exposure Bracketing (AEB) is available.
White Balance
White Balance Control TTL Auto White Balance, Pre-set White Balance (available settings: Daylight, Cloudy, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash) or Custom White Balance
Flash
Built-in Flash Operation modes: Auto, Red-Eye Reduction Auto, Red-Eye Reduction ON, flash ON or OFF
Flash Range Nomal: WIDE: 0.4-4.8m (1.1-16 ft) TELE: 0.4-3m (1.1-9.8 ft) (When Auto) Macro: WIDE: 0.6-4m (1.8-13 ft) TELE: 0.6-2.5m (1.8-8.2 ft) (When sensitivity is set to ISO 100 equivalent)
Recycling Time 10 sec. or shorter (full flash, battery voltage=7.4 V).
Terminals for External Flash +/- 2.0EV (at every 1/3-stop)
Shooting Specifications
Shooting Modes Creative zone: Program, Shutter priority, Aperture priority and Manual Image zone: AUTO, Portrait, Landscape, Night Scene, High-speed Shutter, Slow Shutter, Photo Effect (Black & White, Sepia, Neutral Color, Vivid Color), Stitch Assist and Movie
Self Timer Operates with approx. 2 or 10 second countdown. (Selectable)
Continuous Shooting High Speed: Approx. 2.5 images/sec., Normal: Approx. 1.5 images/sec.
Image Storage
Storage Media CompactFlash (CF) card (Type I or Type II)
File Format Design rule for Camera File system (DCF*1)
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still image: JPEG or RAW
Movie: AVI; Image data: Motion JPEG, Audio data: WAVE (monoaural)
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels Still image: Large: 2,272 x 1,704, Medium High: 1,600 x 1,200, Medium Low: 1,024 x 768, Small: 640 x 480, Movie: 320 x 240 (15bps) or 160 x 120 (15bps)
Number of Recordable Images
Image data &#160;These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data &#160;Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings.
Playback Specifications
Playback Modes File Single, Index (9 thumbnail images), Magnification (approx. 3x or 6x on built-in LCD monitor) or Slide Show
Erasing Specifications
Erase Modes Single Image, All Images
Interfaces
Computer Interface Universal Serial Bus (USB)
Video Out Audio/Video Output (NTSC or PAL selectable, monaural audio)
Other CF card slot (complied with CF Type II standard). Direct connection to Canon Card Photo Printer CP-10 (no computer required).
Power Supply Rechargeable Lithium-ion battery (type: NB-2L) or AC Adapter Kit ACK 700 is necessary.LCD ON: Approx. 180 images LCD OFF: Approx. 420 images (under Canon's standard conditions*2 with full-charged battery)Approx. 150 min. (under Canon's standard conditions*3 with full-charged battery)
Power Source Rechargeable Lithium-ion battery (type: NB-2L) or AC Adapter Kit ACK 700 is necessary.
Shooting Capacity LCD ON: Approx. 180 images LCD OFF: Approx. 420 images (under Canon's standard conditions*2 with full-charged battery)
Playback Time Approx. 150 min. (under Canon's standard conditions*3 with full-charged battery)
Physical Specifications
Operating Temperature 32-104&deg;F (0-40&deg;C)
Operating Humidity 10-90%
Dimensions (W x H x D) 4.4 x 2.3 x 1.7 in. /112.0 x 58.0 x 42.0 mm. (excluding protruding parts)
Weight Approx. 9.2oz./260g (camera body only)
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 8.6 through 9.1 (Please see our Mac OS X Compatibility Statement)CPU: Power PC Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook). RAM: 20MB and over for application
PC Requirements Hardware: IBM PC/AT compatible OS: Windows 98 (including the Second Edition), Windows 2000, Windows Me, Windows XP (Please see our Windows XP compatibility statement)CPU: Pentium 150 MHz and over Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems. RAM: 32MB or more (Windows 98)RAM: 64MB or more (Windows 2000/Windows ME
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
