Canon Support for PowerShot S40 | Canon U.S.A., Inc.
PowerShot S40
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
| Type | Compact Digital Still Camera with Built-in Flash and 3x Optical Zoom Lens. |
Image Capture Device
| Type | 1/1.8-inch Charge-Coupled Device (CCD |
| Total Pixels | Approx. 4.1 million |
| Effective Pixels | Approx. 4 million |
Lens
| Focal Length | 7.1-21.3mm (35mm film equivalent: 35 - 105mm) |
| Digital Zoom | 3.6x (Maximum 11x digital zoom is available when combined with optical zoom.) |
| Focusing Range | Normal AF: 80cm (2.7 ft.) - infinity Macro AF: 10cm (0.3 ft.) (wide-angle) / 20cm (0.7 ft.) (telephoto) - 70cm (2.3 ft.) Manual focus: 6cm (0.2ft.) (wide-angle) / 30cm (1.0 ft.) (telephoto) - 80cm (2.7 ft.) |
| Autofocus System | TTL autofocus (Continuous or Single); AF lock and Manual focus are available |
Viewfinders
| Optical Viewfinder | Real-image optical zoom viewfinder |
| LCD Monitor | 1.8-inch low-temperature polycrystalline silicon TFT color LCD |
| LCD Pixels | 117,600 dots (490 x 240) |
| LCD Coverage | 100% |
Aperture and Shutter
| Maximum Aperture | f/2.8 - f/8.0 (wide-angle), f/4.9 - f/8.0 (telephoto) |
| Shutter Speed | 15 - 1/1,500 sec. Slow shutter operates with noise reduction. |
Exposure Control
| Sensitivity | Auto, or user-set ISO 50, 100, 200, 400 equivalent (At Auto setting, camera automatically adjusts sensitivity in the range of ISO 50 to ISO 100 equivalent.) |
| Light Metering Method | Evaluation metering, Center-weighted average metering or Spot metering (Fix to center/Link to AF frame). |
| Exposure Control Method | Program AE, Shutter priority AE, Aperture priority AE or Manual exposure control; AE lock is available. |
| Exposure Compensation | +/- 2.0EV in 1/3-step increments. Auto Exposure Bracketing (AEB) is available. |
| Auto Exposure Bracketing | (AEB) is available. |
White Balance
| White Balance Control | TTL Auto White Balance, Pre-set White Balance (available settings: Daylight, Cloudy, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash) or Custom White Balance |
Flash
| Built-in Flash | Operation modes: Auto, Red-Eye Reduction Auto, Red-Eye Reduction ON, flash ON or OFF |
| Flash Range | Nomal: WIDE: 0.4-4.8m (1.1-16 ft) TELE: 0.4-3m (1.1-9.8 ft) (When Auto) Macro: WIDE: 0.6-4m (1.8-13 ft) TELE: 0.6-2.5m (1.8-8.2 ft) (When sensitivity is set to ISO 100 equivalent) |
| Recycling Time | 10 sec. or shorter (full flash, battery voltage=7.4 V). |
| Terminals for External Flash | +/- 2.0EV (at every 1/3-stop) |
Shooting Specifications
| Shooting Modes | Creative zone: Program, Shutter priority, Aperture priority and Manual Image zone: AUTO, Portrait, Landscape, Night Scene, High-speed Shutter, Slow Shutter, Photo Effect (Black & White, Sepia, Neutral Color, Vivid Color), Stitch Assist and Movie |
| Self Timer | Operates with approx. 2 or 10 second countdown. (Selectable) |
| Continuous Shooting | High Speed: Approx. 2.5 images/sec., Normal: Approx. 1.5 images/sec. |
Image Storage
| Storage Media | CompactFlash (CF) card (Type I or Type II) |
| File Format | Design rule for Camera File system (DCF*1) |
| Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
| Image Recording Format | Still image: JPEG or RAW Movie: AVI; Image data: Motion JPEG, Audio data: WAVE (monoaural) |
| JPEG Compression Mode | SuperFine, Fine or Normal |
| Number of Recording Pixels | Still image: Large: 2,272 x 1,704, Medium High: 1,600 x 1,200, Medium Low: 1,024 x 768, Small: 640 x 480, Movie: 320 x 240 (15bps) or 160 x 120 (15bps) |
Number of Recordable Images
| Image data |  These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode. |
Time of Recordable Movies
| Movie data |  Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. |
Playback Specifications
| Playback Modes File | Single, Index (9 thumbnail images), Magnification (approx. 3x or 6x on built-in LCD monitor) or Slide Show |
Erasing Specifications
| Erase Modes | Single Image, All Images |
Interfaces
| Computer Interface | Universal Serial Bus (USB) |
| Video Out | Audio/Video Output (NTSC or PAL selectable, monaural audio) |
| Other | CF card slot (complied with CF Type II standard). Direct connection to Canon Card Photo Printer CP-10 (no computer required). |
| Power Supply | Rechargeable Lithium-ion battery (type: NB-2L) or AC Adapter Kit ACK 700 is necessary.LCD ON: Approx. 180 images LCD OFF: Approx. 420 images (under Canon's standard conditions*2 with full-charged battery)Approx. 150 min. (under Canon's standard conditions*3 with full-charged battery) |
| Power Source | Rechargeable Lithium-ion battery (type: NB-2L) or AC Adapter Kit ACK 700 is necessary. |
| Shooting Capacity | LCD ON: Approx. 180 images LCD OFF: Approx. 420 images (under Canon's standard conditions*2 with full-charged battery) |
| Playback Time | Approx. 150 min. (under Canon's standard conditions*3 with full-charged battery) |
Physical Specifications
| Operating Temperature | 32-104°F (0-40°C) |
| Operating Humidity | 10-90% |
| Dimensions (W x H x D) | 4.4 x 2.3 x 1.7 in. /112.0 x 58.0 x 42.0 mm. (excluding protruding parts) |
| Weight | Approx. 9.2oz./260g (camera body only) |
Computer System Requirements
| Mac Requirements | Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 8.6 through 9.1 (Please see our Mac OS X Compatibility Statement)CPU: Power PC Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook). RAM: 20MB and over for application |
| PC Requirements | Hardware: IBM PC/AT compatible OS: Windows 98 (including the Second Edition), Windows 2000, Windows Me, Windows XP (Please see our Windows XP compatibility statement)CPU: Pentium 150 MHz and over Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems. RAM: 32MB or more (Windows 98)RAM: 64MB or more (Windows 2000/Windows ME |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
