Canon Support for PowerShot S50 | Canon U.S.A., Inc.
PowerShot S50
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact Digital Still Camera with Built-in Flash and 3x Optical/4.1x Digital/12x Combined Zoom Lens. Lens and Flash accessories available. |
Image Capture Device
Type | 1/1.8-inch Charge-Coupled Device (CCD) |
Total Pixels | Approx. 5.3 Million |
Effective Pixels | Approx. 5.0 Million |
Lens
Focal Length | 7.1-21.3mm zoom lens (35mm film equivalent: 35 - 105mm) |
Digital Zoom | 4.1x |
Focusing Range | Normal AF: 50cm (1.6 ft.)- infinity Macro AF: 10 - 50cm/ 3.9in. - 1.6 ft. (wide angle)/ 33 - 50cm/ 1.0 - 1.6 ft. (telephoto)Manual focus: 10cm/ 3.9 in. - infinity (wide-angle) / 30cm/ 1.0 ft. - infinity (telephoto) - infinity |
Autofocus System | Around most of picture area; AF lock and Manual focus are available. |
Viewfinders
Optical Viewfinder | Real-image optical zoom viewfinder |
LCD Monitor | 1.8 inch low temperature polycrystalline silicon TFT color LCD |
LCD Pixels | Approximately 118,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/2.8 - 4.9 |
Shutter Speed | 15 - 1/1,500 sec. Slow shutter speed of 1.3 sec. is only available in select modes. |
Exposure Control
Sensitivity | AUTO/ ISO 50/100/200/400 equivalent |
Light Metering Method | Evaluation/Center-weighted average/Spot |
Exposure Control Method | Program AE, Shutter priority AE, Aperture priority AE or Manual |
Exposure Compensation | +/- 2 EV in 1/3-stop increments |
Auto Exposure Bracketing | (AEB) is available |
White Balance
White Balance Control | TTL Auto White Balance, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash), or Custom. |
Flash
Built-in Flash | Operation Modes: Auto/On/Off, Auto Red-Eye Reduction ON/OFF |
Flash Range | WIDE: 1.8 - 13.1 ft. TELE: 1.8 - 8.2 ft. (When sensitivity is set to ISO 100 equivalent) |
Recycling Time | Approx. 10 sec. or less. |
Flash Exposure Compensation | +/- 2.0 EV in 1/3-step increments |
Shooting Specifications
Shooting Modes | Auto, Creative zone (P, Av, Tv, Custom), Image zone (Portrait, Landscape, Night Scene, Fast Shutter, Slow Shutter, Stitch Assist, Movie) |
Photo Effects | Vivid Color, Neutral Color, Low Sharpening, Sepia, Black & White |
Self Timer | Operates with approx. 2 sec. or approx 10 sec. count-down |
Wireless Control | Not Available |
Image Storage
Storage Media | CompactFlash (CF) Card Type I or Type II |
File Format | Design rule for Camera File System (DCF*1) |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
Image Recording Format | Still Image: JPEG (Exif 2.2 compliant)/ RAW |
JPEG Compression Mode | SuperFine, Fine or Normal |
Number of Recording Pixels | 2592 x 1944 (Large), 1600 x 1200 (Medium 1), 1024 x 768 (Medium 2), 640 x 480 pixels (Small) Movie: 320 x 240 or 160 x 120 |
Number of Recordable Images
Image data |  These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode. |
Time of Recordable Movies
Movie data |  Individual movie clips are limited to 3 minutes maximum per clip. Above figures show total movie capacity on various CF cards, measured under Canon's standard test conditions, and may vary depending upon scene, subjects or camera settings. |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnail images), Magnification (approx. 2x to 10x on built-in LCD monitor) or Slide Show |
Erasing Specifications
Erase Modes | Single Image, All Images |
Interfaces
Computer Interface | Universal Serial Bus (USB) (mini-B jack) |
Video Out | Audio/Video Output (Video:NTSC or PAL selectable monaural audio) |
Other | CF card slot (accepts Type I and Type II cards). Direct connection to Canon Card Photo Printers and select BJ Printers (no computer required) |
Power Supply | 1. Rechargeable Lithium-ion battery (NB-2L). 2. AC Adapter kit (ACK-700) 3. Car battery adapter (CBC-NB2)Approx. 210 shots (LCD monitor ON) Approx. 460 shots (LCD monitor OFF)Approx 160 min. |
Power Source | 1. Rechargeable Lithium-ion battery (NB-2L). 2. AC Adapter kit (ACK-700) 3. Car battery adapter (CBC-NB2) |
Shooting Capacity | Approx. 210 shots (LCD monitor ON) Approx. 460 shots (LCD monitor OFF) |
Playback Time | Approx 160 min. |
Physical Specifications
Operating Temperature | 32 - 104°F (0 - 40°C) |
Operating Humidity | 10 - 90% |
Dimensions (W x H x D) | 4.41 x 2.28 x 1.65 in./112.0 x 58.0 x 42.0mm (Excluding protrusions) |
Weight | Approx. 9.2 oz./260g (camera body only) |
Computer System Requirements
Mac Requirements | Hardware: Power Macintosh, PowerBook, iMac or iBook OS: Mac OS 9.0 through 9.2, OS X (Version 10.1/10.2). (Please see our Mac OS X Compatibility Statement) Note: Adobe Photoshop LE, Canon File Viewer Utility v. 1.0, and USB Mounter v. 1.8 software are not supported in Mac OS X. CPU: Power PC Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook). RAM: 20MB and over for application |
PC Requirements | Hardware: IBM PC/AT compatible OS: Windows 98 (including the Second Edition), Windows 2000, Windows ME, Windows XP (Please see our Windows XP compatibility statement) CPU: Pentium 150 MHz and over Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME or Windows XP systems. RAM: 64MB or more (Windows 2000/Windows ME/Windows 98), 128MB or more (Windows XP) |
*1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronics and Information Technology Industries Association (JEITA). |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
