Canon Support for PowerShot SD300 | Canon U.S.A., Inc.
PowerShot SD300
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 03.31.07
File Size 1018.37 KB
Date 03.31.07
File Size 10.51 MB
Date 03.31.07
File Size 443.62 KB
Date 03.31.07
File Size 6.54 MB
Date 03.04.10
File Size 6.23 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash, 3x optical zoom/ 3.6x digital zoom/11x combined zoom.
Image Capture Device
Type 1/2.5 inch Charge-Coupled Device (CCD)
Total Pixels Approx. 4.2 Million
Effective Pixels Approx. 4.0 Million
Lens
Focal Length 5.8(W)-17.4(T)mm, f/2.8-4.9 (35mm film equivalent: 35-105mm)
Digital Zoom 3.0x
Focusing Range Normal: 1.0 ft./30cm to Infinity, Macro: 1.2 in.-16 ft./3-50cm(W), 1.0-16 ft./30-50cm(T), Digital Macro: 1.2-3.9 in./3-10cm
Autofocus System 9-point AiAF/1-point AF (Fixed to center) Intelligent Orientation Sensor, AF Lock, AF-assist Beam On/Off
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 2.0 inch low temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 118,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8(W), f/4.9(T)
Shutter Speed 15-1/1500 sec.* * Manual setting is available from 15 to 1 sec. when in Long Shutter mode.
Exposure Control
Sensitivity Auto*; ISO 50/100/200/400 equivalent *Camera automatically sets optimum speeds.
Light Metering Method Evaluative, Center-weighted average or Spot* *Metering frame when spot is center fixed.
Exposure Control Method Program AE
Exposure Compensation +/-2.0 stops in 1/3-stop increments
AE Lock Available
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), or Custom
Flash
Built-in Flash Auto, Auto with Red-Eye Reduction, Flash on with Red-Eye Reduction, Flash On/Off, Slow-sync
Flash Range Normal: 1.6-11.5 ft./50cm-3.5m(W); 1.6-6.6 ft./50cm-2.0m(T) Macro: 1.0-1.6 ft./30-50cm(W/T) (When ISO is set to AUTO)
Recycling Time Approx. 10 sec. or less
Shooting Specifications
Shooting Modes Auto, Manual, Scene Modes (Digital Macro, Portrait, Night Snapshot, Kids & Pets, Indoor, Underwater), Stitch Assist, Movies
Photo Effects Off, Vivid, Neutral, Low Sharpening, Sepia, Black & White
Self Timer Operates with approx. 2 sec. or 10 sec. count-down
Wireless Control Not Available
Continuous Shooting Approx. 2.4 shots/sec. (Large/Fine Mode and LCD screen is Off)
Image Storage
Storage Media SD Memory Card
File Format Design Rule for Camera File System Exif 2.2 (JPEG)
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still Image: JPEG (Exif 2.2 compliant)
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels Large: 2272 x 1704, Medium1: 1600 x 1200
Medium2: 1024 x 768, Small: 640 x 480 pixels
Movie: 640 x 480, 320 x 240 or 160 x 120
Number of Recordable Images
Image data &#160;Note: N=Normal F=Fine SF=SuperFine Storage capacity varies depending on the scene or the subjects. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of SD Memory Card. Individual clips are limited to 3 minutes.
Playback Specifications
Playback Modes File Single, Index (9 thumbnail images)
Erasing Specifications
Erase Modes Still images: Single Image, All Images Movie: Part of Movie, All Movie
Interfaces
Computer Interface USB (mini-B PTP), Audio/Video Output (NTSC or PAL selectable)
Video Out NTSC or PAL
Other SD memory card slot. Direct connection to Canon CP Printers and BJ Photo Printers (no computer required), using camera's USB cable.
Power Supply 1. Rechargeable Lithium-ion battery (NB-4L)
2. AC Adapter Kit (ACK-DC10) sold separatelyNB-4L: LCD On - Approx. 140; LCD Off - Approx. 400Approx. 180 min.
Power Source 1. Rechargeable Lithium-ion battery (NB-4L)
Shooting Capacity NB-4L: LCD On - Approx. 140; LCD Off - Approx. 400
Playback Time Approx. 180 min.
Physical Specifications
Operating Temperature 32-104&deg F/0-40&deg C
Operating Humidity 10-90%
Dimensions (W x H x D) 3.39 x 2.09 x 0.82 in. / 86.0 x 53.0 x 20.7mm
Weight Approx. 4.59 oz./130g (camera body only)
21 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian and Turkish)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
